rockford build - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2012, 09:37 PM   #41
FordBass
Fan#: 89775
What I Drive: 2012 Black SE Sport
FF Reputation: 1 FordBass Good Standing Member
I am going to use a pioneer head unit with upgraded op amps.
FordBass is offline
Old 03-20-2012, 10:04 PM   #42
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
Points 4,255, Level 41
Points: 4,255, Level: 41 Points: 4,255, Level: 41 Points: 4,255, Level: 41
Level Up 53% Completed
Forum Activity 3%
FF Reputation: 6 alaskanzx5 Good Standing Member
ok, first i have got to say that it just stupid to say your gonna do x db with a setup that isnt even built yet. there are far to many factors to make a good judgment on that.
second no, 1" isnt avaible here sadly and im making a false floor and bolting that down to the car and then bolting the enclosure to the false floor.
so the new box plan for me will be to shrink the box down and forget about the 2x4 and use that threaded pole, still slot ported and tuned to 38-39 hz just have to make the design and see where i can get the tuning at with out to much changes. i decided to use the threaded pole because i could use a smaller box while still keeping the same volume and to begin with i was worried that it could create issues with the airmovement in the box. the corners will all have 45s, double baffle still, i will be using wood glue where everthere is wood to wood contact and then useing liquid nails along all corners on the inside of the box to ensure no air leaks. i will still be facing the box in more then 1 direction so and doing testing to see what works best ( rear facing was the best with the last setup by about 1 db ) the port walls will be rounded and the port opening will be rounded. im gonna paint the inside of the box so that all the walls are smoother ( heard it can make a difference so why not try ).
hn155: Rockford punch pro speakers, t400.4 deh 80prs, full audio build to come. working towards 175hp n/a, simple but fun.
alaskanzx5 is offline
Old 03-20-2012, 10:07 PM   #43
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
Originally Posted by freemind View Post
What kind of processing are you guys using?
i have a pioner hu with a 7 band eq but i will eventualy upgrade to a rockford processor.
i personaly dont think that any aftermarket hu could realy be called a processor though, well exept that stage 4 pioneer that thing is just impressive
Old 03-20-2012, 10:17 PM   #44
02Zetechse
02Zetechse's Avatar
Fan#: 65832
What I Drive: 2002 Satin Black SE
FF Reputation: 6 02Zetechse Good Standing Member
Alaskan, Think about resin for the inside instead of painting ... both will get it smooth but the resin eliminates the need for liquid nail in the corner ... the idea behind painting/ resin is to smooth out the grain in the material for the smoothest surface possible to increase efficiency x amount
Current : 2 15s 149.5@56hz 2k rms Previous Trunk box 1 18 ,146.4@43hz 3500rms,Sony 12s 145.6@63hz
02Zetechse is offline
Old 03-20-2012, 10:35 PM   #45
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
^^ i already have the paint from doing some of my interior peices and i already have plenty of liquid nails from the last box. i realy have to keep the cost down for the box so im using what i have on hand. if this box gets me atleast 145.5-146.5 db then ill keep it till next year, if it doesnt then well i guess ill be rebuilding about 2 months later. its just that right now i have already put a grand into stuff to to fix body damage, i got headlights, my alt, and a throttle body, i only have 80 left of what i was saving for all this stuff. i still have to split the cost of a router with my dad so im realy pushing my limit.
trying to start buying a house so i have a strict limit on what i can spend
Old 03-20-2012, 11:23 PM   #46
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Originally Posted by FordBass View Post
Proccessing? In what means if I may ask?
Sound processing?
Yes, EQ, time alignment(TA), line driver, x-over, etc.
The Eclipse that I use has 13 bands of EQ, TA(tons of adjustment), x-over and 8 volts of output. Simply put, I love this deck.
I used to run a Pioneer Premier DEH-860mp. I almost bought a 800PRS until I came across a very good deal on the Eclipse.
The next deck that I buy will be a dead-head without a doubt.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 03-20-2012, 11:48 PM   #47
FordBass
Fan#: 89775
If you know the frequency response at 1m/1w you can figure what the potential is at a certain wattage.
FordBass is offline
Old 03-21-2012, 12:09 AM   #48
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
once i atualy start on the sq portion of this setup im gonna do rockford t2 (maybe t3)tweeters and their new 6" maybe the 8 " mid bass speakers in both doors up front running off either the t400.4or the t800.4 most likely the t800.4 with a rockford processor and if i can get it specail ordered i want the t3 crossovers that come with the t3 componet sets. then im gonna learn how to custom fiberglass and do the front doors to better aim the speakers towards the center of the car while still keeping the speakers as close to the stock location.
of course though that is all my current idea and stuff changes. ive been stuck at 85% complete on the audio build for ever now, i buy something install it then go i need more.
Old 03-25-2012, 09:29 PM   #49
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
alaskan i filled out the contact form for singer, what did they charge you for your 250 amp? im thinking that will be more than enough power for my needs(=
EDIT: scratch that i found it $390 shipped(= what other options did they give you? amperage wise for price?
Galatians 6:14
crice8 is offline
Old 03-25-2012, 09:35 PM   #50
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
Forum Activity 3%
well i asked them for a 280amp alt they said because of the space the biggest they can do is 250 unless im willing to do custom work to make a bigger alt fit so i dont know what the other options are. i think 02zetec is getting one for 220amp. they are direct bolt on h/o alt no mod needed just upgraded wires. could go to your local parts store to and buy and interstate deepcycle for under the hood about $90 so that while at stop lights you dont have as much voltage drop. still under the $500+ for 2 batteries then.
