Focus SVT grinds going into second - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-18-2012, 09:14 PM   #1
roadracerex
Fan#: 84744
What I Drive: 2002 Black SVT
FF Reputation: 1 roadracerex Good Standing Member
So we autocross my wife's SVT Focus and she is not as agressive as I am with shifting. Under normal conditions just driving around it shifts fine. But autocrossing it at the limit with me shifting into 2nd at 7k rpm, it almost always grinds. I have adopted the wait 1 second and then shift mentality, but it acts like the clutch is not fully disengaging. We replaced the leaking clutch master cylinder last year. Bad clutch hanging up? Trans going? It looks like a previous owner has had the transmission out of the car. There is a bolt half-threaded into the engine block from the bell housing (looks to be cross threaded). I have to stay with a stock clutch configuration per the SCCA rules for STF class. Bad cable for the shifter? Any thoughts are welcome. I can do any work needed, just need to know where to look and in what order.
Disclaimer, I have drag raced my whole life and am used to slamming second gear in my Z06 while autocrossing.
roadracerex is offline
Old 03-19-2012, 06:10 AM   #2
sbslinde
Fan#: 94560
What I Drive: 2003 SVT Focus
Points 171, Level 3
Points: 171, Level: 3 Points: 171, Level: 3 Points: 171, Level: 3
Level Up 43% Completed
FF Reputation: 1 sbslinde Good Standing Member
It might just be that you have to wait for the sincros(sp) to engage. This was(is) an issue with the GT500 also.
If you don't follow the rules,
The results don't mean anything.
sbslinde is offline
Old 03-19-2012, 08:12 AM   #3
Buhda420
Buhda420's Avatar
Fan#: 85611
What I Drive: 2003 svt, silver. 5dr
FF Reputation: 1 Buhda420 Good Standing Member
My 2000 zx3 kona did that when shifting to third....... It$ exactly what to you say, sincros............ It cost me a lot to fix cause I don't really know how to work on vehicles other then minor stuff.......... so yeah its the sincros for sure!!!!!!!!!!
Buhda420 is offline
Old 03-22-2012, 10:08 PM   #4
greygoose8732
greygoose8732's Avatar
Fan#: 65707
What I Drive: 01' Liquid Grey S2, 03' Black SVT
FF Reputation: 1 greygoose8732 Good Standing Member
I had same issue and going into second and it was the second gear synchro. New transmission being put on now. Do you notice it grinding when the car is cool or when you just start driving? I noticed mine was worse after it got warm.
greygoose8732 is offline
Old 03-22-2012, 10:21 PM   #5
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,624, Level 31
Points: 2,624, Level: 31 Points: 2,624, Level: 31 Points: 2,624, Level: 31
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 24 6SPD_soul Great Standing Member
It really sucks, but everybody is right. 2nd gear synchronizer or dog teeth are toasted.
6SPD_soul is offline
Old 03-23-2012, 07:25 AM   #6
Buhda420
Buhda420's Avatar
Fan#: 85611
Mine grinder going into third all the time....... Cold/warm whatever!!!!! The only way I could avoid the embarrassing grind was to wait till the rpm fell really low then engage the stick into 2nd for you 3rd for my old kona...... Damn thinking about that ride makes me appreciate my svtf that much more.........
Mr.Snay's bone stock svtf.... Well a few minor appearance upgrades;)
Buhda420 is offline
Old 03-23-2012, 11:47 AM   #7
riprock
Fan#: 6081
What I Drive: 2003 Silver SVT5
FF Reputation: 1 riprock Good Standing Member
Its not terribly difficult to replace, just take your time and be very organized.....also make sure you have torque specs.
Team DreamSpeed
riprock is offline
Old 03-27-2012, 08:39 AM   #8
euroyellow
euroyellow's Avatar
Fan#: 88908
What I Drive: 2003 scream yellow SVT eap 3dr
Points 511, Level 10
Points: 511, Level: 10 Points: 511, Level: 10 Points: 511, Level: 10
Level Up 22% Completed
FF Reputation: 1 euroyellow Good Standing Member
I have the same problem with my svt.. second grinder when the motor/granny are cold or when shifting to second while reving high like 7k just as you said is like to know what the problem is too so let me know if you figure it out good luck
euroyellow is offline
Old 03-27-2012, 10:38 AM   #9
AliasJerk
Fan#: 52711
What I Drive: 2003 Screaming Yellow FSVT EAP
FF Reputation: 1 AliasJerk Good Standing Member
Syncros seem to be the general consensus. But has anybody thought to suggest cheap fixes first? What type of Gear oil do you run in this car? I have heard of a lot of people running RP Syncromax in the SVT, which isn't the correct oil weight for correct operation of the Getrag, maybe try changing to a different gear oil? Amsoil Severe Gear 75W90 is heavily praised, Redline MTL, or even just heading over to auto zone and getting some Mobil1 75w90 synthetic gear oil; I ran that stuff and had a good experience with it.
If the syncro isn't properly lubricated it certainly will grind if prematurely engaged.
AliasJerk is offline
Old 07-09-2012, 10:40 PM   #10
roadracerex
Fan#: 84744
I have not been able to find new parts. Where does one find new synchros for the SVT Getrag 6 speed to replace the old ones?
