Steeda CAI Now Available - Page 13 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-29-2012, 03:36 PM   #121
FocusBoy58
Sonic Mk3 Crew #03
FocusBoy58's Avatar
Fan#: 38424
What I Drive: 01 Turbo,12 SE,95 Vette 396
Points 21,134, Level 91
Points: 21,134, Level: 91 Points: 21,134, Level: 91 Points: 21,134, Level: 91
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 14 FocusBoy58 Great Standing Member
Buy-Sell-Trade Rating: (16)
Originally Posted by Brabs_Weather View Post
Take a look at what AEM did and you will think that the Steeda is a bargain. They provide the tube and the MAF extension and you reuse your MAF. Save your money and make your own. Or buy something that has been tested. Injen and Steeda produce ~ twice the HP gains. AEM which they claims gives you 3hp for 399.00. WTF... yeah 3hp. The drop in filter can do better that that.
[IMG]http://www.aemintakes.com/images/l/AEM-21-702P.jpg
[/IMG]
That isnt for our cars those claims were made on something else obviously their dyno says the focus has 103 whp STOCK lol.. The aem made 8whp and cost 339.... K&Ns system isnt out yet but they are claiming 13whp but mine only made 6whp. Steedas is good but the CAI at higher speeds will make more power Short rams are only so good.
Granted Steedas is one of the best on the market so far.
2012 Audi Q7 TDI S Line ABTuning 391whp588wtq
01 Turbo Focus 300+ whp
2012 Focus 19" Niches, AEM CAI, F2 Race Header, 3" Borla Dual Exit, H&Rs, Eibach Sways 183whp157wtq
FocusBoy58 is online now
Old 03-29-2012, 03:37 PM   #122
Lemons92
Lemons92's Avatar
Fan#: 88083
What I Drive: 2012 Silver SE
FF Reputation: 1 Lemons92 Good Standing Member
[/IMG]
I have the AEM intake and imma be getting on a dyno here on the 7th pretty sure its more than 3hp cause after i put it on it felt a lot different
2012 Silver SE KSport Coil Overs OZ Racing 17" Rims Custom 2.5 Exhaust AEM CAI and lots more
Lemons92 is offline
Old 03-29-2012, 03:41 PM   #123
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,360, Level 42
Points: 4,360, Level: 42 Points: 4,360, Level: 42 Points: 4,360, Level: 42
Level Up 5% Completed
Forum Activity 4%
FF Reputation: 9 darkangelism Good Standing Member
will be interesting to see your numbers.
darkangelism is offline
Old 03-29-2012, 03:56 PM   #124
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
What I Drive: 2012 Sonic Blue SE Sport 5 Spd
Points 19,028, Level 87
Points: 19,028, Level: 87 Points: 19,028, Level: 87 Points: 19,028, Level: 87
Level Up 36% Completed
Forum Activity 30%
FF Reputation: 43 Duffman355 Great Standing Member
so would somebody care to explain how the ram air steeda works? Without a heat shield, I can't imagine it sucking air from there.
ST Crew #11 / SSR #5
Official Mayo Hater #1
Randomie's Lover #8
Duffman355 is offline
Old 03-29-2012, 04:15 PM   #125
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 4%
it uses the stock ford pipe that is already in there, that draws from outside the engine compartment.
Old 03-29-2012, 04:29 PM   #126
Long_John
Fan#: 90299
What I Drive: 2012 Focus White
FF Reputation: 1 Long_John Good Standing Member
I dont buy it.. I'm sure these numbers are with the hood up and a large fan blowing air at the filter.
Put the hood down and drive down the street, breathing through the shitty factory snorkel and it wont make that power.
Also.. velocity stack smoothing air into the factory rippled tube? I could understand if they changed things around so that it was a straight shot to the manifold.
I bet you can put a k&n drop in filter with an open box and make similar gains, if you were to dyno the same car/day back to back.
Long_John is offline
Old 03-29-2012, 05:12 PM   #127
greg hazlett
Fan#: 93486
What I Drive: 2012 Black Ford Focus SE Hatchback
FF Reputation: 3 greg hazlett Good Standing Member
^^ of course that is how it is tested, every car that is dyno'd does it this way.
greg hazlett is offline
Old 03-29-2012, 05:24 PM   #128
Kabigon
Fan#: 88299
Points 4,575, Level 43
Points: 4,575, Level: 43 Points: 4,575, Level: 43 Points: 4,575, Level: 43
Level Up 13% Completed
Forum Activity 13%
FF Reputation: 11 Kabigon Great Standing Member
Keep in mind that it is very important to minimize air turbulence in the MAF sensor housing.
Kabigon is offline
Old 03-29-2012, 05:27 PM   #129
Duffman355
Tasty Red Meat
Duffman355's Avatar
Fan#: 31282
Forum Activity 30%
I still don't get it. They both make 10 or 12 or whatever horsepower, but one is $80 more expensive? What am I missing here? I trust Steeda and have had parts by them in the past. Heat soak has to be a problem under non ideal conditions on the ram air setup right?
Randomie's Lover #8
Old 03-29-2012, 05:40 PM   #130
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 4%
They both use the factory pipe, so the incoming air should be the same temperature, one just has a heat shield that like you said would help limit heat soak from the rest of the engine, it isnt like the air filter has moved and the air would be significantly colder. It would just be marginally colder. For $80 probably could built a heat shield.
Probably better to buy the ram and upgrade to the heat shield later if needed.
