HOW TO: Wiring in Illuminated Door Sills - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: Was This Helpful?
Yes, I appreciate it and want to add these to my car 19 95.00%
No, I know less now than before 0 0%
Your thread is bad and you should feel bad! 1 5.00%
Voters: 20. You may not vote on this poll
Old 05-10-2013, 11:53 AM   #81
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
Best bet is forad :)
badazz2010focus is online now
Old 05-28-2013, 09:46 AM   #82
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by Dragonware View Post
DarderSauce the light does not turn on when you hit the dome light switch following the instructions of the original poster, Red onto the grey/violet and black to ground.
It only comes on when the door is open , which is fine however when the door is closed id like an option to turn it on also just like the dome light can be.
Sorry I should have been a little more clear. When you turn the dome light on using the dimmer switch for your dash lights, the sills will turn on.
If you can't wear it out, burn it off
DarderSauce is offline
Old 06-11-2013, 02:50 PM   #83
Mumford
Mumford's Avatar
Fan#: 99437
What I Drive: 2009, Sangria Red, SE Coupe
Points 1,138, Level 18
Points: 1,138, Level: 18 Points: 1,138, Level: 18 Points: 1,138, Level: 18
Level Up 38% Completed
Forum Activity 2%
FF Reputation: 3 Mumford Good Standing Member
well thanks to this write up i was able to install my LED stips under the dash very easly ill upload pictures later
have you been mumfed yet
FF14 2nd place winner non-hatch 00-11 sponsored by focus power
Mumford is offline
Old 06-11-2013, 03:39 PM   #84
DarderSauce
Fan#: 95564
I am thinking of installing a flexible line of LED's along the back window since my car doesn't have a rear dome light. Right behind the headliner would conceal them the most. I wonder if I could angle them so they only light up the cab of the car making them invisible to the people behind me
Might be my new project.
Old 06-11-2013, 03:46 PM   #85
Mumford
Mumford's Avatar
Fan#: 99437
Forum Activity 2%
lol i actually bought a set of like 5inch strips i was going to do the same thing with but couldnt figure out a spot to put them...i was thinking cutting them into the rear pillars above the seat belt hole and hide them inside that with a push button to turn them on as well as hooked up to the dome light lol
Mumford is offline
Old 10-09-2013, 11:29 PM   #86
focusfig
Fan#: 101178
What I Drive: 2006 Sonic Blue Hatch
Points 8, Level 1
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Level Up 15% Completed
FF Reputation: 1 focusfig Good Standing Member
I could very well be mistaken but isn't the same grey violet wire in the harness behind the kick panels? If so why not just splice there rather than remove the a pillar? If i'm totally off I apologize, just trying to figure things out for myself.
focusfig is offline
Old 10-19-2013, 08:32 PM   #87
DarderSauce
Fan#: 95564
I think you might be correct but I would have to pull that panel off to make sure. The instructions said to splice into the pillar power, no idea why. If the wire is behind the kick panel, yes it would make more sense to splice it in there.
Old 05-12-2014, 03:17 AM   #88
2005.ST
2005.ST's Avatar
Fan#: 95355
What I Drive: '05 grey ST,eibach springs,SVT rims
Points 231, Level 4
Points: 231, Level: 4 Points: 231, Level: 4 Points: 231, Level: 4
Level Up 62% Completed
Forum Activity 4%
FF Reputation: 1 2005.ST Good Standing Member
I bought a Ford dome light off ebay and screwed it into the roof liner over the back seats. Ran wires thru the liner up to the front dome light. Both dome lights work together and it looks factory. Yes, it's dark in the back with only a front dome light. Went shopping at night and left stuff on the back floor cause I couldn't see it.
2005.ST is offline
Old 05-12-2014, 03:05 PM   #89
Mumford
Mumford's Avatar
Fan#: 99437
Forum Activity 2%
^^ ive thought about doing this you have and pictures of the work and what dome light you use
Mumford is offline
Old 05-12-2014, 06:29 PM   #90
2005.ST
2005.ST's Avatar
Fan#: 95355
Points 231, Level 4
Forum Activity 4%
dome light
I found a Ford light where the vinyl housing was the same color as my headliner vinyl trim.
2005.ST is offline
