I must be getting old... :-) DIY 2012 intake modification - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-16-2012, 11:45 AM   #71
Dysan911
Fan#: 95746
I hear everyone saying that the snorkel appears restrictive. How so? It seems volume wise to have more than enough flow our 2.0 engine could ever consume and the little holes all along the length in my opinion help extend the surface area that the snorkel can reach cold air. I.E. Instead of removing it and isolating the hole it left as the only entry point for cold air. Leave the snorkel but remove that stupid Plastic liner that blocks it. Now the whole entire length of the snorkel becomes one big catch for cold air coming through the front grill (behind the Ford logo).
Let me know if this idea is way off. Too bad we can't dyno it with and without the snorkel to really see the difference.
Maybe dremel out the air splitter in the center though.
Dysan911 is offline
Old 09-17-2012, 03:47 PM   #72
TORQUERULES
The Professor
Fan#: 1083
What I Drive: '13 Mazdaspeed 3; '87 'Stang
Points 26,426, Level 97
Points: 26,426, Level: 97 Points: 26,426, Level: 97 Points: 26,426, Level: 97
Level Up 8% Completed
FF Reputation: 9 TORQUERULES Good Standing Member
It has less than a 2" opening if I remember correctly and it has a horrible bend. Not to mention the rubber flap restricts it even more.
Yes, it IS restrictive.
TORQUERULES is offline
Old 09-17-2012, 05:53 PM   #73
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,291, Level 28
Points: 2,291, Level: 28 Points: 2,291, Level: 28 Points: 2,291, Level: 28
Level Up 94% Completed
Forum Activity 3%
FF Reputation: 13 BetaDnB Great Standing Member
I haven't cut the flap yet. I'm looking at it thinking, "what if I just make two cuts, front to back, a little wider than the intake, then somehow secure newly created flap downward to help direct airflow upward?" No? It's certainly a bitch of a spot to work in.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 09-17-2012, 05:56 PM   #74
Dysan911
Fan#: 95746
I cut one side of mine originally and then felt like what the hell. If I'm cutting one side I might as well just cut the entire flap out. So far no negative issues as a result. I don't really quite understand why they need to redirect every ounce of cold air right into the grill. It really makes you wonder how the intake snout was ever intended to breathe.
Dysan911 is offline
Old 09-19-2012, 05:11 PM   #75
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,026, Level 33
Points: 3,026, Level: 33 Points: 3,026, Level: 33 Points: 3,026, Level: 33
Level Up 84% Completed
Forum Activity 6%
FF Reputation: 12 dan50 Great Standing Member
My car is plagued with a stumble/surge on acceleration, which is worse in hot weather or when driving in stop-and-go traffic. Feels like the timing is being retarded.
Looking at the air intake layout, I wonder if it could be part of the reason. When the car is stationary, not only is no cool air directed to the intake, but the intake is sitting pretty much just above the radiator. One would epect it would get pretty warm in there. Plus, the air snorkel would absorb considerable heat, making the intake air warm even when moving. Could the intake temperature get high enough to cause pre-ignition, thereby telling the PCM to retard the timing?
Our DI engines can run the high compression ratio because the atomized fuel injected into the cylinder cools things off. I wonder how much this ability's compromised if the intake air temp is 130-150 degrees?
dan50 is offline
Old 09-19-2012, 08:07 PM   #76
ChrisRyan
Fan#: 97815
What I Drive: '12 SE Sterling Grey(5door) 5M 203A
FF Reputation: 2 ChrisRyan Good Standing Member
I removed the snorkel and cut the drivers side flap out plus the newmission and it is a different car at low RPM alltogether. The snorkel delete did give the car a nice intake note for sure.
ChrisRyan is offline
Old 09-20-2012, 11:21 AM   #77
Brabs_Weather
Fan#: 93741
What I Drive: 04 Ex Ltd, 08 Edge Ltd, 12 FF Ti
FF Reputation: 2 Brabs_Weather Good Standing Member
I just install the RX-4870
http://www.pumaspeed.co.uk/product-K...s-ST_15609.jsp
I used the end of the stock filter as the support ring. Also the curved part of the lid needs 1/4 to 1/2 inch trim so the end of the filter can extend trough the hole. I took the entire box out and tried to mach up the radius from the lower lid. I am going to make an aluminum one later. I may post picks later but the PUMA website looks the same. Look close and you can see the nice trim job they did. This may be option for some people.
White Platinum Tricoat Metallic
2012 Ford Focus Titanium
Handling Package Nitto Motivo's
Borla Exhaust with UltraQuiet resonator
K&N X-4870. Steeda RSB
Brabs_Weather is offline
Old 09-23-2012, 01:08 PM   #78
Jig Saw
Fan#: 94419
What I Drive: 2012 Sterling Grey Se
FF Reputation: 1 Jig Saw Good Standing Member
I'm gonna have to give this a shot - does it make any weird noises when shifting low in the rpm's with the dct?
2012 Sterling Grey SE Hatch. Debadged. 20% Tints.
Jig Saw is offline
Old 09-25-2012, 02:05 PM   #79
TiStick
Boob Whisperer
TiStick's Avatar
Fan#: 96514
What I Drive: LesVagon
Points 3,706, Level 38
Points: 3,706, Level: 38 Points: 3,706, Level: 38 Points: 3,706, Level: 38
Level Up 38% Completed
FF Reputation: 16 TiStick Great Standing Member
Here is my variation on your latest revision....
My newmisioned box, which after RTV'ing the hose no longer needs the hose clamp/bracket and is removable as a unit!
my backup() box with templates...
Templates transferred...
Finished product!
Sonic's Mk3 Crew #11
Hatch Nation#163
Originally Posted by suss6052 View Post
Watch out for the D
TiStick is offline
Old 09-25-2012, 03:16 PM   #80
TORQUERULES
The Professor
Fan#: 1083
Finished product!
Kind of what I did. How's the noise?
