Go Back   Focus Fanatics > Ford Focus Tech Discussions > DURATEC Performance (2003-2011)
DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
Old 05-16-2012, 04:50 PM   #11
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
If you swap the 2.3 head you also need to do the 2.3 intake manifold , this needs tuning
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 05-16-2012, 07:24 PM   #12
d-coupe
Fan#: 97698
What I Drive: 2008 S coupe
FF Reputation: 1 d-coupe Good Standing Member
What's different with the 2.3 intake? I also need the 2.0 cans and valve cover, correct? What else? Head studs and gasket of course.
2008 VS 5-speed coupe. CFM CAI, FRPP suspension, SES grill+tails
d-coupe is offline
Old 05-16-2012, 07:42 PM   #13
Slkfucusdvr
Slkfucusdvr's Avatar
Fan#: 90401
What I Drive: 2005 ZX3 2.0L Black
FF Reputation: 1 Slkfucusdvr Good Standing Member
Pretty much anything past stock should get a tune just to run your engine safely. I did most of the bolt up mods without a tune and everything ran fine for 20k+ but others have not had such luck (check engine lights) Your ECU can only adapt so much to the modifications you have made to the engine. I would say you definately need a tune if running a bigger head such as the 2.3. Like tom said I believe, the 2.3 head gives you more flow. You are correct about the motor running lean if you put the 2.3 head on. I did not change my head on my 2.0 but i put higher compression pistons in, stage 1 cams, removed the intake runner valves and put a CAI on and just that is making my engine run crazy lean. Hopefully the tune will fix it. Other than that the 2.3 head should bolt right up no problem. Still have to use the 2.3 IM though. Good luck to ya! Let us know how it turns out
Giddyup focus.... Giddyup...
Slkfucusdvr is offline
Old 05-16-2012, 07:45 PM   #14
Slkfucusdvr
Fan#: 90401
Also, every time you take the head off it is good practice to put in new head studs and head gasket. Actually head gasket is a must. Get the deck milled for good practice to. I do believe the 2.0 cams fit in the 2.3. Dont quote me on that. I am sure someone else will second me or correct me on that. And the valve cover should fit. As far as the intake manifold, I am not sure why the 2.0 doesnt work with the 2.3 head. I just know that it doesnt lol
Old 09-17-2012, 07:49 PM   #15
budpln
budpln's Avatar
Fan#: 89951
What I Drive: 2008 red ses
FF Reputation: 1 budpln Good Standing Member
we need someone to do this and do a write up.. with lots of pictures then videos thatd be legit
budpln is offline
Old 09-17-2012, 08:04 PM   #16
budpln
budpln's Avatar
Fan#: 89951
http://www.ebay.com/itm/FORD-ESCAPE-...8b2d4d&vxp=mtr
would this head work?
budpln is offline
Old 09-18-2012, 08:48 AM   #17
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 34 felixthecat Great Standing Member
That 23 head will work. With it run a cossie or knockoff intake manifold. Or use the dual runner 23 manifold. W/ the 23 manifold you will need the imtv to use both the long & short runners. It'll probabiltiy be less hassell to run a aftermarket intake w/ a tune. For sure add a set of cams to the 23 head to take advantage of the head. Even the entry level cams= crane's or crower's stage 1 make a difference. You don't need head stud's, just get a new set of head bolts w/ your head gasket.
Interduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 09-18-2012, 11:25 AM   #18
Semir
Fan#: 85484
What I Drive: 01 FlatBlack ZX3 shell, 07 interior
FF Reputation: 1 Semir Good Standing Member
Is absolutely neccesary to run the 2.3 IM with the 2.3 head? I am also looking to do this, and could only find a head without the manifold.
Semir is offline
Old 09-19-2012, 02:55 AM   #19
VEGAS
VEGAS's Avatar
Fan#: 75680
What I Drive: 2007, Baby Blue, ZX3 2.3L
FF Reputation: 4 VEGAS Good Standing Member
it is not I run a 2.0L intake with a 2.3L engine
However since your doing one you should get the Cozzy knockoff intake since your robbing the head of air if you do not, not that it has to be done now, but does need to be done.
I will later this year myself
Car #1 2007 Focus ZX3 SE - Blue 2.3L, Automatic, Toms Tune, OBX headers, FSWERKS Cold Air Intake and Exaust, Loaded
Car #2 2007 Focus ZX3 S - Silver 2.0L, Manual,TOTALED!!!! (Half Rebuilt)
Car#3 Mustang GT 2007 LOADED!
VEGAS is offline
Old 09-19-2012, 07:40 PM   #20
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
FF Reputation: 5 badazz2010focus Good Standing Member
So someone finally figured out how to get cams to work with the FBW setup that's fly by wire. That's awesome LOL
badazz2010focus is offline
