2009 Ford Focus - Rear Brake Drums - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-17-2012, 06:32 PM   #1
hyperspunk
hyperspunk's Avatar
Fan#: 64939
What I Drive: 2009 Blue Ford Focus SE
FF Reputation: 1 hyperspunk Good Standing Member
Red face 2009 Ford Focus - Rear Brake Drums
Hello,
Does anyone have instructions on how to remove the rear brake drums so I could replace the brake shoes? Thank you.
_____________________________________
Hyper
hyperspunk is offline
Old 04-17-2012, 06:41 PM   #2
matz2453
matz2453's Avatar
Fan#: 88492
What I Drive: 2010 black ses, 2012 Mitsu
FF Reputation: 4 matz2453 Good Standing Member
you got to take the axle nut off, which is behind the silver cap on the drum and then hit it with a hammer
SES #031
matz2453 is offline
Old 04-17-2012, 06:48 PM   #3
hyperspunk
hyperspunk's Avatar
Fan#: 64939
THANK YOU SO MUCH ... I will give it a try. Just one more thing if you don't mind, what size socket is it? Just to make sure I'm unscrewing the right nut. I'm a beginner here with the Focus.
Old 04-17-2012, 07:12 PM   #4
matz2453
matz2453's Avatar
Fan#: 88492
I'm pretty sure its a 30mm, or somwhere around that lol
SES #031
matz2453 is offline
Old 04-20-2012, 11:01 AM   #5
hyperspunk
hyperspunk's Avatar
Fan#: 64939
It didn't work. A friend told me that it might have "clips" that are hard to find that keep them in place. Does anyone know where these clips might be? A picture if possible. Thanks.
Old 04-20-2012, 12:13 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,326, Level 75
Points: 13,326, Level: 75 Points: 13,326, Level: 75 Points: 13,326, Level: 75
Level Up 19% Completed
Forum Activity 99%
You might want to read some of the old drum brake threads for the details, but here's a "primer" on them...
That large nut holds the bearings on the stub axle, thereby keeping the drum in place. It needs a LARGE torque value when installed, & is SUPPOSED to be replaced whenever removed...
Bearing assembly is pressed into the hub, so it can't be renewed without special tools (buy a new assembly, or pay for it to be done).
Drums are typically hard to remove because of wear & rust. The contact area wears, and the edge rusts, creating a ridge that grabs the shoes when you try to remove it.
Most brakes these days don't have a method to manually adjust the shoes back from the drums, so shoes & hardware are typically damaged when drums are removed - so don't pull drums without new shoes & a hdwe. packet in hand... If someone "adjusted" the rear brakes by changing the E-brake cable adjustment, that needs to be loosened as well.
On the Focus, the entire stub axle, bearing & drum assembly can be removed from behind by removing the four nuts that hold it on - some find this easier than removing the axle nut, replacing & retorquing it.
No "hidden clips" holding the drum, your friend may have been thinking of the 'clips" that hold the brake shoes in position - which often are damaged when forcing the drum off of the shoes.
Drums at the rear seldom need service before QUITE a few miles have passed, and at that point I'd actually suggest a complete replacement so you don't need to dive in there again for a LONG time...
Drums with new bearings, new axle nut, new shoes and a replacement hdwe. kit.
Ford shoes might be worth it as well, due to many reports of squeaks & squeals when using some others...
Luck!
sailor is online now
