TSB 12B37 - New? - Page 37 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-14-2012, 11:16 AM   #361
jbird1955
jbird1955's Avatar
Fan#: 48235
What I Drive: 2014 Tuxedo Black Ti Hatch
Points 788, Level 14
Points: 788, Level: 14 Points: 788, Level: 14 Points: 788, Level: 14
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 jbird1955 Good Standing Member
Noemi, I do my milage long hand. The readout on the display never gives me acruate results. My 2nd grade math of milage & gallons works perfect every time
Ford Focus 2014 Hatchback 300A Titanium w/ Moonroof
Tuxedo Black Metallic
jbird1955 is offline
Old 06-14-2012, 12:00 PM   #362
mattphoto
Fan#: 95657
What I Drive: 2012 Black Focus SEL
FF Reputation: 1 mattphoto Good Standing Member
Got mine done 2 days ago and initial impressions are:
Shuttering and vibrations at low gears are eliminated. Seems to be a bit more power and certainly smoother shifting when starting from zero. Shifting seems tighter. Not as much rolling backwards when letting off the brake.
I'm happy. Based on some jerks on this board, I thought the shuttering, noise and vibrations from the transmission were because I "didn't know how to drive" - - amazing what they can fix that now with a TSB update, isn't it? [/vindicated]
mattphoto is offline
Old 06-14-2012, 01:41 PM   #363
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,240, Level 95
Points: 25,240, Level: 95 Points: 25,240, Level: 95 Points: 25,240, Level: 95
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 3%
I was pretty surprised to find out how many people 'knew' how the DCT was supposed to shift...
dyn085 is offline
Old 06-19-2012, 06:34 PM   #364
allyy
Guest
Fan#: 95236
What I Drive: 2012 focus
FF Reputation: -3 allyy Poor Behavior Needs Improvement
Originally Posted by danyall2010 View Post
I could be wrong, but I do not think any grinding is normal. I will give it some more break in time and if it does not do it, I will take it in to Ford. That way, I can tell them that I gave it ample time. I have about 11,750 miles on the car right now.
No grinding is not normal
allyy is offline
Old 06-19-2012, 09:21 PM   #365
JesseE1981
Fan#: 88551
What I Drive: 2012 Sterling Grey Focus Hatchback
FF Reputation: 1 JesseE1981 Good Standing Member
Well my car seems to have "reverted", and the transmission is performing poorly again. I don't understand how the car gets worse over time.The car almost literally feels like it is "jumping", or "lurching" forward with each shift. I also swear to god that outside air temperature affects shifting, as it seems to get worse the hotter it is outside.
JesseE1981 is offline
Old 06-19-2012, 10:08 PM   #366
AmishGuy91
Fan#: 85045
What I Drive: 2012 Ford Focus
FF Reputation: 1 AmishGuy91 Good Standing Member
Same as all the previous transmissions updates then...works great at first and then reverts back to previous behavior
AmishGuy91 is offline
Old 06-19-2012, 10:14 PM   #367
VOLDAR
VOLDAR's Avatar
Fan#: 90444
What I Drive: Volt 2014, White Diamond
FF Reputation: 3 VOLDAR Good Standing Member
Hmm, then something should be wrong with mine. Because after more than 2500 km after the FSA, I didn't see any "revert" at all. I will give it another 5000 km to see if what you say it's true. And don't worry, if it is not in 5000 km, I will wait another 10000 km. Everything for you to be happy !
White Platinum Metallic Tri-Coat
303A, 6-Speed SelectShift Automatic, 17" Aluminum wheels, Luxury Package,
Parking Technology, Navigation, Winter Package
---replaced by---
Chevy Volt 2014, White Diamond, Luxury Package, S1, Navigation.
VOLDAR is offline
Old 06-19-2012, 11:08 PM   #368
Kaaru
Kaaru's Avatar
Fan#: 96763
What I Drive: '12 Oxford Wh. SEL Sedan 28/07/2011
FF Reputation: 1 Kaaru Good Standing Member
Thats a bummer. My 12B37 FSA changed the transmission of my SEL and now it's a different animal. Very fun to drive. Feel like Gran'pa? it's buttery smooth. Feel like havin' fun, it's way more responsive. Also, we kind of have a little heat wave going on here up north (anything above 30° Celcius 3 days in a row is a heat wave for us ) and my tranny works perfectly, even in near 30°ish temp.
They only thing that bugs me a little is comming out of a 90° turn when you drive in ''D'' and throtlle back on, there is somekind of lag when you drive a bit more agressively. I followed some advice I found on this forum and now shift to ''S'' when I'm about to take a 90° turn and it rips tru the corner.
If you take the 90° turn in a regular way, in ''D'' and accelerate normally out of it, everything is fine, well, at least for me. I hope you'll be able to have this corrected as I now enjoy my SEL waaaay more than before. I hope it'll last.
Kaaru is offline
Old 06-20-2012, 12:05 AM   #369
AmishGuy91
Fan#: 85045
No you're definitely right. There's absolutely nothing wrong with the transmission. Ford just releases a new update for it every few months just for the fun of it.
Old 06-20-2012, 05:28 AM   #370
VOLDAR
VOLDAR's Avatar
Fan#: 90444
Correct me if I am wrong, please. I didn't say everything is perfect, I said that I didn't see a revert to what it was before the update. And I hardly can imagine this, when we are talking about a change in the program of the PCM and TCM. Can you explain how something that's been programmed to act different, can be reverted to something that doesn't exist anymore? It's like saying "I updated to MSOffice 2007, but after a while, it reverted to MSOffice 2003". Doesn't make sense for me. But maybe it's just me.
---replaced by---
VOLDAR is offline
