sct 3000 x3:what's the best drag launch rpm - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-17-2012, 11:01 AM   #1
Royce01
Royce01's Avatar
Fan#: 93858
What I Drive: 2001 Amazon Green SE 4dr
Points 925, Level 16
Points: 925, Level: 16 Points: 925, Level: 16 Points: 925, Level: 16
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
FF Reputation: 1 Royce01 Good Standing Member
hey, Im thinking of getting a tune for my SPI focus. there are a few things that confuse me though.I want to make it quicker(maybe even drop a second off my 1/4 time if possible) so i have some questions
1.) what is the the best desired drag launch rpm for the fastest 0-60 time.
2.) what's the best desired temp for cooling fan activation
3.) Is it good to have the alternator disabled at WOT
4.) what should i put as the desired rev limiter and idle rpm.
5.) should i raise the fuel pressure.
The programer is SCT 3000 x3. as far as upgrades I have a Magnaflow cat and catback exhuast. A spectre air intake cone filter. Brembo brakes and K-sport rally suspension. my tire/rim size remains the same. My car also has 113k miles on it. I also plan to put a mustang TB on it this summer when I go to buy the ecu upgrades.
Thanks
a $15,000 honda and a $500 exhaust doesn't make you a street racer!
Sedan Revolution #223
Rally Revolution #223
132bhp 147ft/lb tq
Royce01 is offline
Old 04-17-2012, 06:33 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
RPM depends on grip, or lack of.
I launch off idle and still have traction issues,,, really need better tires.
But per math, the higher the RPM you can launch at the better. The reason is distance traveled vs RPM. A higher RPM naturally moves the car further faster. To add to that the sooner you can get to the next gear the better, same deal with distance over time.
Do not disable the alternator @ WOT. Yes it frees a bit of HP, but there are things that are voltage dependent that can be affected when the voltage falls off.
Fuel pressure is just fine where it is.
Fan temp is pretty good stock also. You can drop it a little if you wish, but you won't see any power from it, only the fan running more.
Rev/Idle, that's totally up to you. But I don't see any reason the stock idle RPM needs to be changed. Rev limit, you might be able to go a bit higher but I wouldn't go too wild unless you dyno the car and see if there is a need for it. But remember that valvetrain parts may need to be uprated if the RPM is extended.
OH, you're not playing dumb ...
iminhell is offline
Old 04-17-2012, 06:48 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,847, Level 100
Points: 51,847, Level: 100 Points: 51,847, Level: 100 Points: 51,847, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
I like to lower the fans from the 232 low speed / 240 high speed to the 190`s and 205 this helps with spark knock and you will see some performance gains lowering the engine temps this much , both safety and performance
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-18-2012, 03:06 PM   #4
Royce01
Royce01's Avatar
Fan#: 93858
Thanks you guys you were really helpful now I just gotta talk my parents into letting me buy it lol
132bhp 147ft/lb tq
Royce01 is offline
