would anyone in the waco,killeen,austin help me? - Focus Fanatics
Go Back   Focus Fanatics > Regional Forums > Southern Fanatics > Fanatics: Texas
Fanatics: Texas Regional discussion Forum for planning events and sharing information with all Members in the Texas (Lonestar) areas.
Old 04-15-2012, 12:02 PM   #1
scoutout
scoutout's Avatar
Fan#: 88324
What I Drive: 2002 black ford focus svt
FF Reputation: 1 scoutout Good Standing Member
can anyone in these areas help me figure out what is up with my svtf? trying to battle the p1383 code. could really use someone who has knowledge or been down this path before! thank you
2002 Black SVT # 2,844 148k miles and counting!
OIF VET 2007-2008
scoutout is offline
Old 04-15-2012, 02:27 PM   #2
scoutout
scoutout's Avatar
Fan#: 88324
oh i will pay you for your time! if that will get any intrest in helping me.
OIF VET 2007-2008
scoutout is offline
Old 04-15-2012, 02:38 PM   #3
mikebontoft
Toxx
mikebontoft's Avatar
Fan#: 58647
Well the cam timing is off. Did you or a shop etc replace the timing belt recently? Plenty of people get it wrong and end up putting the vct solenoid in the wrong spot.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parting) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-sold) | '75 BMW 2002 "Carby" (resto-mod racecar) | '75 BMW 2002 (donor -sold) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (alt. daily).
Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics
mikebontoft is online now
Old 04-15-2012, 02:59 PM   #4
scoutout
scoutout's Avatar
Fan#: 88324
no i didnt change it. i was thinking whoever had the car before me did it.
OIF VET 2007-2008
scoutout is offline
Old 04-15-2012, 03:05 PM   #5
mikebontoft
Toxx
Fan#: 58647
That's very likely.... have you always had the code since you bought it? I have not done a belt on an SVT yet, but from what I understand they are tough to get correctly if you don't know how to do it or look up the procedure.
Old 04-15-2012, 03:25 PM   #6
scoutout
scoutout's Avatar
Fan#: 88324
yep had the code from day one. yea i heard there tough that is why i was hoping to find some help. someone has done it right and knows what there doing.
OIF VET 2007-2008
scoutout is offline
Old 04-15-2012, 03:26 PM   #7
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
Yeah its a timing issue, I sent you information on a very reputable shop here in Austin.
Tom is offline
Old 04-15-2012, 03:41 PM   #8
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
FF Reputation: 34 tukaniSVT Great Standing Member
It's isn't too terrible hard ... just to be very meticulous and have the correct tools to work on it.
The Houston crew has done quite a few of them.
Looks like Tom has a shop that will help you out. Good luck. If you have any questions of the process, you can ask. It's a common thing for SVTF owners.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 04-15-2012, 03:45 PM   #9
scoutout
scoutout's Avatar
Fan#: 88324
i kinda dont have the money for a shop. so im trying to do it my self. should i go ahead and just buy the whole timing belt set and replace it or just try and time it if its off? i took the cover off and the belt looks good.
OIF VET 2007-2008
scoutout is offline
Old 04-16-2012, 02:14 PM   #10
Bullit
Bullit's Avatar
Fan#: 95749
What I Drive: 2010 Flame Blue SES
FF Reputation: 1 Bullit Good Standing Member
When doing a timing belt there are 2 ways to start puting it back together.
1. If there is markings on the cam and oil gears and behind them. You would need to match them up. Also there should be a timing mark on the crank like a nick or a cut and somewhere there should be a gauge with a notch at the 0. Sometimes the guage is on the timing cover and sometimes there is a notch on the block with a timing guage on the crank gear. You want the notch to line up with the 0 on the guage. There shouldn't be a need to retime your motor. Once everything is lined up put the belt on and roll the motor 2 full rotations then tighten the tentioner. Turn the engine 1 full rotation and make sure they line back up with the tentioner tight.
2. If there isn't a timing mark on your crank shaft you need to find top dead center. there are a few ways to find this. One is by pulling the crank shaft gear and putting the tooth notch up then replacing the rank gear. Another is to pull the plug on cylendar 1 and stick a screw driver in the hole. Turn the engine untill the piston hits the tip of the screw driver then just before it starts to go back down stop. That should be TDC (top dead center).
Once you have the Crank at top dead center then you would do everything from the first part minus moving the crank.
This is a general explanation for replacing a timing belt so there may be more may not be more that needs to be done.
Also the markers on the gears are usually triangles or diamonds. Sometimes these gears are used on multiple engines and will have both a triangle and a diamond. Make sure you know witch one to use. Sometimes you can find out this info online or maybe someone can answer that question.
Oh and GOOD LUCK!
I dont often race... but when i do its in a Focus.
Bullit is offline
