New 08+ Cams for focus! Few questions - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 04-18-2012, 07:15 PM   #21
09vistabluecoupe
09vistabluecoupe's Avatar
Fan#: 67900
What I Drive: 2009 Vista Blue SE coupe
FF Reputation: 2 09vistabluecoupe Good Standing Member
Originally Posted by staticsword View Post
This may be a really stupid question, but here it goes anyways. When I install my new cams, will it change the noise of the engine at all, or the exhuast tone?
Yes.
SE Coupe 5spd with Sync and Drivers Group.
- FSWerks CAI
- Autolite AR103s
Midwest crew #52
09vistabluecoupe is offline
Old 04-18-2012, 08:06 PM   #22
staticsword
Fan#: 75360
What I Drive: 2009, black, ford focus, SES, coupe
FF Reputation: 1 staticsword Good Standing Member
Originally Posted by 09vistabluecoupe View Post
Yes.
Do you think it will be a lot louder with them? My car is already obnoxiously loud with the Race Header, I am hoping it will not be unbearable lol
staticsword is offline
Old 04-18-2012, 10:20 PM   #23
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,966, Level 74
Points: 12,966, Level: 74 Points: 12,966, Level: 74 Points: 12,966, Level: 74
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
The cams will add a different tone= you have the valves hanging open longer w/ some overlap.
The cams will have a slight different tone. A header w/ what mufflers? I had a Borla system to begin w/= resonator & muffler. When I ordered my Fwerk's header, I also added a stealth to the order too & that helps a lot. There are a few Magna flow mufflers that fit behind the flex & yes 6'' diameter mufflers fit, which is the diameter of the stealth. It'll sound great don't sweat it, I'd be adding a desent muffler or mufflers like Magna-flow.
felixthecat is online now
Old 04-18-2012, 10:52 PM   #24
staticsword
Fan#: 75360
I have the Fswerks Header and Stealth Exhaust
Old 05-03-2012, 11:16 PM   #25
Boyka67
Fan#: 79298
What I Drive: 08 Vermilion Red SE
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 1 Boyka67 Good Standing Member
vid?
Team Focalize
Team Duratec #96
Sedan Revolution #189
First and only cammed 2008 focus in South Texas since 11/23/2013
Boyka67 is offline
Old 05-04-2012, 08:26 AM   #26
staticsword
Fan#: 75360
I would like to get a video up, however I am having a really hard time finding someone to install the cams. Every shop I called refuses to install them, also I need to get it done on the weekend, which is another inconvience. I have only found one shop that was willing and they wanted $400 for the install, and I am refusing to go to a dealer since they would want a retarded amount for the install. Right now I am just trying to find a weekend mechanic who will install it at his house or somthing.
Old 05-04-2012, 09:03 AM   #27
AeR0_84
Fan#: 89717
What I Drive: 12,Focus,Black,Hatch,5spd,sport pkg
Points 1,471, Level 21
Points: 1,471, Level: 21 Points: 1,471, Level: 21 Points: 1,471, Level: 21
Level Up 72% Completed
Forum Activity 3%
FF Reputation: 1 AeR0_84 Good Standing Member
Buy-Sell-Trade Rating: (11)
where in canada are you located?
AeR0_84 is offline
Old 05-04-2012, 09:07 AM   #28
staticsword
Fan#: 75360
Saint John, New Brunswick
Old 05-04-2012, 04:58 PM   #29
staticsword
Fan#: 75360
Ok, I finally found someone today to install the cams at a decent price next weekend. However his concern is that when he opens the engine up to install them, dealing with the chain may be a pain. He said if he has to deal with the tension in the chain then it will turn into a 6-8 hour job rather than a 2-3 hours job. Does anyone know if it the engine cover comes off without realising the chain tension?
Old 04-07-2013, 10:27 AM   #30
budpln
budpln's Avatar
Fan#: 89951
What I Drive: 2008 red ses
Points 2,655, Level 31
Points: 2,655, Level: 31 Points: 2,655, Level: 31 Points: 2,655, Level: 31
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 budpln Good Standing Member
Thats great that Massive is pulling this off for the '08+ people! I'd go for the stage 1's. You will find you need cam bar that fits the back of the cams when you have the motor atdc & w/ that the #1 cam lobes should be pointing towards each other. The back of the cam slots are off set, so w/ that cam bar laying across the back of the head & into the cam slots it only fits one way & w/ the pass tire off. Use a timing peg= to keep the crank from spinning clockwise & then you you rolling the exhaust cam backwards w/ a wrench in the flats of the cam & shove a 3/16 drill bit thru the timing cover after removing a plug to keep the guide tensoiner from retracting. & then use 2 wrenches to bust the cam sprocket bolts lose. I used two tye wraps around the exhaust sprocket to the chain & undid the exhaust sprocket bolt & the intake one comes out when you pull the intake cam out. Install the intake sprocket on the new intake cam. I marked the cam caps on one side to keep them in order. The exhaust cam in next & put the sprocket on & tighten up the bolt's w/ the preveis two wrenches & put the timing bar in the back of the cams to make sure the cams are in time. For me its easier to do that to explain. Its fairley simple, just need to make sure the cams & crank are in time w/ one another. You'll enjoy the midrange grunt. I installed my crane cams last monday.
dude we need some vids no idle vids hate them!!!! 0-60 25-70 lets see some pull vids man i cant find any i am going to get cams this summer if the stage 1s pull hard unuf ill go with them but i might take the plunge with the stage 2s GET SOME VIDS IM DIEING TO SEE
budpln is offline
