SVT Not Starting - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2012, 01:21 PM   #1
Dean2
Dean2's Avatar
Fan#: 78118
What I Drive: Yellow '03 EAP
Points 414, Level 8
Points: 414, Level: 8 Points: 414, Level: 8 Points: 414, Level: 8
Level Up 28% Completed
FF Reputation: 1 Dean2 Good Standing Member
SVT Not Starting
Hi all. I've got a no start issue that I'd like some help with.
The car's been running okay. It's always had the annoying near death dropping idle when pulling up to stop signs. Otherwise, all seemed to be well. It has 162k miles. Saturday afternoon, it wouldn't start. It seems like it wants to start if I hold the accelerator all the way down, but never actually does.
I have spark. I hooked up my timing light and it flashed during cranking. Everything from the coil to the plugs was replaced last fall. Having spark means I have a good crank position sensor, too, right?
I have not done a compression test yet. Will I get useable readings from a cold engine? And for future reference... I've always read that you shouldn't pull spark plugs from a hot aluminum head. How do you square that with needing to do a compression test on a fully warmed up engine?
I can hear the fuel pump running via the filler neck. I replaced the fuel filter (and let it crank for quite a while). The pressure regulator diaphragm is intact. If I'm not mistaken, I cannot check the fuel pressure. I did smell fuel in the engine bay after cranking.
I tried to get it to fire with starting fluid, but no go there. I removed the MAF sensor to gain access to the intake. I cleaned the sensor with contact cleaner while it was out. Would the lack of readings from the MAF cause it to not start with the fluid? Seems like it would burn regardless. Does it sound like I should go back to spark and/or compression?
There are no codes and no impending codes.
Any ideas on where to go next with the troubleshooting?
Thanks in advance!
Dean2 is offline
Old 04-02-2012, 01:36 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
What you describe could be a stuck injector dumping fuel, flooding the engine, and not letting the other injectors see fuel pressure.
It could be any number of other things too.
elsolo is offline
Old 04-02-2012, 01:43 PM   #3
Grinder
Fan#: 85627
What I Drive: 2003 CD silver SVT
FF Reputation: 10 Grinder Great Standing Member
Thanks in advance!
Well, good job describing your findings, you've covered a lot of the basics already.
My thoughts are this: If you have spark - the CKP signal is there. Doesn't necessarily mean it's correct, but it's there. When you crank the engine under WOT, the PCM enters de-flood mode in which it will provide spark but no fuel injector pulse. So if this is when it wants to start I'd be concerned with a possible leaking injector, low PCM power input (tends to hold injectors open way too long and foul plugs) or poor quality fuel.
If it wants to start under throttle but not quite 100% wide-open, could just be an issue with the IAC. If the IAC sticks shut, it usually causes an initial start/stall. If this continues for a period of time it will foul the plugs and a crank/no start will result. As they age, they can give you dashpot dips as you also described....
What bothers me is that you have spark but it wont start on ether. This tells me your plugs are fouled or you didn't use enough ether. Again, a symptom of a flooded motor.
I'm not sure what diaphram you checked. The SVT is returnless - there is no regulator. Just a contained pulse dampner (sorta resembles a regulator but is part of the fuel rail and not take-apartable) and a fuel pressure sensor on the rail.
How do you know if you have codes? Do you have a scanner? Do you have datalogging capability?
If you don't have the ability to datalog, the next easiest thing to do would be to remove the plugs. Inspect them for damage and fouling. Dry/clean them and crank the engine under WOT with the plugs out. Clean out the cylinders, re-install the plugs, give it a nice solid 3 second hit of ether though the throttle body (while holding it open by hand) and give it another go.
Grinder is offline
Old 04-02-2012, 03:23 PM   #4
Dean2
Dean2's Avatar
Fan#: 78118
Points 414, Level 8
Thanks for the replies.
By WOT, I meant full on, fuel off WOT. I sometimes have to do that to crank it when it's really cold out to prevent it from flooding.
I dug through a bunch of posts over the weekend. I either saw a Zetec thread on checking the regulator or should have said pressure sensor. Apparently, with one of those, a torn diaphragm will let fuel into the vacuum system. Anyway, not applicable here!
The leaking injector idea sounds perfectly logical to me, though I am NOT familiar with injectors/injection. But, it looks like I can check for this by pulling the fuel rail with injectors, pressurizing the system (key to run), and watching for leaks. Any tricks/tips to removing the fuel rail? Can this leak be from the o-rings or is it necessarily a leak due to a faulty injector? Sorry, I'm not sure how everything goes together.
I have a cheapo code reader, but no datalogger. (That tune/datalogger I want keeps looking better and better!)
I should have time to crack it open tonight (and inspect the plugs, too). If so, I'll report back then.
Thanks!
Dean2 is offline
Old 04-02-2012, 03:25 PM   #5
Dean2
Dean2's Avatar
Fan#: 78118
Points 414, Level 8
Oh, and if an injector is leaking, is it definitely broken, or could it just be dirty/stuck?
Dean2 is offline
Old 04-02-2012, 07:44 PM   #6
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,748, Level 78
Points: 14,748, Level: 78 Points: 14,748, Level: 78 Points: 14,748, Level: 78
Level Up 75% Completed
Forum Activity 11%
FF Reputation: 90 goinloco1 Excellent Standing Member
if your smelling fuel after cranking its the pressure regulator.
passenger end of the fuel rail. pull vacuum hose off the regulator and turn ignition on. Any fuel coming out of the regulator vacuum connection, its shot.
When the diaphram goes it dumps raw fuel into the intake through the vacuum hose.
If you find this, do not try to start or you may blow the intake due to the fuel puddled in the bottom.
goinloco1 is offline
Old 04-03-2012, 08:45 AM   #7
Dean2
Dean2's Avatar
Fan#: 78118
Points 414, Level 8
I got the injectors out. There was no visible fuel leaking, but one of them whistles just after the pump cycles on. I'm assuming that instead of flooding, I'm just not getting any pressure due to that leak.
Dean2 is offline
Old 04-03-2012, 09:56 AM   #8
Dean2
Dean2's Avatar
Fan#: 78118
Points 414, Level 8
Hmm, I guess a leak would screw up the atomization of the fuel and it does actually flood. All four are "firing".
Dean2 is offline
Old 04-03-2012, 11:45 AM   #9
Dean2
Dean2's Avatar
Fan#: 78118
Points 414, Level 8
Got it. O-rings! I love a simple, cheap solution.
I went back through the manual and realized that the top of the injector is also a press fit with an o-ring. I figured that that was as likely as anything else to be the culprit. I bought a variety pack of rings and found ONE that fit. So, I replaced it on the noisy injector. The first start took a while and required full throttle. (That may have been due to my leaving a vacuum hose unhooked.) After warming up, it restarted fine. Hopefully, it will do so again this afternoon.
I'll get a proper set of o-rings and replace them all this week.
Thanks much for all of the help. I wouldn't have figured this one out on my own.
Dean2 is offline
Old 04-03-2012, 01:22 PM   #10
Grinder
Fan#: 85627
sorry for the late reply but looks like you've got it figured out. What you did is indeed the most effective way of identifying a leaking injector.
I'm not really confident that your findings jive with your symptom. If the upper o-ring isn't sealing, there should be an external leak. I may be misunderstood though. If it works it works. G/L post again if you still have issues.
Grinder is offline
