For Sale: 2000-2011 Trunk and Hatch LED conversion kits - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-10-2012, 08:54 AM   #11
KyleQ
KyleQ's Avatar
Fan#: 84296
What I Drive: 2008 Focus Coupe 5 Speed
Points 957, Level 16
Points: 957, Level: 16 Points: 957, Level: 16 Points: 957, Level: 16
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 3%
FF Reputation: 3 KyleQ Good Standing Member
Looking bright! I've got a LED bulb in the factory spot and its brighter, but not bright enough for my tastes...
2008 SE Coupe MTX
2000 Contour SVT 3L
MSDS Headers/Weapon-R Y-pipe
Torsen T-2/Clutchnet Stage 3
Fidanza 8lb 131 of 2150
KyleQ is offline
    Quick reply to this message
Old 05-10-2012, 06:36 PM   #12
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
Points 36,103, Level 100
Points: 36,103, Level: 100 Points: 36,103, Level: 100 Points: 36,103, Level: 100
Level Up 0% Completed
FF Reputation: 7 VonKrause Good Standing Member
Well if you want a set let me know, just 26 hours till the cut off point for next weeks orders. Also I will have a green and amber one that I will make this weekend for pictures and they will be for immediate sale on Monday.
Originally Posted by joesperformance View Post
once u know for sure, i want a red set.... from the above pics, it looks to me, that the 1st gen trunk is about the same setup....
I want to say they are but at the same time I'm not sure enough to say yes or no but I do have a test coming up soon with a first gen and the 1.5 gen gets tested tonight. So I should know if the 1.5 gen is the same sometime before 10:00pm.
Get your trunk or hatch LED conversion kits here http://www.focusfanatics.com/forum/showthread.php?p=4542652#post4542652
"2nd Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
Old 05-10-2012, 10:55 PM   #13
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Just got through test fitting into a 1.5 gen focus and it is the same trunk layout and size. So as long as they aren't any different from the 1st gen then they should work.
"2nd Gen problems"
SR #233
Old 05-10-2012, 11:40 PM   #14
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
Ok, I got the First kit. Now how am i to hook them up?
-Bob-
2012 F-150 EcoBoost 4X4 (work truck)
Focus S #1, Sedan Revolution #192, Rally Revolution #8, March 2012 SOTM
Focal Distortion, a Ford licensed club and FSC member.
Sgt, USMC (1999-2003)
st12131 is offline
Old 05-11-2012, 02:08 AM   #15
joesperformance
joesperformance's Avatar
Fan#: 92411
What I Drive: 01 Focus SE Sedan, Zetec
FF Reputation: 3 joesperformance Good Standing Member
cut the wire goin to stock trunk light.... the orange wire is ground, dark wire is power, on stock wiring....
joesperformance is offline
Old 05-11-2012, 08:50 PM   #16
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Ok the quality of the pictures are horrible as my camera is broken... Had to use my phone but here is a quick how to.
On the driver side of the trunk there are some holes that you can wedge the long wire through and get as close to the side of the trunk as possible as you will be hiding extra wire over behind the lining.
Attach the LED brick to this area with the 3M tape on the back and run the next run through this hole.
Go past the next cross bar and drop it down on the opposite side of the bar loop it back on itself stick the brick and continue above the rail to the next bar where you repeat.
The last brick will be a little tricky and requires some fishing but go through here
and come out here
then stick here
Next is the wiring part, DISCONNECT THE BATTERY!!! Serious I know it seems silly to have to say this but I DID blow a fuse while soldering my cars kit. If for whatever reason you do blow the fuse it's the "Battery saver fuse."
Anyway once the battery is disconnected remove the plug from the mount andcut the factory plug free, I like as close as possible so I have more wire to work with but it's up to you. Then pull the wire free from it's mounts on the rear of the trunk. (Don't have that pic yet as mine is done already.)
strip the wire back on the trunk wire to expose about 1/4-1/2 inch of the wire and then repeat on the LED strand. Take the provided colored shrink tube and run it over both wires then take the clear shrink tube and place it over the positive wire and slide them down out of the way. Then twist the positives together and fold them flat against the wire.
Push the clear shrink tube over the positive wires and apply fire. Be careful not to set anything on fire in the trunk, the tube will shrink tight over the wire thus making the connection good.
Then take the ground wire from trunk and LEDs and twist them together and slip the colored tube over both wires and apply fire.
I know it's quick and messy but I will have a better how to up as soon as I do a local members install, that and I should have a camera that actually works, and some one to take the pictures instead of me.
-VonKrause-
"2nd Gen problems"
SR #233
Old 05-12-2012, 07:50 PM   #17
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
This weeks orders are finished, the current available kits are the Green and the amber. Can be shipped out as early as Monday.
"2nd Gen problems"
SR #233
Old 05-12-2012, 07:55 PM   #18
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,468, Level 57
Points: 7,468, Level: 57 Points: 7,468, Level: 57 Points: 7,468, Level: 57
Level Up 59% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
Word!
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 05-13-2012, 05:08 PM   #19
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
ok got mine connected. On my 2010, I hooked the black/white stripe LED wire to the cars green/yellow wire & the LEDs black wire to the cars white/blue stripe wire. The LED's are great, nice and bright. I'll take some night time photos some time after dark.
Posted via FF Mobile
st12131 is offline
Old 05-13-2012, 09:48 PM   #20
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
Sweet look forward to it
"2nd Gen problems"
SR #233
