PTS Remote start from OEM Fob - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2012, 08:55 PM   #11
MKorn
MKorn's Avatar
Fan#: 97610
What I Drive: 2012, SE, Sport, 5MT, Hatch -Silver
FF Reputation: 1 MKorn Good Standing Member
will that work with a manual?
MKorn is offline
Old 05-10-2012, 09:08 PM   #12
SaToX
Fan#: 94321
What I Drive: 2012 White Titanium Hatch
FF Reputation: 4 SaToX Good Standing Member
not off the oem remote unfortunately
SaToX is offline
Old 05-10-2012, 09:09 PM   #13
Aychdot
Fan#: 95866
What I Drive: Then 1995 Escort, Now 2012 Ti hatch
Points 166, Level 3
Points: 166, Level: 3 Points: 166, Level: 3 Points: 166, Level: 3
Level Up 32% Completed
FF Reputation: 1 Aychdot Good Standing Member
can you use the idatalink ADS-AL CA instead? I don't see the one you have listed on ebay. How much do you think it will cost to get it programmed?
Aychdot is offline
Old 05-10-2012, 09:28 PM   #14
SaToX
Fan#: 94321
Yes. The ADS-Al CA is the module I used. They are programmable to do almost any car on the market depending on the firmware you load into it. The downside with this particular firmware is that you have to do a 2 part programming. First hook up all the wires then program it for step one. Plug it back into the car then proceed. What it essentially does is copy the key information the first time you turn the ignition on then you have to remove it, plug it back into the computer and continue to program for step 2. Second step essentially checks the CAN network in the car to make sure that it is reading the car correctly.
The part you need to be able to flash the unit is ADS-USB
SaToX is offline
Old 05-10-2012, 09:35 PM   #15
MKorn
MKorn's Avatar
Fan#: 97610
ok, thanks
MKorn is offline
Old 05-10-2012, 10:27 PM   #16
electech
Fan#: 85620
What I Drive: '12 Focus Titanium Hatch
FF Reputation: 1 electech Good Standing Member
It looks like if you have to program it online, you need to log on with a business id. I did find it here and looks like they do the programming for you and is cheap enough.
http://www.sonicelectronix.com/item_...-AL-CA-64.html
electech is offline
Old 05-11-2012, 07:51 AM   #17
SaToX
Fan#: 94321
Easiest thing to do might be to get everything wired in then take a spin out to your local car starter shop. They would most likely have the programmer. It is only about 6-7 minutes to program both steps.
SaToX is offline
Old 05-11-2012, 08:17 AM   #18
electech
Fan#: 85620
Car starter shop? Not sure what that is. If a person ordered this from the link in my other post and they claim to do the programming for you, would this work? Do you have to wire, hook up, then unhook and program. I think you said that the box learns the car on that initial turn on but if this is the case I am wondering why they would advertise they would program your car for you.
Looking forward to the install video as this has really got me interested, especially for the price.
electech is offline
Old 05-11-2012, 09:22 AM   #19
hand-filer
hand-filer's Avatar
Fan#: 90895
What I Drive: One less Ford
FF Reputation: 1 hand-filer Good Standing Member
Thanks for posting this. I wish I would have held off on buying the Ford remote start system. It is a complicated install and generally speaking a POS.
2012 Mustang Brembo GT - Kona Blue
2013 Acura RDX - Alabaster Silver
hand-filer is offline
Old 05-11-2012, 10:53 AM   #20
SaToX
Fan#: 94321
In most cars you do not need to do a 2 step programming so they can simply program the unit on their end and send it to you. In the case for the focus it goes like so.
1. Program part one on computer
2. Plug into car turn ignition on (light on box flashes rapidly and stays that way)
3. Remove box from car plug back into computer and program for part 2
4. Plug back into car and turn ignition back on, wait and light will go solid green.
5 Done.
And yes the factory ford one is a POS they use and extra key in a box. I seen the diagram when I first got my car and refused to do it. The diagram from Idatalink is doing exactly what you would do to start the car 1. shows the key present, holds the brake, hits the start button, lets go of brake. The benefit of this is when the dealer plugs in with the scan tool there will be no codes present from modules not being power up properly.
SaToX is offline
