Boosting svt - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2012, 02:48 PM   #1
Bwhit1
Bwhit1's Avatar
Fan#: 95170
What I Drive: 03 svt focus
FF Reputation: 1 Bwhit1 Good Standing Member
Boosting svt
So I want to boost my svt. I was wondering what all I will need to do this. I know I need injectors, rods, pistons and a tune. What else will I need to do I would like to make 300 whp.
Bwhit1 is offline
Old 03-25-2012, 03:30 PM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
depending on how old your block is you can do what i did as well and get a new water pump and oil pump as well. get some arp main and head studs....might want to invest in a new cam gear as well...you can make 300 on stock camshafts but if you want the 400 range i suggest a stage 3 or 2 camshaft. some argue a BAP but others just recommend a svt fuel pump wich clearly you have will do just fine. but also if you want the 400WHP range a return fuel system is needed. might want to invest also in a bigger throttle body. and of course the turbo kit with a big enough turbo to withstand 400WHP....not sure on the head package thou...someone else would have to chime in there
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-25-2012, 03:45 PM   #3
Bwhit1
Bwhit1's Avatar
Fan#: 95170
I probably will do a water pump and oil pump. I'll also be doing arp head studs for sure
Bwhit1 is offline
Old 03-25-2012, 04:07 PM   #4
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
ohh also new front and rear main seals would be good too, i did those as well
FF MODERATOR
RIFF CREW
Old 03-25-2012, 04:25 PM   #5
itbparada
Fan#: 31881
What I Drive: 03 fSVT zx3
FF Reputation: 5 itbparada Good Standing Member
Timing belt & tensioner, Throttle Body, DiabloMaFia, 3" exhaust, 3x VF Poly Mounts, J&S safegaurd, WIDEBAND a/f setup, > stage 2 Clutch, Alum Flywheel, Limited Slip Dif
'03 Fsvt-JRSC/BBK/ODP/WMI/ZEX100shot/JEpistons/EAGLErods/ARP/P&PHead+1mm/CMtwindisk/FW/TorsenLSD/PolyMounts/67TB/CatDelete/3"SSExh
'98 Csvt Hybrid-3L 248whp/'97 SableWagon-DD
'03 R1-Built/'89 Sportster-14:1 1340cc
itbparada is offline
Old 03-25-2012, 04:27 PM   #6
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
You don't need to upgrade camshafts on an Svt
Sent from my PC36100 using FF Mobile
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 03-25-2012, 04:32 PM   #7
itbparada
Fan#: 31881
x2 Ive seen well over 350whp on SVT cams
I did although install adjustable cam gears & VCT delete.. made tuning easier and sounded wicked at idle lol
Old 03-25-2012, 04:46 PM   #8
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
I've been wanting a vct delete :( know anywhere to get them?
Old 03-25-2012, 04:47 PM   #9
Bwhit1
Bwhit1's Avatar
Fan#: 95170
I talked to Tom and he said VCTdelete isn't really worth it so I won't be doing that and the turbo I have is a ar .50 will that be big enough to make 300
Bwhit1 is offline
Old 03-25-2012, 04:55 PM   #10
itbparada
Fan#: 31881
need more specs from the turbo...
