Yet another 2012 SE Sport audio upgrade - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-18-2013, 06:58 PM   #31
HatWobble
Fan#: 97153
What I Drive: '12 Focus SE 5spd Hatch 203A
FF Reputation: 1 HatWobble Good Standing Member
Originally Posted by Kbostick88 View Post
As a professional car audio installer I strongly recommend trying to rerun your power wire down the driver side of your car. You always want to run it down the same side as the batter. You'd also want to go through the grommet not through the outside of it pressing against the metal. there is a plastic cover where the clutch plate would go, i recommend going there to run the wire into the car. Your are much less prone to problems this way. going across the engine you increase the heat against the wire as well as have it rub against the metal between the firewall and grommet.
Thanks for the tips.
Regarding the metal-on-wire contact, I fixed this already and am now running it through the grommet instead of outside of it (see post #27 in this thread). I would have used the clutch plate as you suggested, however I have a clutch there at the moment. :)
Regarding running the wire across the engine bay, I made sure to tie the wire high in the engine bay to maximize the space between it and the engine to reduce the heating effects you mention. I have not had any issues after 10,000 miles of operation, so hopefully everything is OK the way it is.
2012 SE Sport 5MT 203A, Tuxedo Black
HatWobble is offline
Old 03-25-2013, 10:49 AM   #32
Shade8685
Shade8685's Avatar
Fan#: 99344
What I Drive: 2012 Tuxedo Black SE Sport Pkg
FF Reputation: 1 Shade8685 Good Standing Member
I have the same LC6i installed, and I'm using the yellow/orange power antenna wire to power it, but the unit doesn't turn on. I tested the cable with a multimeter and it has 12v running on it. I was wondering what cable you used to run to the 12v input of the LOC? Does it need to be a constant 12v source, or should the power antenna cable be fine since it just turns on with the HU?
Shade8685 is offline
Old 03-25-2013, 11:23 AM   #33
HatWobble
Fan#: 97153
I had to look at my old pictures to remember what I did...
I just wired the +12V in parallel with the amp. I simply ran wires from the power terminals of the amp to the power terminals of the LOC. This is what AudioControl recommends in the manual.
Even though that antenna wire has +12V, it might not be working because the LOC can't draw enough current through that circuit.
P.S. nice choice of vehicle!
Old 03-25-2013, 11:29 AM   #34
Shade8685
Shade8685's Avatar
Fan#: 99344
I'll have to give that a try. Guess I'll be heading out to buy more wire :)
Thanks for the quick response.
P.S. You car choice isn't too bad either.
Thanks again
Old 03-28-2013, 11:20 AM   #35
Shade8685
Shade8685's Avatar
Fan#: 99344
Just wanted to do a quick follow up. Hooking the power to the amp terminal fixed my issue. LOC is working great and my stereo is much improved.
Thanks again for the help
Old 04-23-2013, 06:43 PM   #36
mister_eff
Fan#: 110362
What I Drive: 2012 Ford Focus Hatchback SEL
FF Reputation: 1 mister_eff Good Standing Member
HatWobble,
What wire did you hook up the "remote on" wire from the LC6i to? Do you have a picture of that? Is it part of the same head-unit wiring harness?
Thanks!
mister_eff is offline
Old 04-23-2013, 10:10 PM   #37
asting
Fan#: 98342
What I Drive: 2012, Tux Blk Met Focus 5d Sport
Points 509, Level 10
Points: 509, Level: 10 Points: 509, Level: 10 Points: 509, Level: 10
Level Up 18% Completed
FF Reputation: 1 asting Good Standing Member
Originally Posted by mister_eff View Post
HatWobble,
Thanks!
This connects to the Amp and tells it when to turn on and off.
2012 SE Hatch - 5 Speed - Tuxedo Black
Engine: K&N Typhoon CAI, Magnaflow 2.25 exhaust 15072
Suspension: MS3 Springs, Focus electric RMM.
Audio: LC6i, Polk Audio db6501 front, db651s rear, db1040DVC sub, Rockford R600-5 Prime, Fatmat
asting is offline
Old 04-23-2013, 10:11 PM   #38
mister_eff
Fan#: 110362
Sorry for my terrible wording. I mean, where did you connect that wire on the car side of things?
Old 04-23-2013, 10:37 PM   #39
asting
Fan#: 98342
I don't think it does. Per a previous post (on page 2 or 3), the LOC uses the signal from the stock speakers to know when it powers on. It then can supply the remote power signal to an amp. So it goes from the LOC to the amp, and does not do anything with the car.
As soon as I get my fatmat and components in I'll be able to verify this though.
asting is offline
Old 04-24-2013, 05:40 PM   #40
mister_eff
Fan#: 110362
Oh I see. The wire that HatWobble mentions goes from the LOC to the amp, like you said. I thought he also had a wire going from the car to he LOC. Thanks for clearing that up.
My bad, HatWobble.
