Alternative to Ford fuel pumps? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2012, 08:51 PM   #1
car46999
Fan#: 98177
What I Drive: 91 laser
FF Reputation: 1 car46999 Good Standing Member
So I am working on a 2000 Ford Focus with the 2.0L Zetec.
Here is the info that I have gathered:
It will start with the help of fuel into the intake, will idle rough, then die if the gas pedal is pressed.
It is throwing a P1237 code, and the OBDII reports 0-6 psi of fuel pressure.
I checked for 12v out of the FPDM pins 10 and 3 (I think this is the fuel pump power ??), and had ~12v when key in on.
I do not hear the pump come on, and the previous owner reported random stalling.
My questions:
I think this is the original pump, has any one modified the old FDM to improve its performance? Walbro sells a pump, but my understanding is that it there is a design issue that causes issues...
Any after-market FDM as reliable as the OEM, but cost less?
car46999 is offline
Old 04-24-2012, 08:57 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,719, Level 94
Points: 23,719, Level: 94 Points: 23,719, Level: 94 Points: 23,719, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 12%
airtex.
mikebontoft is online now
Old 04-24-2012, 09:31 PM   #3
car46999
Fan#: 98177
a
Mike, Airtex been good for you? How many miles?
any one used one of these? CARTER Part # P75047M
Also: Extended Coverage Program 03N01 lists part number 1M5Z-9H307-AC as the "upgrade Ford FDM.
This is the FDM that has the springs and rods that provide pressure to hold to bottom of the tank?
If I were looking for a used pump, which years/ models have these pumps?
car46999 is offline
Old 04-24-2012, 10:09 PM   #4
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 12%
Hey sorry for the short message earlier, was on my way out.
I'd just replace the pump instead of the module to be honest. I have both sold and been a professional installer of airtex pumps. Carter has been rebranded as Airtex, btw. If you're looking at Carter its probably through oreillys.
As for used pumps I don't like to but... damn it I'm using one I pulled from the junkyard on my boosted car (looked new, strainer hadn't touched gas.)
Old 04-25-2012, 02:12 AM   #5
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Why the questions about quality and then trying to score a USED part? Seems rather oxymoronic to me.
amc49 is online now
Old 04-25-2012, 02:13 AM   #6
dirtbrown
what it be like
dirtbrown's Avatar
Fan#: 40563
What I Drive: 03 EAP
Points 41,796, Level 100
Points: 41,796, Level: 100 Points: 41,796, Level: 100 Points: 41,796, Level: 100
Level Up 0% Completed
Forum Activity 8%
FF Reputation: 27 dirtbrown Great Standing Member
I have a Carter Pump in my SVT
dirtbrown is offline
Old 04-25-2012, 06:00 AM   #7
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Go check out our Vendor Deals, Group Buys, and Special Discounts thread for the latest Rock Auto discount code. It's only 5%, but it helps. Get your fuel pump from them, and compare the part number to one you'd purchase elsewhere just to double check. Typically you save $100 or so. I'd also get any other items you might need at the same time because their prices on spark plugs and windshield wipers are ridiculous: double plat plugs are like $3, and iridium is $5. Standard plugs are less than a dollar, fuel filters are $2, etc.
Just make sure that on the first page, where you enter the manufacturer, you uncheck all the European flags at the top of the list. That way you don't end up accidentally ordering a Euro part.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-25-2012, 02:25 PM   #8
defektes
Fan#: 84501
What I Drive: 2001 Black ZTS
FF Reputation: 3 defektes Good Standing Member
Ive had bad luck with aftermarket pumps in all my cars. I'd strongly suggest go with OEM, and toss a new fuel filter in and forget about it. You really don't want to have to take it all apart again.
Update from dealer:
Service advisor received a letter from Ford corp "engineer". Letter "email" states no reverse is from motor swap install. Ford engineer recommends putting original motor back in.
defektes is offline
Old 04-25-2012, 03:49 PM   #9
car46999
Fan#: 98177
pumps
I would prefer a new Ford part over a new aftermarket, after reading that some people report issues with aftermarket FDMs. But $250 for a new Ford FDM is a bit ridiculous. ($250 is about 85% of what I paid for the car)
If I find a used Ford FDM for less than aftermarket, that is likely what I will buy.
car46999 is offline
Old 04-25-2012, 04:29 PM   #10
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Well,
how long do you plan to keep the car?
how long do you expect a used pump to last? / how many will you have to replace per how long you wish to keep the car?
how long do the update pumps last?
cost/return?
I'm on an update pump. I have over 100K on it and not a single issue. I pull the pump at least once a year and replace the sock filter.
It's up to you what you're going to do, but IMO new Ford is the only reliable option.
121,000 members and still no sponsored racing.
iminhell is offline
