p2004, IRMC stuck open - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2012, 12:51 PM   #1
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
What is the best fix for this code?
GreySkorpion is offline
Old 04-14-2012, 09:14 PM   #2
GreySkorpion
Fan#: 94674
Nobody? Surely someone has had this code and had a solution.
Old 04-15-2012, 12:07 AM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,768, Level 98
Points: 27,768, Level: 98 Points: 27,768, Level: 98 Points: 27,768, Level: 98
Level Up 42% Completed
Forum Activity 4%
Not as familiar with the PZEV as I am with the later Foci. I hear yours is vacuum controlled, so check the hoses out. I have heard of some people who had issues with the clip that holds the actuator to the rod breaking. Find the actuator, and check to be sure it's still connected.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-15-2012, 11:38 AM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,818, Level 73
Points: 12,818, Level: 73 Points: 12,818, Level: 73 Points: 12,818, Level: 73
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 99%
Okay, had to wait for this morning so I could take a good look at mine...
The problem with some things, is that if you haven't had an issue - you haven't REALLY dived into it to know ALL the details first hand - and mine hasn't given me any grief yet...
If you look downwards JUST behind the throttle body you'll see a white piece of plastic (lever arm) with a black pop on rod end at it's right side (when facing the front of the car).
You can put a finger on that, gently push down, and it should return to the top position. If it's "down" already, doesn't move easily, or the rod is disconnected from the lever - you've found the issue.
It could have come apart connection wise, the actuator may have an issue or even a hose disconnected (couldn't actually SEE that easily at a quick glance to tell you what it looks like, kinda hidden), or there could be a problem inside the intake manifold where something got "stuck" as the "code" suggests.
(Pet peeve - the objective isn't to "fix" the code, it's to fix the issue the code suggests may exist...)
Luck!
Let us know what you find...
sailor is online now
Old 04-15-2012, 04:49 PM   #5
GreySkorpion
Fan#: 94674
The rod is up and returns fine when pushed down, I can hear a vacuum like sucking noise when I push it down.
Old 04-15-2012, 04:56 PM   #6
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 4%
I'd trace down the vacuum for the IMRC actuator to be sure lack of vacuum isn't causing the problem. If it's not too hard to reach, you can disconnect the vacuum from the actuator with the engine running and feel if you have vacuum there before you go searching for a red herring.
Be eclectic.
Old 04-15-2012, 07:04 PM   #7
GreySkorpion
Fan#: 94674
Great idea, I will try that. There is an actuator (with the arm on it) and 2 solenoids on top of the intake. It has to be one of those 3 or a vacuum line. All vacuum lines I can see are good and not collapsed or rotten.
Old 04-15-2012, 08:25 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Yup, check it out well, 'cause the response you got is the same as I get on one that works fine...
Old 04-15-2012, 10:07 PM   #9
GreySkorpion
Fan#: 94674
There is suction from the tube that runs from the actuator, it hooks to the solenoid that is on the driver side of the intake (there are 2 solenoids side by side), so I figured to switch the 2 solenoids out and cleared the code via battery cable removal and after 5 start ups, no CEL. I have acces to 2 free solenoids, so the left one now will be getting changed as well and I will have a spare. I hope the CEL stays off.
BTW, this car sat idle for 4 months, I wonder if some parts needed some "exercise" to start working right, ie, tumble flaps.
Old 04-16-2012, 04:25 AM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
solenoid might have needed the excercise as well.
amazing the gremlins after a bit of sitting...
