#21 | ||||
Drum n Bass Lover
Can you explain how this works, especially on our cars, with the fog lights being the same bulbs and wattage as the low beams with the fog lights lower to the ground and not projecting as far?
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete www.soundcloud.com/betadnb www.facebook.com/betadnb |
#22 | ||||
Quite debatable. It's far, far safer to be focusing your eyes several seconds ahead. You should not be paying attention to the ditches at 60 degrees to the direction of travel at high speeds. That takes your eyes too far from center. You can do something about deer (and other obstacles) that are greater than 1 second away, so it's better to be looking more forwards.
In fact, the glare of having useless but more bright light right in front of you adds glare to your own eyes, which reduces your viewing distance. If there is any moisture on the windshield, as well, this will be illuminated because of the angle on incidence with the light the fog lights put on the road, so near the front of the car. Anyways, I'm not even saying don't use them.. I really don't care, lots of people use them. I'm just saying they won't make things safer for you or others on the road. And to tie this back to the original topic, that's why the fog lights are always off by default. |
#23 | ||||
That is, in fact, the intended purpose. In fog, you want to be seen from a greater distance, but the high beams are located high on the vehicle and are too bright, so they light up all the fog so you can't see for your life! |
#24 | ||||
Drum n Bass Lover
Directional light is brighter than omni directional light.
#25 | ||||
Neither light is omnidirectional... they're both in reflector housings. The difference is low beams are pointed down, intentionally away from oncoming drivers. Fog lights aren't really pointed at all, and the result is more light in the entire upper range and to the sides a bit. Good for having others see you.
#26 | ||||
#27 | ||||
Don't bother arguing with Altis, he clearly is much smarter than us and is well versed in how fog lights are designed and how they are enginereed to work. LOL. It's no surprise you're from Ottawa, I lived and worked there for 3 years very recently and this attitude from its driver's was VERY prevalent. (To be fair, there is a LOT of diplomatic "red plated" drivers their that have no business on the road). Some of your answer's about night time visibility and fog lead to believe you truly don't have a clue how to drive in heavy fog at night or otherwise. Oh yeah, that's right, Ottawa is the "fog capital" of Canada... wait, it's not... LOL. We wouldn't have any idea about fog out here living on the Atlantic coast (or any of our southern neigbhors along the eastern seaboard)...... It's clear you don't like fog lights or oncoming cars that have them on (I do agree that a LOT of cars with OEM fogs are barely effective), but, they are definately NOT brighter than low beams and do not "dazzle" oncoming traffic, since they are actually aimed LOWER than your low beams and not (by definition and design) directional (driving lights, conversely are directional). Anything that is aimed high (as in low beams or high beam headlights) or very bright will simply "bounce" back off of heavy fog and make it nearly impossible to see where you're driving. Fog lights are indeed pointed, but, since they are NOT a directional beam pattern, they appear to scatter, but, that light output is scattered to the sides of the car and the ground directly in front. If you want to test this, wait until dark, go to a deserted road, turn on your low beams and fog lights, park car on level surface and walk about 20 feet or so in front. Now, crouch down until the low beams are hitting you in the face, notice that the fogs still are NOT hitting your eyes yet? You will have to crouch even further downward (almost laying on the ground) until you "see" the beams from the fogs hitting your face. Now, an oncoming car's driver will be sitting MUCH higher up for the fogs to "bother" them, not to mention, they are not nearly as bright (yes, I know they use the same H11LL bulb), due to the non directional reflector as opposed to the low beams concentrated beam pattern. Still not convinced Altis? Go find a white wall (underground parking garage for example) somewhere,turn on all of your lights and back away slowly, you will see just how "low" the beam pattern of the fog lights really are. You certainly are entitled to your opinion, and clearly you don't like fog lights (for whatever reason), but, to say they are not helpfull to seeing or to safety is a callous statement.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue 2012 Escape Limited w/park assist 2010 F150 Supercrew XTR 5.4 4x4 2008 Kawasaki Concours 14 (street) 2008 Kawasaki ZX10R (track only) |
#28 | ||||
A quick google search returned this... http://uk.answers.yahoo.com/question...6153116AAUFtd0 http://www.letstalkdriving.co.uk/USE...G%20LIGHTS.htm High beams are far, far more effective when driving alone at night and I would highly recommend you use those on country roads instead. If it's foggy, go ahead and use your fog lights instead and drive a bit slower. And for hypermilers, you burn an extra 0.02 gal of fuel per hour while using them. |
#29 | ||||
Fog lights are supposed to be used with the low beams turned off, when you are travelling in fog that is so thick you can't see your hand in front of your face, and therefore are going about 5mph. This has happened to me twice, once in a older car with aftermarket fog lights that I could turn on independently of my headlights, and once in a newer car with factory "fog" lights. Man, was I pissed I could not turn off my headlights to reduce the glare of the fog. It is damn scary to be on a highway when the fog (or snow) is so thick you can't see the lines on the road. At least once every winter, somewhere in the US there is a case of people being killed in these low visibility situations. The government has mandated that we can't use fog lights as the only source of illumination, and that's probably a good thing because stupid people would be driving around with only their fog lights on and getting into accidents because they can only see 20 feet in front of the car. However, it would be nice if we could figure out a way to override the safety mechanism so that those of us who know what we are doing could use these lights for their long forgotten intended purpose. |
#30 | ||||
Anyways,l this clearly isn't going to get us anywhere. My whole point about this was simply that many cars intended for the rest of the world have it such that the fog lights will always be off when you start the car. There are many places around the world where it is in fact unlawful to drive with them on when visibility is clear. You can argue with me all you want, but the fact that it is specifically illegal to use fog lights in many countries in clear nights means that traffic authorities know that they are certainly not more safe to use in such conditions. I do agree that most people don't use things the way they are intended... but that's what I think the majority of people are trying to do. The only reason people are concerned about having them be on every single time the headlights come on is because they don't want to have to determine if they need them... they just want them always on. Additional Info: UK Gov Highway Act.. http://www.direct.gov.uk/en/TravelAn...code/DG_069859 Note 226 and 236. |
| Thread Tools | |
| Display Modes | |
