2nd gen - Page 3 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Second Generation > MK2 Focus
Old 03-29-2012, 12:25 PM   #21
Minchkin
Minchkin's Avatar
Fan#: 92792
What I Drive: 2009 Black SES Coupe
FF Reputation: 3 Minchkin Good Standing Member
Originally Posted by badazz2010focus View Post
I dont know if you have to cut out the in take silencer I've heard of guys doing it but I've never heard of guys putting it back in.
No, you don't have to cut it out.
There is a how-to somewhere on here, but it doesn't really show you everything. But it is really simple. I can go outside and snap some more pictures, if need be. (Or make another How-To.)
EDIT: Okay, I am a bit bored today. I went ahead an went outside and snapped a few pictures.
We are removing the item circled in yellow. That is our resonator. Removing that gives us a nice noise around the 3-4k range.
First, disconnect your MAF sensor (Circled in red.) by pulling out the red tab on the bottom, then pulling straight out. Hang off to the side, which was already done in the picture. Remove the screws circled in green, then disconnect the hose in the blue circle. As soon as everything is out of the way, pull straight up. It should pop out of place.
On the side, there is one more screw. Unscrew it, then grab the tube and pull it out. It shouldn't take too much force to pull it out. I gave it a little turn and it pulled right out. Then put the screw back in the hole for safe keeping.
It should now no longer have a big tube on the side. It should look like this.
Reverse the first step to put everything back together, and voila. Resonator removed. Should look like this:
Originally Posted by Fact Core from Portal 2
Before the Wright Brothers invented the airplane, anyone wanting to fly anywhere was required to eat 200 pounds of helium.
SES #032
Last edited by Minchkin; 03-29-2012 at 12:54 PM. Reason: Added a quick walkthrough
Minchkin is offline
Old 03-29-2012, 12:42 PM   #22
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by Effected View Post
How do u take out a intake silencer? Once taken out could it be put back in? And yeah i have no rear resonator but still not enough sound. Would just putting a new muffler add sound? Thanks guys
Adding a muffler in no way makes it louder lol wow. it will quiet it if anything. the sound is made by the airflow from the engine. More noise comes from less restrictions....
Galatians 6:14
crice8 is offline
Old 03-29-2012, 12:51 PM   #23
st12131
Focal Distortion
st12131's Avatar
Fan#: 74797
What I Drive: 2007, Huyndai, Santa Fe, GLS
FF Reputation: 8 st12131 Good Standing Member
I think the "2nd" cat everyone is talking about is only a cat if you have a PZEV, otherwise its just a resonator. I could be wrong, but when I did my exhaust, it definitely was not a cat on my car!
Posted via FF Mobile
st12131 is offline
Old 03-29-2012, 12:54 PM   #24
crice8
crice8's Avatar
Fan#: 84830
You are not wrong. back when i did mine i got in a big argument on here with someone because they kept saying we had two cats. the pzez has two cats. all others have only the manicat followed by a resonator then muffler. Non sport exhaust models also have the lunchbox muffler. replacing the large muffler right after your flex with a high flow/straight through muffler will give you more sound, you will also need to have the stock resonator that is also there removed too. But simply adding a muffler to your current setup will not help you with your goal
Galatians 6:14
crice8 is offline
Old 03-29-2012, 12:57 PM   #25
Effected
Fan#: 93697
What I Drive: 2009 red coupe SE Stick
FF Reputation: 1 Effected Good Standing Member
Yeah so the air intake silencer is off. Not a huge difference in sound but does sound a bit better. Since i have the "sport tuned exhaust" any other easy ideas? Cant take off rear resonator because I don't have one :(
Effected is offline
Old 03-29-2012, 01:00 PM   #26
crice8
crice8's Avatar
Fan#: 84830
Originally Posted by blueflow94 View Post
not sound like an a-hole, but where is everyone getting this secondary cat from?
It came on all pzez models. Also i have heard of cases where non pzez models also had a second cat depending on the state where they purchased the car. I have learned one thing over the past few months on this forum. No matter what everyone thinks the set parts are that come with certain models of certain years, there are tons of cars out there that are exceptions. weather it be dealer request or location as the cause is unknown. There are so many inconsistencies. That is why the best thing to do for anything mod wise is visually verify your own car first for the given mods then check with many other people. pics if necessary
Galatians 6:14
crice8 is offline
Old 03-29-2012, 01:01 PM   #27
crice8
crice8's Avatar
Fan#: 84830
you do have one.... having the sport exhaust means you have no rear "lunchbox" muffler. You still have a resonator and another muffler further up in your exhaust.
Galatians 6:14
crice8 is offline
Old 03-29-2012, 01:18 PM   #28
Effected
Fan#: 93697
Yeah ur right. So taking off the other resonator would be good? Just replace it with other piping?
Effected is offline
Old 03-29-2012, 01:25 PM   #29
crice8
crice8's Avatar
Fan#: 84830
Yes, have an exhaust shop replace the frontal muffler with a straight piece of pipe. See if that makes it lous enough for ya. If not, Get a Round magnaflow muffler online or buy mine after i take it off next week and have a muffler shop put it in the place of the resonator. They are a straight through design so it will give you a nice deep louder tone
Galatians 6:14
crice8 is offline
Old 04-26-2012, 05:31 PM   #30
HOTFOCUS101
HOTFOCUS101's Avatar
Fan#: 96284
What I Drive: 2010 White Suede SEL focus -
FF Reputation: 1 HOTFOCUS101 Good Standing Member
Can't you get a ticket for that ?
HOTFOCUS101 is offline
