Solution to cooling fan resister failure??? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2012, 11:43 PM   #11
winterbeater
Fan#: 93035
What I Drive: 2001 blue wagon
FF Reputation: 3 winterbeater Good Standing Member
New approach on this issue. I'm just a cheapskate. That's why I bought this old Focus for $2G and patching it up ever since.
I pulled the resistor. Ohmmeter tells me that only the thermal fuse is blown. NAXJA forum (one of my other beaters) dudes have fixed heater fan resistors with Radio Shack thermal fuses for $1.79. That's my next step. I'll try to do pictures.
winterbeater is offline
Old 04-13-2012, 12:23 AM   #12
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,384, Level 61
Points: 8,384, Level: 61 Points: 8,384, Level: 61 Points: 8,384, Level: 61
Level Up 78% Completed
Forum Activity 36%
Activity: 36% Activity: 36% Activity: 36%
funny to see a fellow XJ owner who also has a Foci on here. funny... wiring up the low speed fan relay to turn on the high speed relay would be the cheapest fix as it would only require a small gauge wire to the +12V coil on the high speed fan relay. most likely you have the 12" or less of 16 AWG wire laying around to do this...
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 04-13-2012, 02:37 AM   #13
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,060, Level 34
Points: 3,060, Level: 34 Points: 3,060, Level: 34 Points: 3,060, Level: 34
Level Up 7% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Even cheaper is to bypass the thermal fuse with a piece of wire..........
Ed
emsvitil is offline
Old 04-13-2012, 09:49 AM   #14
winterbeater
Fan#: 93035
Agreed, but then you run the risk of wiring or connector meltdown. When I worked in HVAC warranty, I saw blower motor resistors that had overheated, where the thermal fuse failed to melt that actually caused fires, or more often wire meltdown.
Old 04-22-2012, 01:38 PM   #15
winterbeater
Fan#: 93035
Repair for blown thermal resistor
Fixed it by jumping the relays as suggested. Soldering the thermal fuse was a pain, so I took the shortcut. Works great so far. Fans come on full power at 107C.
First picture shows the low and high speed fan relays at the bottom right. Pull the relays out. This is the fuse box right under the hood.
Insert a jumper wire as shown. Re-insert the relays. That's it! The PCM then activates the high speed fan circuit when it signals the low speed relay.
Old 04-22-2012, 01:48 PM   #16
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
Good solution. The same thing can be done underneath the box by simply jointing or bridging the hot wires to the relay coils. Then you don't have relays jammed in there on top of wires.
At least you didn't wire it constant hot like some people do. Then they wonder why their fans and alternators keep blowing up.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 05-12-2012, 07:29 PM   #17
hanojreason
Fan#: 96982
What I Drive: 2013 Focus ST1
Points 64, Level 1
Points: 64, Level: 1 Points: 64, Level: 1 Points: 64, Level: 1
Level Up 28% Completed
FF Reputation: 1 hanojreason Good Standing Member
Winterbeater!!! Thanks so much! Worked like a charm for me!
hanojreason is offline
Old 08-12-2012, 11:51 PM   #18
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Forum Activity 3%
a_2000_se and others are right. I am so stupid, the lower section of the schematic is only rated at 30 amp, if you simply tie the resistor wires together to bypass and full fan speed, you will have too much amp flowing through the wires.
Looking at this much later caught it, my bad. looks like I'm fixing to experience it first hand, mine started overheat at idle only today. Will be yanking that resistor tomorrow.
Going up underneath the fusebox may not be much of an option, there's a godawful bunch of wires under there and not a lot of room without disconnecting more stuff. I rebuilt one of those entire boxes when mine was shattered in accident. Bought just the plastic box for $10 after cutting out all the wiring in junkyard, the guy at part desk thought I was crazy. The fusebox is part of the main wiring harness. It took maybe 2 hours to rebuild it but I saved a bunch of money doing so.
amc49 is offline
Old 03-12-2013, 05:24 AM   #19
239rsw
239rsw's Avatar
Fan#: 15133
What I Drive: 2002 Yellow ZX3
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 239rsw Good Standing Member
Now that the weather is getting warmer, I am planning to look into the cooling issue that I have had. I've replaced the thermal fuse (resistor) a few years ago. It worked (no overheating) until the weather got really warm. The following spring, I replaced the resistor assembly from dealer and it failed again.
Looking at the schematic diagram, if my connectors were bad, the fan should still not work if resistor was replaced. I am wondering if the sensor, if any, that kicks off the high-speed relay is not working. Where can I find that sensor?
I have an 02 zetec
2002 ZX3 @ 333K
Last Update : 10/05/2014
239rsw is offline
Old 03-12-2013, 06:04 AM   #20
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 5%
The temperature sensor is located in the center of the cylinder head between cyl 2 and 3. It is the same sensor that shows your engine temp.
Be eclectic.
