custom airbox/heat shield for 2012 steeda SRI - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-13-2012, 02:41 PM   #1
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,345, Level 41
Points: 4,345, Level: 41 Points: 4,345, Level: 41 Points: 4,345, Level: 41
Level Up 98% Completed
Forum Activity 5%
FF Reputation: 9 darkangelism Good Standing Member
I am planning on trying to build a custom airbox/ heat shield for the Steeda Short Ram intake for the 2012. It is somewhat similar to their cold air intake but uses all of the stock inlets and allows for a cold air pipe from the front bumper area, similar to the mod that newmission did. I am looking for some feedback and see if there are any flaws in my design. The airbox will be built from 1/8th inch aluminum sheet bent into the proper shape.
Front panel mod:
Taking what newmission did with drilling holes in the front plastic triangle and making full slots across with the exception of where the punchouts are. I will then hot glue a piece of screen door screen to the backside, this will help keeps bugs and rocks from getting sucked up.
I will hot glue a funnel that is cut to the right size to the first piece of intake pipe and wrap the edge with duct tape so that no air can escape out and to protect the glue from weather. The first piece of pipe will a 45 degree mandrel bent pipe 2.5” inside diameter, and will be hose clamped to a 1 foot long straight pipe and will run into the airbox.
Airbox:
The airbox will be four sided liked the CAI that Steeda has, and have a 2 sided cover. The estimated dimensions are six inches wide, six inches long and 7 inches tall. The bottom piece will be an extra half inch long on the open right side to make the connection piece to the chassis shorter. That piece will screw in below the grounding wire, in the same spot that the steeda design uses.
The bottom side will have a hole for the 2.5” pipe along the top edge so that the pipe can be anchored in the box with a hose clamp that is screwed into the box. It will also have a screw hole to screw the stock steeda SRI mount to.
The front side will have a hole for the modified second stock inlet and will have a bracket that runs to the chassis to attach below that hose.
The left side will have a hole on the bottom edge for the primary stock intake with the hole for the velocity stack right above it, this is basically the same design that steeda uses and the velocity stack will be screwed into the aluminum like the steeda design. Next to that hole will be another bracket like the steeda has for a 3rd mount point to the chassis.
Stock air inlet mod:
The stock air inlets have two inlet hoses. The first one will be the same as the steeda design. The second inlet the steeda design just plugs it, probably due to the odd shape, the hole on the chassis side is round and I will take some hose and screw it into the housing to allow a round shape into the airbox. This should allow for three separate inlets to the airbox and higher and colder airflow.
The top cover:
The top cover will be an L shape piece of aluminum that will use two screws on the left side to hold it in place. The top will be covered with some foam that will prevent rubbing against the hood.
Parts list:
24X24 1/8 inch thick aluminum(airbox)
12X24 1/8 inch thick aluminum(cover)
1 foot 45 degree aluminum pipe 2.5” inner diameter
1 foot straight aluminum pipe 2.5” inner diameter
1 pipe connector
Screen door mesh
Funnel
2 inch inner diameter hose for 2nd inlet
Three metal brackets
12 8mm screws and bolts
Steeda short ram intake
Foam padding
darkangelism is online now
Old 08-13-2012, 02:08 PM   #2
focusonthis420
focusonthis420's Avatar
Fan#: 30951
What I Drive: SGM 2012 5dr
FF Reputation: 17 focusonthis420 Great Standing Member
Buy-Sell-Trade Rating: (26)
Don't know if I missed another thread of yours about this, but have you made any progress?
Sterling Gray Metallic 2012 5dr Titanium w/ MS3 RMM
focusonthis420 is offline
Old 08-14-2012, 03:21 AM   #3
TKE421
TKE421's Avatar
Fan#: 101988
What I Drive: 2012 Tuxedo Black Focus SE
Points 614, Level 12
Points: 614, Level: 12 Points: 614, Level: 12 Points: 614, Level: 12
Level Up 28% Completed
FF Reputation: 1 TKE421 Good Standing Member
Gonna watch this VERY closely!!
TKE421 is offline
Old 08-14-2012, 10:44 AM   #4
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 5%
Right now the steeda SRI is sitting in the bottom half of the stock box, this I found was more than enough for shielding the bottom. I have not done the rest yet, I just moved to a new house, and did some plastidip and then I had to do touch up paint this past week, and 110 degree temperature is not very fun to work outside in, so I haven't gotten back around to this, still planning on it, going to build a new cover and a 2nd heat shield next to the crinkle tube to keep as much hot air out. Also will do a new mission mod to bring colder air in from the front fender.
So the design has changed somewhat, but still should have the same outcome.
Old 07-09-2013, 01:28 PM   #5
papaacer
Sonic's MK3 Crew #25
papaacer's Avatar
Fan#: 111083
What I Drive: 2012 Race Red SE
Points 7,225, Level 56
Points: 7,225, Level: 56 Points: 7,225, Level: 56 Points: 7,225, Level: 56
Level Up 38% Completed
Forum Activity 74%
Activity: 74% Activity: 74% Activity: 74%
FF Reputation: 11 papaacer Great Standing Member
Hey josh hate to revive an old thread but did this ever happen?
papaacer is online now
Old 07-09-2013, 01:36 PM   #6
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 5%
No, I still have the aluminum but not the metal skills, I have the Steeda intake crammed in a cut stock box, might just glue the aluminum on top of that as a heat reflector and cut a second piece on the engine side of the MAF housing. Will give at least some shielding and takes less skill.
My intake air temps are only bad under WOT and in city driving 10-14 degrees over ambient, cruising is 1-6 degrees. In general 10 degrees is 1 HP, so not losing much power currently, but would like to get heatsoak down slightly.
Old 07-09-2013, 01:39 PM   #7
papaacer
papaacer's Avatar
Fan#: 111083
Forum Activity 74%
See I'm kinda wanting to do a little bit of a K&N type housing myself, just need to measure it all out, might go find some cardboard and do it today to get ready to find metal
Originally Posted by Twenty View Post
That's because if a sedan was used there would be too much awesomeness and the internet would explode.
Originally Posted by Deftmetal View Post
I've never died because my car turned off.
Old 07-09-2013, 01:43 PM   #8
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 5%
Cool, my OP had some rough measurements of what fits.
