Go Back   Focus Fanatics > Model Specific Discussions > MK2 Focus
View Poll Results: Was This Helpful?
Yes, I appreciate it and want to add these to my car 14 93.33%
No, I know less now than before 0 0%
Your thread is bad and you should feel bad! 1 6.67%
Voters: 15. You may not vote on this poll
Old 04-14-2012, 05:52 PM   #1
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
HOW TO: Wiring in Illuminated Door Sills
Here we go everyone, in response to VonKrause's How to wire in fog lights that I found very helpful, I wanted to help anyone considering installing illuminated door sill plates. First thing is first, go get yourself the Ford Sill kit..... I got mine from another member and it was $100. If you buy them from Ford they usually run you around $200 but you can usually find them on Ebay or check the marketplace.
this is what they will look like:
Illuminated Sills by DarderSauce, on Flickr
First thing you are going to want to do is remove the battery terminals (+ & -)
Next you are going to want to remove the factory sill plates..... Just snaps right off.
3 by DarderSauce, on Flickr
Then your passenger side kick panel
2 by DarderSauce, on Flickr
4 by DarderSauce, on Flickr
Now remove your A pillar
6 by DarderSauce, on Flickr
5 by DarderSauce, on Flickr
8 by DarderSauce, on Flickr
This is where you will be wiring in your Sill plates
7 by DarderSauce, on Flickr
Unplug the connector and find the grey/violet wire
9 by DarderSauce, on Flickr
Strip back some of the electrical tape so you can use a quick connector to splice in the wiring for the lights.... You will connect the red wire to the grey/violet wire (the black wire is the ground but we will get to that later)
13 by DarderSauce, on Flickr
12 by DarderSauce, on Flickr
Now you are going to want to strip the black wire back so you can attach an end to it and ground it on a bolt under the kick panel (any bolt will do). But since I had only large ends I had to double the wire over so there was more metal connecting to the end I connected
14 by DarderSauce, on Flickr
16 by DarderSauce, on Flickr
Now you have to feed the wire from the passenger side to the drivers side. I fed it as far back as I could so they would not be in the way. This is where a coat hanger/metal wire comes in. Feed the wire through from the drivers side and hook it to the wiring for the door sills so you can bring it back through.
18 by DarderSauce, on Flickr
I ran the wire on top of this metal bracket
29 by DarderSauce, on Flickr
Now you can remove your sill and kick panel on the drivers side door
19 by DarderSauce, on Flickr
You can now drill the holes on the kick panels, make sure you do not drill into the clips that attach the sills to the body. The position you drill will depend on the side you are on.
21 by DarderSauce, on Flickr
20 by DarderSauce, on Flickr
Next thing you are going to want to do is center the Illuminated Sills on the factory sills and tape off the end and the middle of where you want them.
22 by DarderSauce, on Flickr
Next you want to clean the door sills with the alcohol pads (in kit) and apply the adhesive promoter (also in kit) and let the promoter sit for 5 min.
23 by DarderSauce, on Flickr
Now you are ready to attach the plates!!! Remove the tape from the back of the plates and line them up with the lines you have taped off, this is also when you will feed the fiberoptic wire in the holes you drilled. After attaching the sills they will look like this
28 by DarderSauce, on Flickr
Attach the battery terminals and make sure everything lights up and if it it does... re-assemble everything and you're done! Hope this helps and I will be happy to answer any questions you guys may have.
If you can't wear it out, burn it off
DarderSauce is offline
Fan#: 1
Old 04-14-2012, 06:04 PM   #2
champjfocus
champjfocus's Avatar
Fan#: 96072
What I Drive: 2009 Ford Focus SES in Sangria Red
FF Reputation: 1 champjfocus Good Standing Member
Do you have pictures of lit up? Get some in the dark tonight too! Looks great! Cant wait to see it in dark and in my car. Great how to!
SES #035:
LED plate lights, LED map lights, LED cargo lights, remote start system
champjfocus is offline
Old 04-14-2012, 06:25 PM   #3
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
FF Reputation: 5 badazz2010focus Good Standing Member
So you had to glue them onto the existing focus sills o never knew that lol
badazz2010focus is offline
Old 04-14-2012, 06:26 PM   #4
matz2453
matz2453's Avatar
Fan#: 88492
What I Drive: 2010 black ses, 2012 Mitsu
FF Reputation: 4 matz2453 Good Standing Member
nice how, i wish they came in different colors, i want blue ones, but dont feel like ordering them from china lol
SES #031
matz2453 is offline
Old 04-14-2012, 07:07 PM   #5
champjfocus
Fan#: 96072
Affixed using 3M tape.
SES #035:
Old 04-14-2012, 08:24 PM   #6
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
job well done! Now MOAR PICTURES!
Posted via FF Mobile
st12131 is online now
Old 04-14-2012, 08:30 PM   #7
DarderSauce
Fan#: 95564
Oh they are coming... Not quite dark enough yet.
Old 04-14-2012, 08:55 PM   #8
09vistabluecoupe
09vistabluecoupe's Avatar
Fan#: 67900
What I Drive: 2009 Vista Blue SE coupe
FF Reputation: 2 09vistabluecoupe Good Standing Member
Come on bro !!!
SE Coupe 5spd with Sync and Drivers Group.
- FSWerks CAI
- Autolite AR103s
Midwest crew #52
09vistabluecoupe is offline
Old 04-14-2012, 11:22 PM   #9
champjfocus
Fan#: 96072
Hurry! lol
SES #035:
Old 04-15-2012, 10:10 AM   #10
badazz2010focus
Fan#: 78166
LOL geez guys
