HELP, No Start, no crank, no nothing!!! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > General Technical Chat
Old 04-05-2012, 10:53 AM   #1
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
Okay here is the deal, I have used the search function and after reading lots of "suggestions" I am stuck. My 2004 2.3 Duratec with auto trans will not start, won't crank, wont turn over. All the dash lights come on, fuel pump can be heard and PATS is working normal. We had to replace the ignition cylinder due to the old one freezing up and since have had this issue. They key turns fine in the ignition, PATS blinks slowly until the key is turned to start where it comes on solid for about 2 seconds, then turns off (which is normal PATS light sequence).
What we have checked and or replaced:
1) Starter was replaced, power at starter, but relay is the only relay we didnt change, its behind a metal plate on inside fuse panel.
2)PATS sequence is normal
3)Used a jumper wire to bypass the neutral safety switch, no change
4)Battery fully charged and terminals are clean
5)Ignition switch plugged in(not tested though)
6)PATS ring plugged in
7)All relays replaced, except PITA starter relay
8)All fuses good
9) Fuel shut-off switch in kick panel is good
So what else should I check or test?? Should I replace the ignition switch and starter relay (although having power at the starter should rule out a bad relay)
Thanks for the help in advance.
GreySkorpion is offline
Old 04-05-2012, 12:25 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,487, Level 30
Points: 2,487, Level: 30 Points: 2,487, Level: 30 Points: 2,487, Level: 30
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 19%
Sounds like the starter relay/solenoid/coil is not working, or not getting a +12v signal to work.
Either way, you will need to take the troubleshooting to that relay, to find out if the ign switch is outputting on the "start" position, or if the relay is just not responding to it.
elsolo is offline
Old 04-05-2012, 01:22 PM   #3
Getahorse II
Fan#: 73771
What I Drive: 2000 red SE wagon, SPI
Points 348, Level 6
Points: 348, Level: 6 Points: 348, Level: 6 Points: 348, Level: 6
Level Up 96% Completed
FF Reputation: 1 Getahorse II Good Standing Member
Its really not that hard to get the relay/fuse panel out, orders of magnitude easier than replacing the starter. Relays are cheap. Replace the relay.
Getahorse II is offline
Old 04-05-2012, 04:28 PM   #4
hauntedxpast
Fan#: 82951
What I Drive: 2003 Red ZX3
FF Reputation: 1 hauntedxpast Good Standing Member
You could try jumping the starter sylenoid.. Sounds like an issue with the starter or sylenoid..
hauntedxpast is offline
Old 04-05-2012, 04:41 PM   #5
Buddy4679
Browser
Buddy4679's Avatar
Fan#: 94214
What I Drive: 2014 PB ST3
Points 1,916, Level 26
Points: 1,916, Level: 26 Points: 1,916, Level: 26 Points: 1,916, Level: 26
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 2 Buddy4679 Good Standing Member
CHECK FOR BROKEN WIRES!!! I went thru a very similar situation this week!!!!
Originally Posted by Malibooya View Post
I'm pretty much the biggest tool that could ever be in my car.
!!2003 SVT is GONE!!
2007 Silver Chevy TrailBlazer--GONE!!
2014 Performance Blue ST3
#128 Hatch Nation
Buddy4679 is offline
Old 04-05-2012, 05:54 PM   #6
GreySkorpion
Fan#: 94674
Okay thanks guys, will try all suggestions.
Old 04-05-2012, 09:05 PM   #7
GreySkorpion
Fan#: 94674
Starter and starter solenoid check out, we removed the starter and solenoid assembly from a donor car and it started the donor car up just fine. Next is to replace the starter relay with the relay from the donor car. (morning)
Weird thing is the car started and ran fine after we did the pound the key in the froze up ignition cylinder, once we got the key to turn, we replaced the ignition cylinder (tumbler), now we have the no start issue.
If its not the starter relay, I am stuck, looks like it will go to a automotive specialty electronics shop.
Old 04-06-2012, 07:19 AM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
Points 27,399, Level 98
Points: 27,399, Level: 98 Points: 27,399, Level: 98 Points: 27,399, Level: 98
Level Up 5% Completed
Forum Activity 19%
You should check the operation of the ignition switch. You swapped the starter, so obviously the starter is not getting the go-ahead from the starter relay. Swapping the relay will likely do nothing. It's very rare for a relay to be bad. Maybe 2-3 times in 8 years on this site. I've never personally had a bad relay in any vehicle I've worked on. I would plug in the N/S switch, and unplug the starter relay. Then I'd use an electrical tester to be sure that the relay is working correctly. Relays are merely automated switches. The small pins are the "coils" which is the electrical signal that tells the relay to change position. Then you have 2 pins for normally open operation which should be the wires going to the starter. You're looking for continuity not voltage to tell you if it's working. You should find 12v to ground on one of the coil pins, and one of the normally open pins regardless. When you turn the key to start, then you should have continuity between the coil pins. You may have a blown fuse on the coil circuit.
I could write more but I have to go to work on Good Friday.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-06-2012, 10:04 AM   #9
GreySkorpion
Fan#: 94674
Replaced the starter relay AND ignition switch,cleaned negative battery to chassis ground contacts, no start still!!!!
Old 04-06-2012, 11:53 AM   #10
GreySkorpion
Fan#: 94674
All fuses and relays have now been replaced. Thinking I will replace both battery cables with known working ones from my other focus. Also when I get it running it will be getting the BIG 3 upgrade!!
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
