Hacking the SD Nav Card - In THEORY - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-23-2012, 09:05 AM   #1
Faygo Focus
Faygo Focus's Avatar
Fan#: 85587
What I Drive: 2012 Tuxedo Ti with James Bond Pkg
Points 3,799, Level 38
Points: 3,799, Level: 38 Points: 3,799, Level: 38 Points: 3,799, Level: 38
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 2 Faygo Focus Good Standing Member
In THEORY, what would happen if you copied all the files from the SD Nav Card to a read/write 16GB SD Nav Card, and then modified some of the .png files to get different icons for things like your home, favorites, etc?
Anyone ever theorized about this?
Faygo Focus is offline
Old 03-23-2012, 10:27 AM   #2
mattphoto
Fan#: 95657
What I Drive: 2012 Black Focus SEL
FF Reputation: 1 mattphoto Good Standing Member
A new nav card won't work. There's some secure/embedded info on the factory card that allows it to be recognized by the MFT unit. The copied card would not have it, and the unit would treat it just as a data card. It has been tried before on the Edge forum.
But you idea IS certainly cool.
mattphoto is offline
Old 03-23-2012, 02:28 PM   #3
Faygo Focus
Fan#: 85587
Would that info happen to be the *.key file?
Old 03-23-2012, 02:31 PM   #4
mattphoto
Fan#: 95657
chances are you don't have access to the real secure content. SD manufacturers/developers have that locked tight and it has not been cracked yet. Also I recall reading some cameras utilizing serial/manu codes from the card itself to verify authenticity. Could be possible with MFT too.
Old 03-23-2012, 02:33 PM   #5
Faygo Focus
Fan#: 85587
How is it that they make the SD card read-only? The little switch does nothing, so is there some attribute on the actual media?
Old 03-23-2012, 02:43 PM   #6
JDBug182
JDBug182's Avatar
Fan#: 83895
What I Drive: 2009 Blue SES Coupe
FF Reputation: 3 JDBug182 Good Standing Member
Just an idea...what about copying all the files including any "hidden files".....i would assume thats where the files would be they dont want you messin with lol
mmmmmm...... fo-FoMoCo-coa??
JDBug182 is offline
Old 03-23-2012, 02:44 PM   #7
mattphoto
Fan#: 95657
SD (Secure Digital) was widely adopted by media companies because it has some propitiatory technology to hide and lock content from the end user. This has yet to be cracked and probably wont be because it relies on some hardware-level markers.
It's not just a flash memory card.. it can distribute content that is locked, it can run integrated hardware (like the eyefi cards), it can hide storage space (as well as anything saved to it).
All SD readers are subject to the gateway technology of the card that dictates how the card is interpreted when it is plugged in. No way around it as of yet.
Old 03-23-2012, 02:53 PM   #8
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,361, Level 42
Points: 4,361, Level: 42 Points: 4,361, Level: 42 Points: 4,361, Level: 42
Level Up 6% Completed
Forum Activity 6%
FF Reputation: 9 darkangelism Good Standing Member
If you worked for a memory company you might have tools to clone it, but nothing in the consumer world can.
darkangelism is online now
Old 03-23-2012, 04:29 PM   #9
Kabigon
Fan#: 88299
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
Forum Activity 14%
FF Reputation: 11 Kabigon Great Standing Member
It's not a matter of the card being read only.
There is a portion of the memory that you cannot access without the proper tools.
SD = Secure Digital
Kabigon is offline
Old 03-23-2012, 04:51 PM   #10
hotleadsingerguy
hotleadsingerguy's Avatar
Fan#: 86687
What I Drive: 2012 Black Titanium 5-Door
FF Reputation: 5 hotleadsingerguy Good Standing Member
Actually, that's not even possible either.
The way SD cards work is that the memory can be sectioned off completely, and given special attributes. What this means is that someone can set a certain amount of memory as a separate partition that can only be accessed by a specific hardware ID code, and it can *never* be seen except by that piece of hardware.
Not even memory tools would be able to read it. That's the entire reason this format was created. It was made so that media companies (music and movie) could protect their content from ever being read by anything but their own products. It's basically a way to not allow the content to ever be copied, and cracking it would be almost impossible.
hotleadsingerguy is offline
