High Idle - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-02-2012, 09:56 AM   #11
cyoun012
Fan#: 91345
What I Drive: 2005 Black ZX4 ST
FF Reputation: 1 cyoun012 Good Standing Member
I'm wondering if cleaning my Throttle Body just moved the gunk down into the IAC valve. I'm going to take it apart this weekend and try to clean it. I'm a rookie, so is there any advice out there so i don't it up?
cyoun012 is offline
Old 05-02-2012, 11:12 AM   #12
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,833, Level 59
Points: 7,833, Level: 59 Points: 7,833, Level: 59 Points: 7,833, Level: 59
Level Up 42% Completed
Forum Activity 19%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
The IAC valve is pretty difficult to get to and some on here I've seen say that it was easier to get to some of the bolts from the bottom .
Also might want to check for a cracked or split vacuum line too.
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is offline
Old 05-02-2012, 12:44 PM   #13
ligardner
Fan#: 32567
What I Drive: 02 Focus LX; 05 Focus ZX4; 02 Wago
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 ligardner Good Standing Member
I just went through the process of removing and cleaning a problem IAC valve, and then having to do it again three days later (!!) when the car developed a persistently high idle causing me to buy a new IAC valve.
The trick to removing w/o tearing off the intake manifold is to jack up the care fairly high so that you can reach up to where that little bugger sits crammed in nicely among other parts. there is just enogh room to get an 8mm ratcheting box wrench on the two little bolts holding the IAC on.
But the harder trick is fumbling with your new IAC to orient it so you can get these tiny bolts back in their holes. Just take a deep breath--you can do this. Its possible somebody with tiny hands could reach down to pin it in place while you search for the bolt holes. i did the replacement at 10:00 last night without a helper.
DEFINITELY take off your neg. battery cable and let the car sit for a while before you start it up.
ligardner is offline
Old 05-02-2012, 02:32 PM   #14
dperry
Fan#: 97914
What I Drive: 2006 Light Tundra Metallic Focus
FF Reputation: 1 dperry Good Standing Member
I've tried cleaning my IAC valve twice with no luck, so I guess I'm wondering if I should just replace it to see if that fixes the problem. I just don't want to part with $100 or so just to get the same idle I currently have.
dperry is offline
Old 05-13-2012, 09:52 AM   #15
wintrjr
Fan#: 98312
What I Drive: 2006 Blue ZX3 2.0
Points 8, Level 1
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Level Up 15% Completed
FF Reputation: 1 wintrjr Good Standing Member
An update on my high idle problem . . . after about 1.5 - 2 weeks my idle is now starting to return to normal. The RPMs are coming down quicker and coming down to 750. It appears to take time to return to normal and it is running much better now. I probably didn't need to replace my AIC valve . . . oh well.
I also had to replace my throttle cable this weekend ?!?!?! I've never heard of a throttle cable going bad. Mine frayed between the gas peddle and the firewall and wouldn't allow the throttle to return to idle. I limped it home, got the part (dealer part only $107) and replaced it in about 5 minutes. Back on the road.
wintrjr is offline
Old 05-15-2012, 10:57 AM   #16
cyoun012
Fan#: 91345
bump. any results? i cleaned out throttle body and IAC. now it sounds worse, and the idling problem is the same. still popping the p0507 code. i'm going to replace iac valve this weekend. Do i really have to change out the gaskets for TB and IAC?
cyoun012 is offline
Old 12-02-2012, 08:17 PM   #17
Hoops
Fan#: 15163
FF Reputation: 1 Hoops Good Standing Member
Any updates to this issue? My 2005 is having this same issue after cleaning the throttle body. Currently throwing code po507 with high idle.
2009 Ford Focus SES 5spd coupe
2009 Ford Fusion SEL
2007 Ford Mustang GT 5spd
1994 Ford Ranger XLT 4x4
Hoops is offline
Old 12-03-2012, 09:54 AM   #18
wintrjr
Fan#: 98312
Points 8, Level 1
OK, an update on my high idle. My car is back to normal and running great!!!! All I can say is that run time and mileage was what worked for my car . . . more time than I thought it would take.
On a side note, about a month ago, I came across a guy in a new V6 Camaro with a stick that was making his left hand turn so, so slow. When we straightened out I got in the right lane and started running my '06 ZX3 (111,000 miles BTW) thru the gears and the dude in the Camaro hit it at about the same time. Up to about 60 mph. I stayed right with him, about 1 car length behind . . . after that I started catching this Camaro. At about 95 mph I was along side of this guy, passing him and laughing uncontrollably. Now, I was running my little ZX3 pretty hard but so was the Camaro, I could really hear him hitting the gears and high RPMs. Now, I know that it was only a V6 but supposedly 310 horsepower and he was driving it good . . . . I'd have taken it back to the Chevy dealer and demanded my money back after getting beaten by a Focus. Needless to say . . . this was a fun day!!!!!
wintrjr is offline
Old 12-03-2012, 04:09 PM   #19
bones33
Fan#: 105414
What I Drive: '05 Silver ST
Points 378, Level 7
Points: 378, Level: 7 Points: 378, Level: 7 Points: 378, Level: 7
Level Up 56% Completed
FF Reputation: 1 bones33 Good Standing Member
The aforementioned idle issues can also be caused by a thermostat stuck open. Happened just as described to me. The stock gauge reads normal and doesn't change from about 143* to at least 215* so it is not a good indicator of engine temperature. Mine ran from the 140s to the 180s erratically when the thermostat was stuck. It should normally operate at least 192* or so.
If you don't have a PCM reader (I use a scangauge) you can get a good idea if your thermostat is stuck open this way: If your heater is not as potent as it should be and you have idle issues, replace your thermostat. They are about $26 and though fiddly to change, not technically difficult. Small hands would be helpful but not required. I realistically spent about 3 hours doing it, but I'm kinda slow.
For me, after changing out the thermostat it cleared up the idle issues and I picked up about 3 mpg consistently over 3 tanks.
bones33 is offline
Old 05-18-2014, 12:18 AM   #20
RugbyDump
Fan#: 163946
FF Reputation: 1 RugbyDump Good Standing Member
High Idle Issue
Hello,
I am new here. Just got a 2005 Focus ST ZX4 yesterday. It has had the engine replaced with a junkyard motor with 100k on it. Car has 143 on the odometer.
Anyway, I am having the same issues described here with the high idle between shifts and for several seconds at redlights. When I was test driving the car, the CEL came on and it spit out a code for IAC. The seller owned a shop so he had AZ deliver one right away and without even installing it, I made the deal.
Put it on yesterday evening and now the idle is generally high. I say generally because it will occasionally actually drop so low in idle, when I first start it up, that it has actually died twice on me. But then it usually gets going and it hangs between shifts and for several seconds at red lights. I am now getting the P0507 code I think is what it was. Remember, this is after having just replaced the IAC valve.
I read the suggestion about the thermostat and I will definitely try one tomorrow. In the days ahead, I will be driving a lot more so if that proves to be the solution, all will be well. Thirdly, I know to check my throttle cable tomorrow as well. Does anyone have any other suggestions?
Thanks so much! I hope to be part of this group for a long time. Love my Focus!
Dump
RugbyDump is offline
