2012 intake question - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 06-12-2012, 07:42 AM   #21
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
FF Reputation: 46 dyn085 Great Standing Member
I also removed the snorkel and put a piece of bent aluminum in the bumper gap to push down the rubber flap that is attached to the radiator shroud. Others have cut the rubber completely. This gives the OEM inlet a ram-ish set up.
Some day I would like to fab an actual piece out of fiberglass to create an actual ram air.
dyn085 is online now
Old 06-12-2012, 08:20 AM   #22
lscrx
Fan#: 41668
What I Drive: 2012 Focus SE hatch 5mt
FF Reputation: 2 lscrx Good Standing Member
Why not add one of these?
Posted via FF Mobile
lscrx is offline
Old 06-12-2012, 08:21 AM   #23
Pretherius
Pretherius's Avatar
Fan#: 97062
What I Drive: 2012 SE Sedan 5-Spd Sterling Gray
FF Reputation: 1 Pretherius Good Standing Member
Do we have a consensus as to whether there are any significant negative effects to swapping to one of these intakes in terms of engine life? I would expect the less restrictive filter to let more crap into the engine (but you'd see this even if you just put a K&N into the stock air box, too). My concern is heightened further because this engine is direct-injected.
If this is really a safe mod, $250 for 10 whp is a damn no-brainer IMHO.
Pretherius is offline
Old 06-12-2012, 08:37 AM   #24
_RED_
Sonic's MK3 Crew #02
_RED_'s Avatar
Fan#: 10712
What I Drive: 2012 Focus SE sport
FF Reputation: 2 _RED_ Good Standing Member
This car and the mods are to new to know what the long term effects are.
Dyno numbers: 177hp/163tq
Mods: Steeda Intake, STS Kit, Rear sway bar, Lowering springs, Steeda RMM, Magnaflow catback, SCT Tune
Moderator: Third Generation Ford Focus, DURATEC Ti-VCT GDI Performance Chat & Florida regional section
_RED_ is online now
Old 06-12-2012, 08:41 AM   #25
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
If it's any consolation, I've used K&N cotton gauze filters or intake/filter combinations with the last 4 cars I've owned and racked up more than 150K miles on each of them. When I sold them, they were still in perfect running condition, were oil-tight (didn't burn significant oil) and didn't show signs of wear otherwise.
I have seen statements that a cotton gauze filter can increase engine wear due to contaminants by up to 10% over paper. This may or may not be true, and I think the actual estimate would vary greatly depending on the running environment of the engine. In other words, if I were driving in dry, dusty conditions a majority of the time, I might consider sticking with paper media. Otherwise, I have seen no reason for alarm.
I'm not sure why you would have heightened concern with a DI engine. Even if "crap" were to make it into your engine, it would be dry "crap" (not sticky like blow-by/PCV gases) and fly right past your valves and not stick to them. In other words, your DI engine should react to this "crap" in the same way a port-injected engine would, and show wear mostly on piston rings and cylinder walls.
Hatch Nation #90
TboneZX3 is offline
Old 06-12-2012, 08:48 AM   #26
Joey D
Joey D's Avatar
Fan#: 86391
What I Drive: 2012 Tuxedo Black Titanium 5-Dr
FF Reputation: 2 Joey D Good Standing Member
I doubt you'll see any engine problems with an intake. The only thing that would be bad is if you are using a dirty filter or if you drive through a really big puddle and flood the intake area.
Joey D is offline
Old 06-12-2012, 08:55 AM   #27
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Here is a well-designed (IMO) filtration test of various media: http://www.bobistheoilguy.com/airfilter/airtest3.htm
Filtration and flow are inversely proportional. You must be the judge as to whether the increase in flow is worth the decrease in filtration in your environment.
Hatch Nation #90
TboneZX3 is offline
Old 06-12-2012, 08:58 AM   #28
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Cotton gauze filter manufacturers (e.g. K&N) state that a filter of this type filters better as it gets dirty, but flow will be reduced. This is why their maintenance schedule is as high as 100K mile intervals. I don't see how reduced flow and increased filtering would be detrimental to the engine.
Hatch Nation #90
TboneZX3 is offline
Old 06-12-2012, 09:15 AM   #29
Pretherius
Pretherius's Avatar
Fan#: 97062
My reason--which admittedly could be unfounded--is that we don't have gas washing over the intake to clean stuff off. Some of the extra stuff that gets into the engine may not be inherently sticky but there is always humidity, and some of that stuff does get stuck to water into the air and then will be sucked into the intake... throttle, MAF, ports, intake valves. All I can do is speculate either way, sadly.
Yep, that's exactly the article I had in mind.
I'd be really interested to know then what we'd get out of tossing a K&N into the stock airbox. If it's worth 2 HP then meh, but if it's good for 6 or 7, that would be enough to make me happy.
Old 06-12-2012, 09:21 AM   #30
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Throttle and MAF should be a moot point when comparing the two, as they would work the same in a DI or port-injected engine. You might have a point about humidity and the ports intake valves, but I would certainly be more concerned about blowby/PCV gasses building up there than any miniscule dust that is making its way past the filter. Speculation though, as you mentioned...
Hatch Nation #90
TboneZX3 is offline
