ZETEC Engine stumble - SOLVED - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-20-2004, 03:43 PM   #41
bwojdyla
bwojdyla's Avatar
Fan#: 3589
What I Drive: Red 2000 ZX3
FF Reputation: 1 bwojdyla Good Standing Member
Its nice isn't it.
And don't complain about being cold at 31 degrees. It's 17 here. wind chill puts it at 4. Its so cold that my huge office buildings HVAC unit can't keep up with the heat loss. It's like 55 in here.
Those who control the present control the past, those who control the past, control the future. - George Orwell, 1984.
bwojdyla is offline
Old 12-20-2004, 07:46 PM   #42
InfraredZTW
InfraredZTW's Avatar
Fan#: 15867
What I Drive: 2002 Infra-Red ZTW
FF Reputation: 1 InfraredZTW Good Standing Member
"Most useful thread... everrrr" - The Comic Book Store Guy from Simpsons
Just keep driving...
InfraredZTW is offline
Old 12-20-2004, 08:00 PM   #43
tension001
tension001's Avatar
Fan#: 2278
What I Drive: 2001 Infra-Red 5sp ZX3
FF Reputation: 1 tension001 Good Standing Member
ahha wow, pretty cold. Its supposed to be getting down to 17 here tonight....
2001 Red ZX3 5spd
OBX 4-2-1 Race Header; Borla 2.5" SVT Catback; MAC Short Ram; FC 65mm TB; FC Race Shifter; Gear Concepts Aluminum Pedals; Painted Interior; SVT Front Bumper and grille
tension001 is offline
Old 12-21-2004, 01:16 PM   #44
InfraredZTW
Fan#: 15867
I'm having problems with the idling when i'm trying to keep my ATX at 30km/h in traffic with the brake. It feels like it's gonna die. And always if i am stopped and i press the brake, when the lights come on the engine stumbles.
BWO, any idea bulbs?
Old 12-21-2004, 02:20 PM   #45
bwojdyla
bwojdyla's Avatar
Fan#: 3589
nope. I was going to take a shot, but it would have been 100% pulled out of my rear end bullshit.
I can tell you some things to do though. First is to reset. Unplug the battery for an hour or so. This will clear the fuel trims stored in the ECU. Your programming will be reset to factory default and the computer will relearn the appropriate fuel curves. try cleaning out the upper intake (cleaning the MAF, filter, check the PCV valve itself). It's probably not any of the servo's like EGR or IAC since those would throw a quick CEL. check your spark plugs for fouling, check to make sure your spark plug wires are in good shape and the ends make strong contact on the coil and the plug, check all the vacuum hoses, not just the one that was bad in this case. that's about all I can think of that would amount to rough running as an easy fix.
bwojdyla is offline
Old 12-21-2004, 04:32 PM   #46
InfraredZTW
Fan#: 15867
"Damn rookies" I can't seem to find the PCV valve, on my Probe is right on top alive and clicking in a pool of mobil1 (btw what brands do you guys think are best in PCV-ing, also what would be the best sparks to use - i know not bosch)
I have a K&N flat filter almost new- so i won;t try to clean it yet
and what do you mean by cleaning the massAF, just some dust blowing? or real clean wiping?
Old 12-21-2004, 05:13 PM   #47
bwojdyla
bwojdyla's Avatar
Fan#: 3589
The PVC is on top of the oil seperator. look down at your engine, under the right side of the exhaust manifold is a rubber hose that makes a 90 into the top of the oil seperator (which is nestled up to the crankcase). That hose attches to the PCV valve, which supposedly just pulls out. I've never even been able to get the darn hose off to try.
To clean the MAF, first unplug it and take it out, as in out of its housing. There are two torx screws that hold it to the housing (you don't have to take the intake apart). look into it, there are two wires, one mounted low and in front, the other mounted high and in the back. the back one tends to get really dirty cause thats the one in stagnation. use a cotton swab and some rubbing alcohol to clean them both. it really smooths the idle if its dirty.
bwojdyla is offline
Old 12-30-2004, 04:59 PM   #48
InfraredZTW
Fan#: 15867
Kewl.
I'll try today maybe.
Thanks
Old 12-30-2004, 10:38 PM   #49
InfraredZTW
Fan#: 15867
Grrr.
I tried...The two torx screws on top of the maf are "secure"-torx with an extra pin in the center and after fiddling with a series of drivers for a while i got mad and took the intake pipe out, then found two regular torx on the side of the MAF assy and took the full maf assy out.
the resistor-like wires were one high and in the front and one low and in the back, the one in the back was (i would say a little corroded) darker and due to a lack of iso-prop alcohol i cleaned them with a drop of water.It didn't seem to do much to the darker wire and i managed to get some cotton stuck in the 4 pins that hold the wires(darn).
I cleaned everything and reinstalled.
It seems that the idle is better (5% better) i would say but only after the engine is heated.
I used the test mode and the rpm goes from 670 to 720 at hot idle with no accessories on.
When the flickering issue goes on the rpm goes down at least 50.
I also checked the PCV hose with my hand and it feels pretty firm.Could it still be broken ?
Anyway.
Ideas?
Old 12-31-2004, 10:57 PM   #50
InfraredZTW
Fan#: 15867
hmm.. i guess u'r partying hard till 2005..
Waiting for the 05 ZX3 to be on sale?
Similar Threads
Zetec engine identification mr_force ZETEC Performance (2000-2004) 15 09-05-2007 05:00 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
New Engine Technology 2004SVTAutoXer Ford Focus & General Car Chat 8 04-26-2006 07:06 PM
Zetec Stumble Fix...Help? jcarian General Technical Chat 1 03-12-2005 12:00 AM
