Eagle Eyes Projector HID cutoff - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-17-2012, 03:38 AM   #1
Nicksterr
Fan#: 60824
What I Drive: 2008 Vista Blue Focus SES Sedan
Points 954, Level 16
Points: 954, Level: 16 Points: 954, Level: 16 Points: 954, Level: 16
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 Nicksterr Good Standing Member
Hi guys -
I put a DDM Tuning 55w HID kit into my Eagle Eyes projectors today, following the steps in the how-to thread for all connections and installing 3 washers behind the bulb lock plate/bracket (which was quite difficult as I had to dremel out some of the plastic that touches the side of the bracket in order to fasten it without losing all the washers in the process. I ended up just super gluing the washers together and that made it easier)
With that said, my cutoff turned out to be a bit funny.
Here are two pictures of my cutoff:
At about 10 feet:
At about 20-25 feet:
If you take a close look at the area within the red rectangle, you will notice a serious lack of light. This turns into a MASSIVE blind spot of zero light at the end of the light beam straight in front of me while driving. Currently, it's quite awful and much worse then driving with the halogens. I'm essentially just illuminating ditches and the pavement right in front of my car. It also looks like I'm going to have to aim my projectors a little higher since the install, but that's a separate issue.
Any thoughts?
Nicksterr is offline
Old 04-17-2012, 07:58 AM   #2
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
Points 6,542, Level 52
Points: 6,542, Level: 52 Points: 6,542, Level: 52 Points: 6,542, Level: 52
Level Up 96% Completed
FF Reputation: 20 Slammed_2.0 Great Standing Member
Buy-Sell-Trade Rating: (4)
Take off one washer on each side. The capsule is too far back
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
Old 04-17-2012, 09:50 AM   #3
Covmister
Covmister's Avatar
Fan#: 89659
What I Drive: 2001 white zx3
FF Reputation: 3 Covmister Good Standing Member
^^^^ agreed
In all reality it isnt fast at all, it didnt ever cost 250k, and it wont blow your girls panties off. that being said i drive a ford focus
Covmister is offline
Old 04-17-2012, 10:46 AM   #4
Slammed_2.0
Boosted HB.
Fan#: 84306
I have photos when I was messing with my bulb mount when I just had pnp HIDs.
I ended up shaving some one the factory housing to allow the capsule to sit like it was a halogen.
Old 04-17-2012, 01:19 PM   #5
SESRob
Fan#: 84340
What I Drive: 2009 Black Focus SES
Points 16, Level 1
Points: 16, Level: 1 Points: 16, Level: 1 Points: 16, Level: 1
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 1 SESRob Good Standing Member
Wow, I guess I'm lucky!? My HIDs went in the housing without modification and the cut-off is perfect! I do have the "step" on each side, but not a noticable "dark" area between the two lamp projections.
SESRob is offline
Old 04-17-2012, 03:08 PM   #6
Nicksterr
Fan#: 60824
Do you have the 2 or 3 screw backplate?
Old 04-17-2012, 04:13 PM   #7
SESRob
Fan#: 84340
Points 16, Level 1
I have the 2 screw backplate....the one with "issues". Lucky for me, mine wasn't an issue. If you want, I'll try to post some pictures later of my projection pattern.
SESRob is offline
Old 04-17-2012, 05:18 PM   #8
Nicksterr
Fan#: 60824
That would be great. I'm about to go out and remove my washers completely to see what that does. I'll report back tonight with new pictures.
Old 04-17-2012, 07:22 PM   #9
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Can you guys post some pics of what your doing so i can follow(=
Galatians 6:14
crice8 is offline
Old 04-17-2012, 08:16 PM   #10
SESRob
Fan#: 84340
Points 16, Level 1
I think Nicksterr was following a "how-to" post here that suggested that if you had the two screw backplate you would have to install washers with an HID setup to get a clean cut off (spacing the bulb back in the housing)....I have the two screw back plate and installed my HIDs (just as is) and they have a great cut-off/pattern. Said he was going to try the HIDs without the washers to see if everything was "ok".
SESRob is offline
