Full Build... blue smoke??? Ideas??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2012, 10:52 PM   #1
itbparada
Fan#: 31881
What I Drive: 03 fSVT zx3
FF Reputation: 5 itbparada Good Standing Member
Short Story- First start after build.. some smoke as expected, took car out to seat rings & run heat cycles. 25 miles on the car now, slight amount of smoke on rev ups. No smoke at idle. Plug 1,2,4 CLEAN, Plug #3 slightly wet with oil, fresh plug installed
125 Miles on motor, lost ~.75 qt No smoke at idle. If I am comming down a hill off the throttle say 40mph in 4th... at the bottom of the hill I throttle & it blows a pretty decent cloud & clears right out. Friends have said they smell slight burning oil?Running Rich? when cruising behind me in a 50mph zone but done see anything. CEL for misfire cyl 3 came and went on its own, plug not so wet but oil still evident.
Im wondering what I need to do or just keep breaking it in?
2003 Fsvt
Head: +1mm Ferra Valves, New Guides, seats & Stem Seals, all ARP
Block: 2004 Zetec w/ 20k, Decked, bored, honed / JE Pistons / Total Seal Rings / Eagle Rods / Clevite Bearings / polished SVT crank / all ARP
This is the 7th zetec motor ive built with IDENTICAL internals / same machine shop & never had this issue. Rings were installed properly indexed. I install all of my pistons wet (dip in non detergent oil b4 dropping piston into cylinder). My guy over at the machine shop keeps telling me its because I didnt install them dry (rings / walls parts cleaned dry) and "turn the motor over by hand 30 revolutions to seat the rings to the hone".
Compression Test-
106 102 108 103
Im debating pulling the windage pan / head & sliding piston #3 out to see whats going on there... Any ideas before I start pulling this appart again? =/
'03 Fsvt-JRSC/BBK/ODP/WMI/ZEX100shot/JEpistons/EAGLErods/ARP/P&PHead+1mm/CMtwindisk/FW/TorsenLSD/PolyMounts/67TB/CatDelete/3"SSExh
'98 Csvt Hybrid-3L 248whp/'97 SableWagon-DD
'03 R1-Built/'89 Sportster-14:1 1340cc
itbparada is offline
Old 03-22-2012, 11:00 PM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
could be valves in the head?
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 03-22-2012, 11:02 PM   #3
itbparada
Fan#: 31881
First thing I did was replace the valve stem seals on that cylinder thinking maybe 1 got messed up durring install somehow. LOVE the DOHV valve spring compressor i have that bolts to the valve cover bolt holes:
No help though... valve cover breather isnt pushing out irregular amount of vapor... like 99% its not in the head, invested ALOT into it
Old 03-23-2012, 12:56 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,537, Level 100
Points: 52,537, Level: 100 Points: 52,537, Level: 100 Points: 52,537, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
Where is your PCV run to ? 2 places this can happen if your not running you valve cover or PCV to the intake is the valve seals and rings ???
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 03-23-2012, 01:24 AM   #5
itbparada
Fan#: 31881
Valve cover & PCV dump under car... custom breather with baffle welded in the back
Old 03-23-2012, 01:42 AM   #6
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,722, Level 94
Points: 23,722, Level: 94 Points: 23,722, Level: 94 Points: 23,722, Level: 94
Level Up 38% Completed
Forum Activity 13%
could the rings on #3 have shifted after indexing? maybe something odd with a clearance you didnt catch? I have always installed pistons wet.
mikebontoft is online now
Old 03-23-2012, 09:52 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
Well sure you do pistons wet , spinning the engine wont do anything to help seat the rings tho
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 03-23-2012, 12:27 PM   #8
itbparada
Fan#: 31881
Well i do remember being extra careful & putting compressor on each piston in the same fashion keeping it from rotating while compressing... each one dropped in with a few taps from the handle of my rubber-deadblow and moved like butter in the cylinder
Old 03-23-2012, 12:38 PM   #9
itbparada
Fan#: 31881
thats what i told him... but he is all dead set on dry assembly, he claims better compression, less blowby & blablabla. Dry wasnt even an option because i was building my motor piece by piece over the course of a year as money slowly rolled in...
so i took her out for a ride today, just hit 200 miles
Figured id mention i tossed my wideband in for a short time and its ALL over the place. would this be the slight oil burning... orrr because of the bigger valves, ported head & 9:1 compression block? good thing i havent touched boost
Old 03-23-2012, 02:14 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
What do you mean by all over the place on the wide band
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
