Finally dynoing the Focus 5/2/12 - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2012, 12:42 AM   #131
Kabigon
Fan#: 88299
Points 4,377, Level 42
Points: 4,377, Level: 42 Points: 4,377, Level: 42 Points: 4,377, Level: 42
Level Up 14% Completed
Forum Activity 9%
FF Reputation: 11 Kabigon Great Standing Member
I did this log earlier this evening.
0~2 seconds: Steady throttle in 2nd gear. A/F (commanded and actual) is mid to high 14's as expected.
2~10 seconds: WOT, fuel rail pressure goes up to 2000+, A/F (commanded and actual) are in the mid 12's, fuel system remains in closed loop.
10~19 seconds: Foot off the throttle, A/F actual off the scale because of fuel cutoff, fuel system is open loop.
Kabigon is online now
Old 05-05-2012, 12:45 AM   #132
JSR84
JSR84's Avatar
Fan#: 87788
What I Drive: 2008 MazdaSpeed 3
FF Reputation: 1 JSR84 Good Standing Member
2~10 seconds: WOT, fuel rail pressure goes up to 2000+, A/F (commanded and actual) are in the mid 12's, fuel system is closed loop.
You need to figure out a way to post spread sheets, those graphs are vertically useless.
Something like this. http://dl.dropbox.com/u/64314401/4th%20Gear%20WOT.xlsx
2008 Victory Red MazdaSpeed 3 - Not stock and self tuned.
2012 Sterling Gray Focus Ti - K&N.
Smashing Internet ignorance one person at a time.
JSR84 is offline
Old 05-05-2012, 12:50 AM   #133
Kabigon
Fan#: 88299
Forum Activity 9%
Originally Posted by 1turbofocus View Post
To answer your question in Open Loop where AF is needed (only time a wide band AF gauge is needed) no the OBDII port will not show you AF
What does this apply to?
On a Mazdaspeed 3 (for example), when the PCM transitions to OL at WOT, the OBD data for equivalence ratio is valid (you can see the A/F hitting ~10:1).
If valid data is not output, then what is?
Old 05-05-2012, 12:56 AM   #134
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,075, Level 45
Points: 5,075, Level: 45 Points: 5,075, Level: 45 Points: 5,075, Level: 45
Level Up 63% Completed
FF Reputation: 4 Ox-y-GenIII Good Standing Member
Kabigon, then your readings show the same results as mine basically. 14+ when not full throttle, 12.0+ when wot.
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 05-05-2012, 01:11 AM   #135
Kabigon
Fan#: 88299
Forum Activity 9%
Only CL = Closed Loop fuel uses the front o2 for fueling , OL = Open Loop uses the base fuel tables and no o2 for WOT fueling , If you go WOT then you are using your OL fueling , its more what your trying to log with then your not going OL
Are you saying that the standard mode 1 PID data for fuel system status is invalid on the 2012 Focus? That's what most monitoring devices look at.
Then your to rich and loosing some power/torque
That's how it came from the factory. In any case, it's nothing to worry about.
Who did your tuning
My car is stock. I don't think that I ever implied otherwise.
When I said "Could this be attributed to PCM calibration differences or...?", I meant different PCM calibrations that came from Ford.
Old 05-05-2012, 01:20 AM   #136
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 18,690, Level 86
Points: 18,690, Level: 86 Points: 18,690, Level: 86 Points: 18,690, Level: 86
Level Up 68% Completed
Forum Activity 79%
Activity: 79% Activity: 79% Activity: 79%
FF Reputation: 43 Duffman355 Great Standing Member
one last time, I would like to thank Ox-y-GenIII for his results in reassuring (which I had no doubt about FS Werks claims to ~167 bhp) form this type of modded focus.
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 05-05-2012, 01:29 AM   #137
Kabigon
Fan#: 88299
Forum Activity 9%
Sorry, I haven't really polished this for public consumption. The graph was intended for the purpose of "seeing what's going on" without the need for exact numbers.
I'm don't know if it's obvious as to how to read the graph.
For example, the range for commanded AFR (green) is 10 (bottom) to 20 (top), so each major division is 1 and each minor division is 0.5.
The file created during logging contains raw CAN data and timestamps so it is possible to convert it to CSV. I will probably do this in the near future.
Old 05-05-2012, 01:31 AM   #138
Kabigon
Fan#: 88299
Forum Activity 9%
That's good to know. Your car isn't PZEV, is it?
I'm surprised that more people don't monitor/log OBD data (especially considering that the 2012 has a wideband O2 sensor).
Old 05-05-2012, 02:27 AM   #139
mustang0
mustang0's Avatar
Fan#: 96079
What I Drive: 2012 Blue Candy SE HB Sport Package
Points 732, Level 14
Points: 732, Level: 14 Points: 732, Level: 14 Points: 732, Level: 14
Level Up 32% Completed
FF Reputation: 1 mustang0 Good Standing Member
Since you mentioned this, does anybody know if the Torque APP for smart phones able to do this? If not tell us the best way to go about this, Thanks.
65 Racestang 96 Mustang 2012 Focus SE HB Sport Pac 5 speed man. NewMission Cold Air, lunchbox Delete,Custom 3" Magnaflow exhaust, Steeda Rear Sway Bar, Steeda STS,Axis wheels, Blox shift knob,Focus elecrtic RMM, Injected 93 Tune V1 176HP 152Torque
mustang0 is online now
Old 05-05-2012, 02:28 AM   #140
rubsterob
Fan#: 90929
What I Drive: 2012 race red hatch
FF Reputation: 1 rubsterob Good Standing Member
youre all speaking a foreign language to me. can some one explain what open lop and closed loop is referring to?
rubsterob is offline
