Adding Subwoofers to a Titanium - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-30-2012, 11:43 AM   #11
HammerStriker
HammerStriker's Avatar
Fan#: 86553
What I Drive: 2012 Ignot Silver Hatchback SEL
FF Reputation: 1 HammerStriker Good Standing Member
Originally Posted by mellonas View Post
So went by an audio shop down the street and they said all they would have to do is plug a new amp into the old one to run the new subs. I had an old pathfinder with the bose audio system and it had its own amp and i ran subs through it for like 8 years so Im sure this would be just fine
The problem as I see it is that our Sony sub is not just a sub. It is also the DSP. There is no sub feed from the HU. Also our system chokes down output the higher you turn the volume to keep distortion from blowing the stock speakers.
To get the volume / bass you are seeking, you need to eliminate the Sony sub and replace it with a good DSP + amp + bigger sub(s).
I haven't found a viable solution at a price point I'm OK with yet, but I'm still looking.
HammerStriker is offline
Old 06-02-2012, 10:31 PM   #12
jvillareal78
jvillareal78's Avatar
Fan#: 95766
What I Drive: 2012 White Platinum Titanium HB
FF Reputation: 1 jvillareal78 Good Standing Member
Id be interested in knowing if anyone has taken the sony sub part, and is it possible to replace with another 8" sub inside the factory box?
jvillareal78 is offline
Old 06-03-2012, 11:20 AM   #13
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
I would think its possible. I replaced the factory 8" sub that came with the audiophile system in my truck, but the SQ stayed the same. You need to replace everything to make an improvement over the factory sony system.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
Old 06-04-2012, 04:23 PM   #14
mellonas
Fan#: 98545
What I Drive: 2012 Black Ford Focus Titanium
FF Reputation: 1 mellonas Good Standing Member
so NO ONE has put after-market sub's in their 2012 Focus?
mellonas is offline
Old 06-04-2012, 05:18 PM   #15
HammerStriker
Fan#: 86553
Yes, they are out there, but I don't think anyone has added subs to the Sony system.
Do a search and let us know what you decide.
Old 06-04-2012, 06:46 PM   #16
kaptinkurk
Fan#: 98769
What I Drive: 2012 Sterling Grey Sedan
FF Reputation: 1 kaptinkurk Good Standing Member
Yes, I have added subs to my 2012 focus, however it is an SE and without the sony system. The sony system is going to cause you much more problems than the regular 4-6 speaker configuration because of the built in amp/sub. You could just splice in an LOC and run that to add additional subs to run aside the built in sub, however you will want to be careful how much strain you are putting onto the alternator after doing this.
This is why it is not really recommended to adding aftermarket subs to the sony system, or any system with amps/subs added in by stock. You have to fully know what you are doing and what to order not to cause problems with the stock configuration. The last thing you want to do is add subs to it not knowing what your doing and cause hundreds/thousands of dollars of damage to a no longer warrantied sound system.
kaptinkurk is offline
Old 06-05-2012, 04:03 PM   #17
mellonas
Fan#: 98545
I would definitely get a professional to install at this point, because it is becoming more difficult than I imagined. Or I might just forget about subs altogether. By the time I got a custom box to fit well in the trunk and a professional installation and what not, it would prbably costing more than it's worth.
mellonas is offline
Old 06-05-2012, 11:19 PM   #18
I Bleed Ford Blue
Fan#: 94113
Your best solution would be run the leads going to the sub into a LOC, then into another amp, then to a new sub or better sub in the factory box. At least that way you will have some real power going to the sub, instead of the crap sony amp they use now that is rated at 390 watts total for all 10 speakers, and that rating is more than likely peak power. The RMS is probably around 200, then divide that into 10 speakers and you get like 20 watts per channel.
L-CCC #18/HOIA #37
Old 06-13-2012, 07:17 PM   #19
d_kelly160
Fan#: 100154
What I Drive: 2012 black s
FF Reputation: 1 d_kelly160 Good Standing Member
what warranty will it ruin .. im looking to add the big three and and put two 15s in my 2012 ford focus
more spl then just regular riding around subs
d_kelly160 is offline
Old 06-19-2012, 06:48 PM   #20
mellonas
Fan#: 98545
It would ruin the warranty on focus's with the sony sound system option. i.e. all titaniums. They have factory amps in them.
mellonas is offline
