Go Back   Focus Fanatics > Ford Focus Tech Discussions > ECU Tuning Chat
ECU Tuning Chat Discuss performance tuning options for your Ford Focus.
Old 04-06-2012, 02:21 PM   #1
Sayshell
Fan#: 97253
What I Drive: 2012 focus SE with sports package
FF Reputation: 1 Sayshell Good Standing Member
surge performance chips
http://www.streetbeatcustoms.com/Sur...ce-Chip/17558/
I am about to buy one of these...
35 horsepower or 4-9mpg....
I would take the 4-9mpg
If it does half of what it claims its worth it... Do these things actually work?
I drive a 2004 ford focus zx5... So I am guessing it could work. A better designed chip should be able to save gas/boost power
Sayshell is offline
Fan#: 1
Old 04-06-2012, 02:54 PM   #2
Focusalaska
Focusalaska's Avatar
Fan#: 68329
What I Drive: 2009 Ebony SES
FF Reputation: 2 Focusalaska Good Standing Member
RUN far away from that. Definately will not help you gain any mpg.
Team Duratec #23
Official SES Registry #49
Tom's Tune, DDMTUNING 5000k HI/LO & FOGS, Switchback LED turn signals, AR103's gapped .54, FSWerks CAI. more to come
Focusalaska is offline
Old 04-06-2012, 02:56 PM   #3
UnbridledCarnage
Rhinoliner!!!
UnbridledCarnage's Avatar
Fan#: 66551
What I Drive: 03 Rhinoliner'd ZX3 AdvanceTrac
FF Reputation: 9 UnbridledCarnage Good Standing Member
IIRC there isnt a chip for the zetec. its ECU tuning. if they worked, everyone would be screaming about it
If your local to the 502, 270, 812, 606, 859 area, check out FocusXtreme, the Ohio Valley chapter of FF. Monthly meets and kickass people! Join and POST UP!!!
Mod for General Chat, Ford General chat, FocusXtreme, KY,NC,SC sections
Originally Posted by matmatician View Post
Racecar > Comfortable female.
UnbridledCarnage is offline
Old 04-06-2012, 02:59 PM   #4
Sayshell
Fan#: 97253
you sure? Could you elaborate a bit? It seems too good to be true for sure and I think you are right.. the only reason I believe it is possible is because theoretically it could work and basically be the same thing as buying an ECU tuner just with pretuned settings for higher performance for the guy who doesn't know how to tune it him self, and because its false advertising if it doesn't do the minimum requirement.
Sayshell is offline
Old 04-06-2012, 03:04 PM   #5
UnbridledCarnage
Rhinoliner!!!
Fan#: 66551
It is false advetising. even Toms tune will not add much HP. if it worked, none of us would spend the money for toms tune, we would just buy this. for a car to be "tuned" it has to specific to your vehicle/mods.
Old 04-06-2012, 03:40 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 33 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
You should look into 'truth in advertising' more. Generally, claims by ads can be untrue for some instances if there is truth in some instances. Take things like hair growth products, cold remedies and the like. If by the majority the ads are true, the advertiser can make claims that may not hold true for all.
Being the ad is not specifically for the Focus they can make this claim. But you should not expect any of it to be true ... because it isn't, not even close.
Everyone is correct in that a flash tuner (SCT) is the only method to go. There is not a workaround or cheaper alternative.
iminhell is offline
Old 04-06-2012, 04:56 PM   #7
Focusalaska
Fan#: 68329
First.... when the website you chose comes up with MANY buyer beware/ ripoff reports, i would be a little hesitant to believe any claims from them. http://bit.ly/I2ORnC Theoretically a electric supercharger should work also, but it does not. I can find you many E-bay ads with theoretical "performance gains". Truth of the matter is MANY of us Focus owners have already found what DOES in fact work. As said before if you really want to tune (although you don't know how) get in touch with a company that uses SCT software. Tom here on the forums or FSwerks both could tune almost any Focus remotely (e-mail tunes using a SCT flasher).
Team Duratec #23
Old 04-06-2012, 07:52 PM   #8
JCH841
JCH841's Avatar
Fan#: 79303
What I Drive: 2008 Black SES (?) Coupe
FF Reputation: 3 JCH841 Good Standing Member
I clipped this directly from the linked website; "quickly gain 4-9 mpg better fuel economy. Turn it to the max and expect to gain up to 35 horses" Your expectations can subconciously change your driving habits enough to see 4 mpg and if you gained 2 hp that is "up to 35." Like they said - RUN.
Growing old is unavoidable. Growing up is optional.
JCH841 is offline
Old 04-06-2012, 07:56 PM   #9
Sayshell
Fan#: 97253
alright I am convinced. Mission aborted... too bad was hoping their was a secret short cut.
Sayshell is offline
Old 04-07-2012, 12:36 PM   #10
bradshsi
bradshsi's Avatar
Fan#: 58770
What I Drive: 2002 Sonic Blue Turbocharged SVT
FF Reputation: 6 bradshsi Good Standing Member
It is a slightly more polished version of the resistor to falsify IAT values tuning trick.
Basically there are zillions of these on Ebay but they all work the same way. They are a resistor that is wired into the IAT circuit (it even says so in their description). This fools the ECU into thinking the air temperature is different from what it actually is and then ECU then adjusts the amount of fuel delivered based on a ficticious air density (air density is a function of air temperature).
It may in some instances give a small HP performance gain if you trick the ECU into pushing in more fuel. But really unless your ECU tune is horrible, you are far more likely to cause performance problems and in rare cases even damage your engine.
Sona si latine loqueris
bradshsi is offline
