2012 Ford Focus K&N Intake kit Released. - Page 14 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 05-18-2012, 02:13 PM   #131
suss6052
suss6052's Avatar
Fan#: 95752
FF Reputation: 23 suss6052 Great Standing Member
Originally Posted by VOLDAR View Post
I have a question: what happens if I disconnect the positive battery cable instead of the negative cable ? Because in my car, the easiest to disconnect is the positive, not the negative cable. I don't know what it is in yours when you say "negative battery cable".
It is not the first time when I see people saying "disconnect the negative battery cable". In my opinion, whatever needs to be done is to disconnect a battery cable (regardless which one) to have the same result. Am I right or completly out of touch with the reality of this engine car ? (not that I don't know that I am at least 20 years behind).
Basically the circut is broken when the cable is removed from the negative terminal in a safer manner. If you disconnected the postitve battery cable only there is a risk of completing the circuit and causing a battery explosion than if you prevent the flow of electrons by disconnecting the negative terminal first.
suss6052 is online now
Old 05-18-2012, 02:18 PM   #132
troy-knfilters
troy-knfilters's Avatar
Fan#: 85424
What I Drive: 2000 Ford Taurus SE (FFV) Vulcan
FF Reputation: 1 troy-knfilters Good Standing Member
These warnings should be followed because this can happen....
It's not something I would like to see anyone have happen to them.
Troy.
Resident K&N Guy - Got a Question about a K&N Product? Let me know - I can help!
troy-knfilters is offline
Old 05-18-2012, 02:25 PM   #133
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Volt 2014, White Diamond
FF Reputation: 3 VOLDAR Good Standing Member
THANK YOU for the info. Now, why in my car the positive battery cable is the easiest to disconnect ? I can't post a picture right now, but it is something like in the picture bellow (see the "red wire" = battery positive)
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---replaced by---
Chevy Volt 2014, White Diamond, Luxury Package, S1, Navigation.
VOLDAR is offline
Old 05-18-2012, 02:29 PM   #134
troy-knfilters
Fan#: 85424
I'm not a Ford Engineer but I can speculate that having the positive terminal under a metal cowl would make jump-starting the car VERY dangerous, it's in the best interest if the positive is easiest to get to from a roadside-emergency standpoint.
Troy.
Old 05-18-2012, 02:35 PM   #135
VOLDAR
VOLDAR's Avatar
Fan#: 90444
Troy.
It might be a reason. Thank you, again !
Now, back to the thread subject: I like more and more the K&N intake. Hmmm... I have to be cautious, because I might end up buying one.
---replaced by---
VOLDAR is offline
Old 05-18-2012, 02:38 PM   #136
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Troy.
And the convenient ground at the strut tower makes negative easily accessible from that standpoint.
Hatch Nation #90
TboneZX3 is offline
Old 05-18-2012, 03:05 PM   #137
Fastlane54
Fastlane54's Avatar
Fan#: 98286
What I Drive: 2012 SE Sport HB, Red Candy-203A
FF Reputation: 1 Fastlane54 Good Standing Member
With the battery cover removed:
So it is my understanding that removing the cable connection at "NEGATIVE" in the photo is disconnecting the negative from the battery. It really is a handy spot for jumps.
Fastlane54 is offline
Old 05-18-2012, 03:14 PM   #138
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I don't have my car here to check, but I would speculate that you would need to remove the actual clamp from the post to remove all negative contact from the battery. There are more than likely more wires going to the negative post than just the body ground you label there as "negative".
Indeed, it is a great spot for jumpstarts, as you're not supposed to hook ground up directly to the "low charge" battery in a jumpstart situation. Hooking negative directly to a low charge battery could induce an arc (short) between the posts if the battery is damaged. Using that body ground in the pic would reduce the chance of that happening.
Hatch Nation #90
TboneZX3 is offline
Old 05-18-2012, 04:52 PM   #139
Fastlane54
Fastlane54's Avatar
Fan#: 98286
... There are more than likely more wires going to the negative post than just the body ground you label there as "negative".
Would any additional wires connected to the - terminal on the battery be using it as the source of the ground for their circuits? If so, they would also be disconnected from ground when removing that negative connection in the photo.
Old 05-18-2012, 05:00 PM   #140
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
That would be true, assuming that negative connection were the only ground to the body. However, circuits may still be "complete" if they are connected to the battery negative, and may also be "grounded" by other means (other wires, circuits, etc.). Again, I can't confirm this until I'm near my car...
Hatch Nation #90
TboneZX3 is offline
