Adding rear swaybar to Focus that had none - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 03-25-2012, 10:43 PM   #1
Lscman
Fan#: 95211
What I Drive: 2007 ZX3
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 3%
FF Reputation: 9 Lscman Good Standing Member
Can anyone tell me whether my 07 Focus S that was manufactured without a rear swaybar is swaybar "ready"? By this, I mean does it have predrilled holes for the pivot bushing brackets and end links?
Ford has historically neglected to drill holes for swaybar brackets and end links on cars like Mustang etc that came without rear swaybars, so I'm wary to their cost-cutting behaviors. Drilling holes in the right spot can be a pita when you have no template.
any advice appreciated.
Lscman is offline
Old 03-25-2012, 10:48 PM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,618, Level 58
Points: 7,618, Level: 58 Points: 7,618, Level: 58 Points: 7,618, Level: 58
Level Up 34% Completed
Forum Activity 12%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
It does not have any mounts for the rear sway bar. I was in the same boat and went with Steeda's kit to fix that. It's not perfect and you'll hear suggestions to get it weld permanently in place but it does the trick and is a good mod to do. Better if you already have upgraded springs/shocks over stock.
rambleon84 is online now
Old 03-26-2012, 11:50 AM   #3
Lscman
Fan#: 95211
Forum Activity 3%
Cars without swaybars never have end links or metal bushing mounts pre-installed for center pivot points. What I'm trying to find out is whether or not my car has pre-drilled holes for the OEM mounting hardware. Did you have to drill the control arms and subframe to install the bar? thanks
Lscman is offline
Old 03-26-2012, 12:47 PM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 12%
The LCA's have the predrilled hole for the end links and are reinforced. There is not a mounting spot on the rear subframe and is what the Steeda kit addresses by using the clamps in the link i posted.
Here is my view:
You can easily verify the control arms and subframe by sticking your head down there. Ive never known an 07 that did not come with a factory rear sway bar to have the mounts on the subframe for the sway bar mounting but they all have had the same control arms with the hole for the end links.
Old 03-26-2012, 01:34 PM   #5
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,347, Level 64
Points: 9,347, Level: 64 Points: 9,347, Level: 64 Points: 9,347, Level: 64
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 7%
You could always go to the junkyard and find a hatchback or sedan that came with a rsb. then you wont have to worry about the gnarly noises typically associated with the steeda add on kit. Also if you do that you can clean it up really nice replace oall of the bushings put a few coats of paint on it then install it.
Edit: If I'm not mistaken then all pre 05 hatches came with rear swaybars.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 03-26-2012, 05:04 PM   #6
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,268, Level 72
Points: 12,268, Level: 72 Points: 12,268, Level: 72 Points: 12,268, Level: 72
Level Up 55% Completed
Forum Activity 99%
FF Reputation: 65 felixthecat Excellent Standing Member
Add the cradle too
You would also have to grab the cradle too for the mounts, if you are looking for an all bolt up.
felixthecat is online now
Old 03-26-2012, 09:40 PM   #7
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
Rear sway bar mount up to the cradle
Here is my view:
Rear sway bar mount= Just asking, Is that as far as you can get the left side mount over? Looking at your pix, looks like the left side can go over more. I see that ever so often, where the mounts aren't over as far as they should be. You probably all ready know that the bar works better when the mount are toward the end of the bar before the bent.
Old 03-27-2012, 09:33 AM   #8
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 12%
/\ that's the farthest left it can go using that bracket. There is a cross section on the back of the rear subframe that comes out behind the bar, before the bend. I was not exactly happy that i could only get the bar that far and not get the brackets symmetrical. I'd love to swap a rear subframe or get a proper mount welded at the same point as the focus's that came with a rear sway bar. Especially since the proper rear subframe has these mounts at the bend.. youre making me want to revisit this and find a place that can do a little welding for me.
Not my picture but you can see on another '07 a little better:
photo belongs to SMITHBOY76908
Old 03-27-2012, 10:18 AM   #9
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
I notice in the above pix, there are springs where a solid spacers should go. The bar would work better w/ solid spacers there.
Old 03-27-2012, 11:45 AM   #10
Lscman
Fan#: 95211
Forum Activity 3%
Thanks for pics.
wow, the Steeda kit doesn't look particularly desirable with respect to bracket location, shape or strength. It appears to be fabricated from flat steel plate like a universal addco product so the bushing brackets probably rotate on the frame bar under heavy torque. The flat plate solutions are OK if the pivot point is on the top or bottom of the frame rail, but not when it's positioned on a vertical surface. This position sees a ton of lateral rotation force, although a small hole drilled and tapped in the frame with a bolt would stop that motion.
One would think they could have designed custom shaped brackets to snugly fit the frame rail bend point, allowing the bracket pivot points to be positioned near the end of the straight center section of swaybar where they belong. I could do a far better job with some metal scrap, $5 heavy duty u-bolts from Ace Hardware, a grinding wheel, scissors and cardboard to make templates.
The $60 price tag for this steeda bracket kit is a joke. I think it's really designed to fit most chevy and ford and billed as a special focus setup lol. Welding isn't necessary but a better designed bracket is, imo. With bushing pushed together the effective torque arm lenght in the above photo is nearly double the OEM design. If the bracketry was totally silent & not moving under hard cornering (bad assumption according to owners), the 21mm bar becomes about a 17 or 18mm in practice.
Lscman is offline
