Replaced rear 02, still throwing CEL codes? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 04-17-2012, 01:50 PM   #1
kkeiran
Fan#: 60322
What I Drive: 2003 Silver SVT
FF Reputation: 1 kkeiran Good Standing Member
Question Replaced rear 02, still throwing CEL codes?
2003 Ford Focus SVT, 2 Door Hatchback.
I replaced a bad 02 sensor this morning (it was bent against pipe above) which was throwing codes P0141 & P0136. I'm usually not concerned too much about the rear sensor as my car eats through them like candy anyhow, but I need to get it to stop throwing the CEL codes so I can pass inspection. Usually when I pop in a new sensor, everything is fine at least for a while (months?)... definitely enough time to run through inspection.
Well this year things aren't going as planned. I know Bosch aren't the best quality, but it's all we have locally and they've always worked fine at least for a bit. Anyway, I installed a new one (rear, sensor 2) and cleared the code, but after driving cycle the CEL turned on again. This time it as just P0141. I double checked the installation and everything looked fine... tight, reconnected again, and no obvious signs of bad wires on either end. I clear the code again and after this drive cycle P0141 is gone, but now it's showing just P0136. :/
Is this anything else I should try before cutting my loss and assuming I got a faulty sensor? Would a bad fuse somewhere cause any of this?
I need to pass inspection soon, lol.
Thanks for your time and help.
kkeiran is offline
Old 04-17-2012, 02:25 PM   #2
kkeiran
Fan#: 60322
Heh, I just checked the codes again and now it's throwing P0141 (again) AND P0325. Could an 02 sensor issue trigger P0325 (Knock Sensor Circuit Malfunction)? :/
kkeiran is offline
Old 04-17-2012, 03:22 PM   #3
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
if they are all running on the same circuit (Don't have a diagram handy) you may have a wire or sensor shorting to ground. These circuits use a current limiter so the wires will not burn up.... the problem with that is the part in the circuit that is bad will use all of the amperage and all of the GOOD sensors will throw codes. You need to take a look at that. I may grab a diagram in a minute here... I like these kind of problems.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 04-17-2012, 03:32 PM   #4
kkeiran
Fan#: 60322
Where should I look, back under the car where I installed the sensor? Or we talking about something else? I can swap out 02 sensors, but other than that I'm a bit of a novice working on my car.
Thanks!
kkeiran is offline
Old 04-17-2012, 03:40 PM   #5
mikebontoft
Toxx
Fan#: 58647
that's fine..... I'll pull up some diagrams and see if I can't get an idea at least. I would check the wires from the other side though. Something is a bit odd though, that much I know.
There is a possibility that if the sensor is reading a low voltage, the vehicle itself may be running lean if it can't adjust enough for fuel and the engine is knocking because of it but.... yeah.
Old 04-17-2012, 06:37 PM   #6
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
FF Reputation: 2 Gettysburg150 Good Standing Member
What modifications does your vehicle have?
Gettysburg150 is offline
Old 04-17-2012, 07:06 PM   #7
kkeiran
Fan#: 60322
It's a 2003 Ford Focus SVT (2door/hatchback). I haven't done any modifications.
kkeiran is offline
Old 04-17-2012, 07:08 PM   #8
kkeiran
Fan#: 60322
Assuming it's an oxygen sensor related problem, might this allow me to at least pass inspection if I'm unable to resolve the issue before my deadline? http://focus.c-f-m.com/bbko2cheaterforfocus.aspx
kkeiran is offline
Old 04-17-2012, 08:39 PM   #9
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Could it be a resistance issue with the replacement sensor itself? Different brands use different resistances.
Mile30 is online now
Old 04-17-2012, 09:28 PM   #10
kkeiran
Fan#: 60322
Same brand & part # I've always used. :(
kkeiran is offline
