2012 FF LED tail light bulbs? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-11-2012, 10:00 PM   #21
Mucrammada
Mucrammada's Avatar
Fan#: 91537
What I Drive: 2013 Limited WRX Hatch, 2011 CTS
FF Reputation: 1 Mucrammada Good Standing Member
Holy crap, you spent a lot of money on light bulbs!
Mucrammada is offline
Old 04-11-2012, 10:21 PM   #22
Infam0usprime
Infam0usprime's Avatar
Fan#: 96862
What I Drive: 2012 Ford Focus Ti | 2001 Dodge Ram
FF Reputation: 2 Infam0usprime Good Standing Member
Originally Posted by RKZX2 View Post
you are correct sir. my mistake. here are the correct parts numbers:
rear--23454
Thank you for all the part numbers saved me the worry of buying the wrong ones and sending them back and getting new ones
Infam0usprime is offline
Old 04-11-2012, 10:21 PM   #23
Infam0usprime
Fan#: 96862
Worth it tho
Old 04-12-2012, 08:00 AM   #24
chrisdh79
Fan#: 85037
What I Drive: 2012 Ford Focus Titanium Sedan
FF Reputation: 1 chrisdh79 Good Standing Member
yeah. that's because there is still power in the module. they will go off after about 10 minutes. ok. i got them from LEDLIGHT.com part numbers as follows
rear brake & rear running #42367 in red
front markers & reverse #70475 in super white
fogs #75647 (WARNING!) the largest tab needs to be trimmed to make it fit. it's real easy. just put the new & stock lights side by side. match the tabs. trim the the one that doesn't match. takes only a minute to trim.
Sorry if this seems like a stupid question, just dont want to order more then needed.
Do you have to order each bulb individually, or do they come in pairs?
So in total, we'll be replacing 10 bulbs?
Also for the: rear brake & rear running #23454 in red, do you select the single or dual circuit?
chrisdh79 is offline
Old 04-12-2012, 05:27 PM   #25
Infam0usprime
Fan#: 96862
I'm pretty sure they are both single I tested and only one light lit up when I hit the brake the other one just stayed lit and when I took my foot off the brake it just turned off
Old 04-12-2012, 08:48 PM   #26
underbird10
underbird10's Avatar
Fan#: 88103
What I Drive: 2014 ST3
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 3 underbird10 Good Standing Member
I tried LEDs for the tail and brake lights. Didn't work out because they don't draw enough current to make the flasher relay work. I didn't try any extra resistors or anything, but it was a total bust as a plug-in mod.
UB10
2014 ST3 - Tuxedo Black with Full Leather Recaros, Sunroof, Nav-Sync-MFT
My other rides -2006 Performance White Mustang GT Coupe, 2004 40th Anniversary Edition Mustang Coupe, 2013 Edge Limited
underbird10 is offline
Old 04-12-2012, 09:42 PM   #27
RKZX2
RKZX2's Avatar
Fan#: 94762
What I Drive: 2012 Yellow Blaze SE Hatch
Points 1,685, Level 23
Points: 1,685, Level: 23 Points: 1,685, Level: 23 Points: 1,685, Level: 23
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 2%
FF Reputation: 1 RKZX2 Good Standing Member
really? how come they work with my car? the rear brake & tail lights are INDEPENDENT from the directionals. i didn't mess with those because of that reason. all i did was swap stock bulb for led bulb. NO resistors. the only thing i get is "brake lamp burnt out" message on screen at start up.
RKZX2 is offline
Old 04-12-2012, 09:58 PM   #28
underbird10
Fan#: 88103
Sorry, you're right it was the turn signal LED that didn't work. The brake and backup lights were fine. I tried it right after I bought the car and it didn't work the first time I tried it so I just gave up and went back to the stock bulbs. I don't remember if I left in the LED tails or not. I'll have to check.
UB10
Old 08-20-2012, 07:23 PM   #29
WillyMays
Fan#: 102842
What I Drive: 2012 dark gray sel 5 door
FF Reputation: 1 WillyMays Good Standing Member
i have leds in every slot EXCEPT directionals, headlights & hi-beams. i even put them in the fogs. here are pics.
the only problem is, in the rear, you will get a message on screen saying "tail light out" because of the low voltage. but they look so great, i'll deal with it.
I just bought my Focus and thinking of doing the same thing you did, but I live in Mexico and I'm really looking forward to see how it looks like, can you please load your photos again?
WillyMays is offline
Old 01-04-2013, 06:09 PM   #30
muledoe
Fan#: 89140
FF Reputation: 1 muledoe Good Standing Member
rear--23454
for the rear/brake on this # what is the base i need?
http://www.ledlight.com/SearchResult...KeyWords=23454
and also i would have to get it in red correct?
and what about front turn bulb what LED # would i need for that?
muledoe is offline
