P/S delete - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-03-2012, 11:30 AM   #11
FR2oh
FR2oh's Avatar
Fan#: 71822
What I Drive: 07 Silver ZX4. 00 SPI
FF Reputation: 2 FR2oh Good Standing Member
Buy-Sell-Trade Rating: (8)
I dont have a part number because i got it off a junk escape engine used , i would imagine you can just go to ford parts and tell them you have a 2006 ford escape with a 2.3 4cyl and tell them you need the pulley and bracket where the p/s would go since it has electric p/s
Sedan Revolution Member #222
Best E.T 15.0@90mph, 2.4 60'
Steeda SRI, F2 header, Magnaflow catback, Massive UDP, P/S delete, A/C delete, Eibach 22mm front swaybar, H&R springs, Eibach rear camber kit
FR2oh is offline
Old 04-03-2012, 11:38 AM   #12
FR2oh
FR2oh's Avatar
Fan#: 71822
FR2oh is offline
Old 04-05-2012, 09:05 AM   #13
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
What I Drive: 2005 Grey ZX4
Points 1,218, Level 19
Points: 1,218, Level: 19 Points: 1,218, Level: 19 Points: 1,218, Level: 19
Level Up 18% Completed
FF Reputation: 8 AMMO-Duke Good Standing Member
This is really cool. Questions...
Do you remove the fluid in the rack/lines before adding breather? I am wondering if it will be easier to turn without fluid. But then I would think you would have problems with no lubrication. I wonder if you took apart the rack and greased the moving parts?
Please give more specifics on how it drives. I assume you cant tell much difference at road speeds, how is it while parking?
AMMO-Duke is offline
Old 04-05-2012, 10:54 AM   #14
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I would be very apprehensive to try this on a car that came with power steering purely from a longevity standpoint. The steering column and joint to the rack aren't meant to see the kinds of stress they will experience without the power assist and things will probably wear much faster especially if one does a lot of low speed maneuvering. For a racecar or something of that nature, I could see it, but not for a DD. TB1999 deleted his by doing something like this, but his was a dedicated track car as well and said he would never consider a PS delete on a daily driver.
jetrinka is offline
Old 04-05-2012, 12:52 PM   #15
Bwinkelsas
Bwinkelsas's Avatar
Fan#: 50224
What I Drive: 2007, Screaming Yellow, ZX3 SES
Points 915, Level 16
Points: 915, Level: 16 Points: 915, Level: 16 Points: 915, Level: 16
Level Up 15% Completed
FF Reputation: 2 Bwinkelsas Good Standing Member
i did his p/s delete on my car using the jaguar idler pulley, just looped the lines, its been that way for about a year now. It is a dd, basicly all city driving. I can not say if anything was gained on the delete as i did it at the same time as the cfm pulley kit and clutch/flywheel kit.
1.706 / 7.720@91.13 / 12.381@96.84 letting off.
Stock Motor, why hate on the 2.0?
More power and new numbers to come soon...
Bwinkelsas is online now
Old 04-05-2012, 12:55 PM   #16
Bwinkelsas
Bwinkelsas's Avatar
Fan#: 50224
Hope the op does not mind, at crusing speed i personally like the no p/s better as you get better road feel, anything under about 5 mph though is tough.
Old 04-05-2012, 06:35 PM   #17
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Thanks for the input, did you remove the fluid from the lines/rack?
Old 04-05-2012, 07:14 PM   #18
FR2oh
FR2oh's Avatar
Fan#: 71822
I didnt ijust left the fluid in the rack and found a t-fitting and installed a breather but i can feel more power low end from it like an average bolt on.
FR2oh is offline
Old 04-05-2012, 11:01 PM   #19
AMMO-Duke
AMMO-Duke's Avatar
Fan#: 84715
Here's what I am thinking. By leaving the fluid in the rack, every time you turn, you will be pushing against the fluid(resistance) as it moves from side to side through the lines. Theoretically, if you remove the fluid it will be easier to turn because you will only be moving around air. This will probably only help at low speeds, like when parking. The only problem with this is that you are left with no lubrication. I wonder if it is feasible to take the rack apart and grease everything?
Of course, this is all just an idea. I have never taken apart a steering rack and I do not know how it works. Maybe I am way off, I am sure someone will chime in and let us know if I am wrong.
Old 04-05-2012, 11:49 PM   #20
PowerFocer
PowerFocer's Avatar
Fan#: 61706
What I Drive: 2010 Sedan SE
Points 4,602, Level 43
Points: 4,602, Level: 43 Points: 4,602, Level: 43 Points: 4,602, Level: 43
Level Up 26% Completed
FF Reputation: 2 PowerFocer Good Standing Member
P/S fluid is not so much for lubrication as it is for hydraulic pressure. You need the fluid in the rack to make it work. Air compresses, fluid does not. If you removed the fluid it would die quickly. Also, not having the pump means you have no way of changing the fluid. Once it goes bad you're going to have an even harder time and have to replace the whole rack when it dies.
In my opinion (based solely on my auto degree and not on ever having done one) the only truly effective long term P/S delete would be a full manual rack swap (early 90's escort). Sure you could make another setup work, but it will not last as a DD.
Originally Posted by WeeAsp View Post
Rule of thumb:
NEVER trust anyone with your car or your girl.
Either way, you could get a rod thrown in both.........
Fast cars make smart people do dumb things
PowerFocer is offline
