2012 5-Door tail lamp scratching body - Page 17 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-24-2012, 10:54 PM   #161
mrname
Fan#: 104170
What I Drive: 2013 Tangerine Scream ST
FF Reputation: 1 mrname Good Standing Member
Hello,
I am a 2013 ST owner. I purchased my car on Sept 1. I have been posting my impressiojs and pictures at "http://fordstnation.com/my-st/1578-my-st-pure-emotion.html".
Recently, following this forum I have been made aware of the paint chipping that shows up around driver side tail light area. After reviewing my car, I too found out that my ST has similar problem. I posted some pictures and my observations/comments at "http://fordstnation.com/focus-st-repair-shop-service/1858-rear-tail-lights-chipping-paint-4.html".
Cheers,
mrname is offline
Old 09-25-2012, 09:41 AM   #162
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,379, Level 36
Points: 3,379, Level: 36 Points: 3,379, Level: 36 Points: 3,379, Level: 36
Level Up 20% Completed
Forum Activity 22%
Activity: 22% Activity: 22% Activity: 22%
Originally Posted by HuskerFocus View Post
I don't know. I am taking it into my dealer soon (Crystal from the Ford Customer Service team pushed it on up to regional for me). From the conversation I had with the Regional Rep, he said that the dealer will take a look, and assuming it is what I say it is (and it certainly will be), they will send it out for a quote and repairs. All while they provide me a rental.
What I will be asking when I take it in is, "What will you be doing to prevent this from happening in another 6 months?" It would appear that the light, when installed, was simply tightened a bit too much, hence it rubbing. I would assume that either a 'buffer' will be installed to keep it just off the body. But, who knows.
Also, in all fairness to my dealership, I had yet to tell them. The Regional Rep did it first. But they have been nothing but great/understanding with the transmission re-flash/programming and the strut TSB...
The up side is that both my dealer and regional rep (Central IL) have been polite and responsive.
Hey HuskerFocus,
I'm glad to hear that your dealer and regional rep are taking great care of you. Keep me in the loop moving forward; send me a PM if you need anything further.
-Crystal
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 09-25-2012, 10:02 AM   #163
HuskerFocus
Fan#: 100149
What I Drive: 2012, Ingot Silver, SEL Hatch
FF Reputation: 1 HuskerFocus Good Standing Member
Originally Posted by mrname View Post
Hello,
Cheers,
Read your detailed post! Thanks! But is there any way you would be able to post some of the pics on here? I'd hate to register for ST Nation when I don't have an ST :) Plus, it would help a number of people that surely wouldn't register over there.
Vehicles: 2012 Focus SEL - Ingot Silver - +MyFord Touch
Mods: Drop in K&N Air filter, 30% Tint
Build Date: 12/19/2011
HuskerFocus is offline
Old 09-25-2012, 01:34 PM   #164
lddavis
Fan#: 104180
What I Drive: 1997 Red Outback
FF Reputation: 2 lddavis Good Standing Member
An excellent question. Most people seem to have no trouble getting the paint damage repaired under warranty -- but there's no point in just repainting the panel without also fixing the light. And there doesn't seem to be a universally-agreed upon method for that.
It would also likely be wise for Ford to fix the root cause at the plant. Even if it's one car in a thousand, that's 200 annoyed customers next year, and paying just one bodyshop to repaint a panel adds up to a lot of washers.
lddavis is offline
Old 09-25-2012, 02:22 PM   #165
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,050, Level 66
Points: 10,050, Level: 66 Points: 10,050, Level: 66 Points: 10,050, Level: 66
Level Up 50% Completed
Forum Activity 24%
It appears both of my left side lamps are rubbing badly, the hood is even worse than the tail lamp, now concerned about every body gap. Grr.
suss6052 is offline
Old 09-25-2012, 03:00 PM   #166
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
If you want to save your self some time and trouble, just pop the hood and adjust the two rubber hood stops mounted just behind the grille. Unscrewing them a small amount will raise the spot where the hood rests and will keep it off the headlights. Don't overdo it....you're only looking to add a couple mm of clearance, and you don't want to get your fender/hood gap out of whack. This is likely the same procedure your dealership will follow. If the Q/C guy was taking a nap when your car rolled off the line, these adjusters probably got missed.
cbdallas is offline
Old 09-25-2012, 03:04 PM   #167
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
Need the paint fixed first or the hood will just rust in that spot, more so if its adjusted clear of the lamp.
suss6052 is offline
Old 09-25-2012, 07:43 PM   #168
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 24%
Tail light rubbing, but the body shop on first glance claimed the light looked like the car was backed into, but the bumper cover doesn't show any signs of that damage (only damage seemingly from the lamp rubbing against it, same as the rear quarter panel.
Have to bring it back tomorrow for them to actually look at this and the hood/ LF head lamp.
There is sort of a black mark and other scrape marks on the lamp however. But I'm fairly certain that it was rubbing on the fender the entire time I've had the car.
I'm just getting more and more depressed on all the little things they screwed up on and hadn't admitted. They might get ford to fix the paint, but if they claim it was caused by the damage to the lamp then I may have to make an insurance claim (at least I believe I lowered the deductible, but that will still suck, and also at that point I might as well have them work on the front passenger door as well as there is a dent there, and scratches probably everywhere .
LF headlamp where the hood was rubbing on it.
Its worn through the paint in less than 5000 miles. That will likely rust quite badly if its not fixed soon as winter is coming.
Not sure what hit the radiator support when nothing on the hood should touch it, except potentially under an "over slam" condition.
That does not really look bent to me, but what do I know. I don't know how the lamp got damaged externally, but I do know its worn through the paint down to the primer or bare metal on one side, but the gaps seem excessive on the other side almost. Not sure that it hasn't done damage there also.
For comparison here is the gap between the hood and the headlamp on the right side
This is much more uniform, but the damage is already done on the other side. I hope they will fix this a bit better than the fact that they are ignoring the seat concern. They claim its working perfectly, but they are denying the existence of the evidence in their own factory service manual as posted to their dealer service page, as well as other sources. I'm about at the end of my rope. I mean come on, its no where near as complicated as a dual clutch mechanism or the engine, but seriously is that the best they can come up with?
Here's the photo evidence of the damage at both ends. I haven't heard of anyone noticing any issues with the head lamp and the hood however.
suss6052 is offline
Old 09-25-2012, 07:47 PM   #169
RedComet
RedComet's Avatar
Fan#: 99232
What I Drive: TB '14 Fiesta ST
Points 2,564, Level 30
Points: 2,564, Level: 30 Points: 2,564, Level: 30 Points: 2,564, Level: 30
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 8 RedComet Good Standing Member
When my fiancee comes home with our car, I'm going to inspect my lights to see if I've got the same issue. I hope not.
Kay - HN#79
'14 Fiesta ST Tux. Blk. 6MT, COBB Stg. 1
Gone: '12 Hatch SE Sport MTX75
V - Power* Junkie
RedComet is offline
Old 09-26-2012, 10:11 AM   #170
HuskerFocus
Fan#: 100149
I checked my front lights, and they seem okay on my build. I did notice a paint chip on the front of my hood ... just under the edge, which made me wonder "wtf..." but I can't see how the lights or even a hard slam would do that. I'll likely just Dr. Paint Chip that myself...
But as for the rear lights ... my rear passenger is the only one with the visible damage. But the rear driver side also has no clearance (as in paper can't slide) in the same spots... I just wonder if/when that may start to show damage. We'll see what the dealer can/cannot do.
Also, regarding a ford fix, if they do allow it, they should take an initial look, then off to a body shop (if they don't have one themselves) and provide you a rental/loaner while it is being fixed.
