bad rear brakes on 2012 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-26-2012, 05:53 PM   #1
murfmoble
Fan#: 90355
What I Drive: 2012 silver focus titianum
FF Reputation: 1 murfmoble Good Standing Member
Both my rear rotors are wearing like crazy, Fronts seem fine and no grinding noise from the brakes, I'm taking it in to have them check it out and hopfully fix this problem, I'll keep in touch!
murfmoble is offline
Old 03-26-2012, 06:06 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
If you have any problems with your dealer, then contact FordCustomerService through private message on this message forum. She will probably be around to say hello tomorrow during business hours. To PM her, click on her name to drop down a menu, and the 3rd selection will be "Send private message".
Good luck, hopefully they will fix it, and it won't cost you a thing.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 03-27-2012, 09:42 AM   #3
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,469, Level 36
Points: 3,469, Level: 36 Points: 3,469, Level: 36 Points: 3,469, Level: 36
Level Up 80% Completed
Forum Activity 18%
Hi murfmoble,
Pleasure to meet you! I'm the rep whynotthinkwhynot mentioned; here to help with your concern.
When you take the Focus to your dealer, PM me with your VIN, dealer, mileage, full name, and best daytime number so I can get this escalated to the Customer Service Manager for your area.
Originally Posted by whynotthinkwhynot View Post
...then contact FordCustomerService through private message on this message forum. She will probably be around to say hello tomorrow during business hours...
Morning whynotthinkwhynot,
I said hello to the OP! We'll see what assistance can be provided.
Take care!
Noemi
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 03-27-2012, 05:47 PM   #4
murfmoble
Fan#: 90355
went to the dealer and they needed to order parts but said they would have to turn the rotors down instead of replacing them with new ones, Don't like tis one bit, If I ahve a brake job down the line I will have to buy rotors myself and with only 6300 miles on the car I think they should replace them with new, What do you guys think?
Old 03-27-2012, 09:22 PM   #5
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
I can't say what it is without seeing it. I've seen debris- hard spots- in pads cause grinding. In that case, I'd say it's ok to turn the rotors and replace the pads. If the rotors were the problem, then those would have to be replaced. Like I said, it could go either way. If it's a problem, it will probably be a problem under warranty. Don't always assume the worst, if enough damage was done, then you would be likely to end up with a brake job under warranty due to the history. Brakes on these cars last longer than anything else I've ever seen- my fronts went over 60k miles, and would've probably gone 80k+. I changed them for a larger pad/rotor. Typically brakes should last about half that. Another scenario is that it was just a hard spot in the pads, the rotors can be easily smoothed out, and you'll never hear anything else in 80k miles.
Be eclectic.
Old 03-27-2012, 10:01 PM   #6
03rubicon
03rubicon's Avatar
Fan#: 95694
What I Drive: 12 SE Hatch, 03 Rubicon
FF Reputation: 2 03rubicon Good Standing Member
I agree with you, they should replace them. Ford warranty does not allow replacement of rotors unless they are not able to machined. The only reasons they say rotors can't be machined is if they are under the minimum thickness spec or will be under the spec after they have been machined for this repair, if a caliper has seized and has caused the brakes to go metal to metal or if the rotors are absolutely damaged beyond repair. If you are unhappy with the repair, I would contact ford customer service and see if they can help.
03rubicon is offline
Old 03-30-2012, 09:56 AM   #7
FordService
Official Ford Rep
Fan#: 79824
Forum Activity 18%
went to the dealer and they needed to order parts but said they would have to turn the rotors down instead of replacing them with new ones,...
Hi murfmoble,
Thank you for the info and your patience. Be on the lookout for my reply.
Originally Posted by 03rubicon View Post
...If you are unhappy with the repair, I would contact ford customer service and see if they can help.
03rubicon,
Thanks for the recommendation. We'll certainly take care of the OP's concern.
Take care and have a FANTABULOUS day!
Noemi
FORD SERVICE
p: 800.392.FORD
Old 03-30-2012, 10:52 AM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,351, Level 75
Points: 13,351, Level: 75 Points: 13,351, Level: 75 Points: 13,351, Level: 75
Level Up 26% Completed
Forum Activity 99%
FWIW, with unusual rear wear the first culprit I'd look at is E-Brake release, either a mechanical issue or accidental partial engagement when you (or another driver) thought it was released....
Luck!
sailor is online now
Old 03-30-2012, 05:37 PM   #9
murfmoble
Fan#: 90355
I haven't use the e-brake since I got the car! didn't park on a hill or incline and made sure the brake was released all the way down and its just me driving the car.
Old 03-30-2012, 11:55 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Well, you SHOULD use it occasionally, or someday when you need it it won't work!
And notice the OTHER common culprit, a mechanical issue causing it to drag....
BOTH are more common than defective pads or rotors.... Not that it COULDN'T happen, I just haven't seen a case yet....
Luck!
( I always like to hear a reason for a failure, even if it's fixed under warranty...)
