Leaking seal Variable Cam Timing (VCT) solenoid (Oil leak) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-10-2012, 12:01 AM   #1
Kaaru
Kaaru's Avatar
Fan#: 96763
What I Drive: '12 Oxford Wh. SEL Sedan 28/07/2011
FF Reputation: 1 Kaaru Good Standing Member
Hello all,
Thanks to this Forum, I was able to track down a serious issue I had with the first Focus I purchase back in nov 2011.
I had a major oil leak in the engine bay and back then the dealer was not able to precisely tell me the nature of the oil leak.
Thanks to ''Raycer'' a forum member, I was able to find out that it was due to a faulty Solenoid seal from one of the 2 VCT Solenoid unit under the hood.
Raycer made a post about it back in june 2011 but the post has been since hijacked and the issue has faded and/or went all over the place.
I'd like to know if anyone had a similar experience regarding this VCT Solenoid broken seal.
Another member, Gabe2010SE had a picture of the culprit added. Here it is:
Thanks in advance
Kaaru is offline
Old 04-10-2012, 12:41 AM   #2
xwhit3devilx
xwhit3devilx's Avatar
Fan#: 86578
What I Drive: 2014 Hyundai Veloster Turbo
Points 5,510, Level 47
Points: 5,510, Level: 47 Points: 5,510, Level: 47 Points: 5,510, Level: 47
Level Up 80% Completed
FF Reputation: 2 xwhit3devilx Good Standing Member
I've heard of several people having this issue now, shame it's as widespread as it is. I had a similar issue with oil gushing out everywhere, but in my case it would seem the oil dipstick was "faulty", more like they forgot to put the tube the dipstick slides into inside the engine during manufacturing. My thread is here in case you're interested.
http://www.focusfanatics.com/forum/showthread.php?t=260179
Leaving parts out of the engine itself, and to have that problem at 300 miles hasn't really given me high hopes for the car long term.
xwhit3devilx is offline
Old 04-10-2012, 10:58 PM   #3
Zosylf
Fan#: 97557
What I Drive: 2012 Candy blue metalic Hatchback
FF Reputation: 1 Zosylf Good Standing Member
Wanted to go for a nice Easter ride with the girlfriend, decided to check oil on new Focus (2400 mi.). Raised hood and see puddles of oil on valve cover! Good thing I checked oil before 135 mi. trip to girl's house. So I know it happened recently. Blown rubber seal on part you've circled on pic, front vct soleniod. Just got car back from dealer, today. They cleaned up engine, but felt-like heat shield on hood still soaked in oil. I also didn't like the use of rtv type sealant on valve cover re-install. Wonder how much of that is floating around in my engine oil now! They also charged me for an oil change, I insisted on because, I felt my closed oil system had been breeched and contaminated. What the heck Ford! I picked you over imports doing the right thing and standing by you. Don't have a good feeling about this!!!!!!!!!!! Gees It's stylish though.
Zosylf is offline
Old 04-10-2012, 11:06 PM   #4
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Seems like this is one reason not to install the engine cover. Think I'll take a peek under mine tomorrow.
dan50 is offline
Old 04-11-2012, 08:00 AM   #5
Kaaru
Kaaru's Avatar
Fan#: 96763
One quick way to ''know'' your seals are broken and you are leaking oil, is the very powerfull burn oil smell that fills the interior of the car.
Beleive me, you can't miss it. when the car moves, the smell goes away, of course...But as soon as you stop at a red light or idle for some other reasons, BAM! instant burt oil smell flagrance...I called it back then ''Eau de Focus''
So, IMO, having the engine cover will block your visual check, but the smell will always be there. Follow your nose, it always knows :)
Kaaru is offline
Old 04-11-2012, 11:20 AM   #6
B1GTED
B1GTED's Avatar
Fan#: 96546
What I Drive: 2012 Tuxedo Black Metallic Focus Ti
FF Reputation: 1 B1GTED Good Standing Member
Engine cover would keep it from soaking the hoods heat shield.
B1GTED is offline
Old 04-11-2012, 11:34 AM   #7
Kaaru
Kaaru's Avatar
Fan#: 96763
Indeed it will.
It will however prevent any visual check to see if some oil is leaking from the Solenoids. In my case, it was pretty severe, as I did a visual check while the engine was running and oil while was gushing everywhere. Some may experience a smaller/slower leak. I admit however that the engine cover looks pretty darn nice :)
Kaaru is offline
Old 04-11-2012, 02:47 PM   #8
dan50
Fan#: 91789
Forum Activity 4%
Originally Posted by Kaaru View Post
Indeed it will.
We'll be taking on a 3,000 mile road trip shortly and it only has about 2,500 on it so far. So I think I'll remove the cover for the trip to allow a quick visual inspection at each fuel stop. Not expecting a problem, but if it does happen it would be better to find it early.
dan50 is offline
Old 04-11-2012, 08:53 PM   #9
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
Is the RTV all the way around the valve cover?....or is it in a location where the valve cover gasket has to bridge a seam (such as where a front cover meets the engine block?). If its where there is a seam that the valve cover gasket sits on, then it is completely normal for there to be a small touch of RTV at that location only.....which is the same as it has been done for decades. Some engines have the entire front cover sealed with RTV from the factory, same with oil pans, etc. Any competent technician can do the repair with zero worries of contamination in your engine
Rat Fink is offline
Old 04-12-2012, 07:43 PM   #10
Zosylf
Fan#: 97557
The RTV was in the front where valve cover meets the block right below the the vct soleniod.
Zosylf is offline
