Go Back   Focus Fanatics > Model Specific Discussions > MK3 Focus
Old 05-07-2012, 05:56 PM   #181
JSR84
JSR84's Avatar
Fan#: 87788
What I Drive: 2008 MazdaSpeed 3
FF Reputation: 1 JSR84 Good Standing Member
Good info ChrisRo!
2008 Victory Red MazdaSpeed 3 - Not stock and self tuned.
2012 Sterling Gray Focus Ti - K&N.
Smashing Internet ignorance one person at a time.
JSR84 is offline
Old 05-07-2012, 07:57 PM   #182
Kabigon
Fan#: 88299
FF Reputation: 5 Kabigon Good Standing Member
Originally Posted by ChrisRo View Post
The stoich itself is a set value in the PCM at 14.079, but the car itself won't actually know what fuel it has in the tank. Since ethanol is a regulated deal, it just makes sense to include that in at least US calibrations.
The only thing it knows is the quality of the fuel in terms of adaptive spark and knock sensors. If it's 87 octane, it's not going to be aggressive as if you fill with 93 octane. The knock sensor strategy is intelligent enough to add/subtract based on audible feedback.
It also will know the commanded and actual lambdas. So, the car just needs a proper lambda, and needs knock sensors that can add/remove timing based on fuel quality. In those terms, yes - it will know the fuel quality.
The proper lambda for E85 and the proper lambda for 100% gasoline, for a given car/mods, will be the same. If that lambda too lean or too rich for gasoline, it's going to be too lean or too rich for E85. The only difference is when you speak about it in terms of air/fuel ratio. So really, the car doesn't need to know what fuel is in it. Make sense?
Hope this helps!
Here is some interesting reading on this subject:
In order to maintain proper fuel control, the PCM strategy needs to know the stoichiometric Air/Fuel Ratio for use in the fuel pulse width equation. On pre-2000 MY flex fuel vehicles, the percent alcohol in the fuel was determined by reading the output of the Flex fuel Sensor. The percent alcohol was stored in a register called Percent Methanol (PM). Although current alcohol-blended fuels only include ethanol, the percent methanol nomenclature has persisted. On 2000 MY and later vehicles, the Flex Fuel Sensor has been deleted and PM is inferred. The strategy to infer the correct A/F Ratio (AFR) relies on the oxygen sensor input to maintain stoichiometry after vehicle refueling occurs.
http://www.motorcraftservice.com/vdi.../OBDSM1202.pdf
(see pages 62-63)
Kabigon is offline
Old 05-07-2012, 08:21 PM   #183
ChrisRo
ChrisRo's Avatar
Fan#: 98578
What I Drive: 2012 White Platinum Focus SEL w/MFT
FF Reputation: 1 ChrisRo Good Standing Member
(see pages 62-63)
Good read. So what I'm saying sounds like it really applies to 2000 MY and up. However, wideband data only became available in most Ford models over the last 3 MY's, and as little as 1 MY in this case. So, lambda wasn't available.
That's interesting. The tough thing is that I've never actually seen the logic they're claiming in any PCM codes. This is probably because I never tune flex vehicles and always tune gasoline, E10 or E85.
I need to dive into a flex fuel PCM code.
ChrisRo is offline
Old 05-07-2012, 08:59 PM   #184
cessna1
Fan#: 97921
What I Drive: 2012 Red Candy Sedan
FF Reputation: 1 cessna1 Good Standing Member
Actually my 2001 Taurus still had a sensor made by Siemens that measured the ethanol blend in the tank. Pretty much figured changes out immediately.
cessna1 is offline
Old 05-07-2012, 10:33 PM   #185
TORQUERULES
The Professor
TORQUERULES's Avatar
Fan#: 1083
What I Drive: '12 Black SEL 302A; '87 'Stang
FF Reputation: 9 TORQUERULES Good Standing Member
Thumbs up
I can guaruntee that they wouldn't put a wideband sensor in the car and not use it. Coyote Mustangs still need tuning, even though the wideband may be adjusting for additional mods. That explanation is my post before this. However, you're absolutely right - there is correction going on with the widebands (or wideband in this case) and it does allow the car to have a little bit of "wiggle room" to mod without NEEDING a tune to hit targeted air/fuel ratio (which comes from the Desired Lambda at WOT table within the tune). Need a tune and should have a tune, is where it gets tricky.
The factory wideband sensors on these are extremely accurate, and we actually believe them as much as some of our lab equiptment. We've tested it back-to-back with Dynojet Wideband Commander, AFM1000, and UEGO's (junk). They're very accurate.
Your last paragraph is exactly right.
I agree... Good tuning is necessary, but at least Ford has given us some wiggle room again. Almost like a higher tech revival of the old A9L EEC IV 5.0 HO processor days. :-)
Sonic's MK3 Crew #5
I just wish manufacturers would quit trying to make magazine types, hipster douches, and librarians happy and give us the damn car the way the engineers intended.
TORQUERULES is offline
Old 05-08-2012, 12:26 AM   #186
Ulf Wafflestein
Fan#: 96259
What I Drive: 2012 Sonic Blue SE w/ Sport Pack
FF Reputation: 0 Ulf Wafflestein Newbie
Originally Posted by 1turbofocus View Post
Only CL = Closed Loop fuel uses the front o2 for fueling , OL = Open Loop uses the base fuel tables and no o2 for WOT fueling , If you go WOT then you are using your OL fueling , its more what your trying to log with then your not going OL
Then your to rich and loosing some power/torque
Who did your tuning
You aren't local so I don't feel bad for calling you an idiot for not knowing grammar. Come on man, don't make yourself look like such a dullard.
Ulf Wafflestein is offline
Old 05-08-2012, 01:54 AM   #187
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
FF Reputation: 16 Sonic_HedgeHog Great Standing Member
Yo Noob...
Learn your place and follow forum rules before throwing daggers.
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is online now
Old 05-08-2012, 04:41 AM   #188
twoblue
twoblue's Avatar
Fan#: 97624
What I Drive: 2012 Blue Candy SE Sport/Wint 203A
FF Reputation: 1 twoblue Good Standing Member
(see pages 62-63)
Anyone remember the Super Stallion concept/show car it was flex fuel and I believe had the system described above.
2006 Windveil Blue Mustang GT
2012 Blue Candy SE sedan
twoblue is offline
Old 05-08-2012, 07:31 AM   #189
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (15)
Learn your place boy. Now go sit in the corner and think of what you did.
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is offline
