Old 10-25-2004, 08:36 AM   #1
baj
Fan#: 14762
FF Reputation: 1 baj Good Standing Member
Help with fog and break lights on RS focus
Hi all i am new to the Focus scene so i am sorry if this has been answered before.
My friend is having a problem with the break and fog lights on his RS focus.
When the break is pressed the fog lights come on with the break lights. If you turn on the fog light the breaks come on too.
Does any one have any ideas what could be causing this. i have checked all the fuses and every thing seems fine.
He said that this happend a little while after fitting a new stereo. i have removed the stereo but it is still doing the same thing.
Has any one got any ideas or know where i can get wiring diagrams from?
Thanks in advance
Baj
baj is offline
Fan#: 1
Old 10-25-2004, 08:41 AM   #2
knightriderzx3
knightriderzx3's Avatar
Fan#: 274
What I Drive: 2008 Black SRT4
FF Reputation: 2 knightriderzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
not really sure, but the first thing that i would check would be the fuse panel. look to see if there is something connecting the 2 fuses by accident. if not, take it in to the dealership.
cheers.
ractive short ram ai, 65mm throttle body, 9mm ford racing spark cables, pacesetter header, Focus Central UDP
knightriderzx3 is offline
Old 10-25-2004, 08:45 AM   #3
baj
Fan#: 14762
I did sugest taking back to the dealer but he said it has been chipped along with other work and if he takes it back it would void the warrenty on the car. just wanted to see if i could resolve the problem before going back to the dealers.
I even removed the fog fuse but they still come on when you press the breaks.
baj is offline
Old 10-25-2004, 08:50 AM   #4
knightriderzx3
Fan#: 274
take the chip out and see if that works. if so, get the chip re-burned. if you can't take it out, call the chip manufacturers and ask them if they've ever encountered this problem before.
Old 10-25-2004, 08:53 AM   #5
baj
Fan#: 14762
would the chip cause such a strange problem??? i am new to the ford scene but i would not of thought this would cause the problem.
baj is offline
Old 10-25-2004, 09:01 AM   #6
knightriderzx3
Fan#: 274
well if the only thing that was done to it electronic wise was the chip, it would be a natural assumption. mind you i'm not sure if the ECU has anything to do with the lights. what happens when you pull the fuse for the brake lights? do they still work? what happens when you pull both fuses? the more things like that that you try, the closer you get to the answer.
Old 10-25-2004, 09:03 AM   #7
baj
Fan#: 14762
i will try and remove both fuses and see what happens. do you know where i can find some wiring diagrams on line???
Thanks
Baj
baj is offline
Old 10-25-2004, 09:11 AM   #8
knightriderzx3
Fan#: 274
no, sorry i don't. but if i do, i'll drop you a line.
Old 11-19-2007, 12:59 PM   #9
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
FF Reputation: 17 nilskje Great Standing Member
By fog lights, you mean 2 at the front and 1 at the back? Or only the back , or only front.. Need to know to chk out the wiring diagram. Guess the stereo install was also an amp in the trunk? (shorted cables in trunk).
nilskje is offline
Old 11-19-2007, 06:46 PM   #10
knightriderzx3
Fan#: 274
Guy, this post is 3 years old.
Similar Threads
How To: SVT Fog Light Protection w/Lexan ..:: sleestak ::.. Focus SVT 23 03-22-2013 03:43 PM
iminhell's FS thread, parts & lots of Focus toys (56K warning) iminhell Archive 30 10-08-2009 02:47 PM
2005 Fog light inserts? Godzukidan MK1 Focus 2 03-30-2008 05:22 PM
**Vote for May ROTM** Chick ROTM Showcase & Voting Center 4 05-11-2005 12:10 AM
how to undo the splash guard plastic to get to fog lights J-Dawg MK1 Focus 5 01-04-2005 04:38 PM
