ZETEC Engine stumble - SOLVED - Page 20 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-23-2011, 11:57 AM   #191
daveringstaff
Fan#: 84320
What I Drive: 2000 ZX3
FF Reputation: 1 daveringstaff Good Standing Member
Mystery hose?
Wrong post
daveringstaff is offline
Old 05-10-2011, 01:46 PM   #192
y-bot
Fan#: 81143
What I Drive: 2001 silver SE wagon
FF Reputation: 1 y-bot Good Standing Member
I've got a 2001 SE Wagon with a Zetec engine and an automatic. I've got a code of P071 and slightly rough idle. I also think I can hear something that may be a vacuum leak coming from the back of the engine. I have a new one of the hoses discussed in this thread but I haven't quite figured out how to replace it. I removed the intake tube thingy that goes between the air cleaner box and the throttle body and I can see the end of the hose that goes to the PCV. I think I can feel the other end but I don't see it. Should something else be removed to get to it?
Thanks!
y-bot is offline
Old 05-10-2011, 02:22 PM   #193
2003zx5
Fan#: 84545
What I Drive: White 2012 SEL sedan
Points 291, Level 5
Points: 291, Level: 5 Points: 291, Level: 5 Points: 291, Level: 5
Level Up 82% Completed
FF Reputation: 1 2003zx5 Good Standing Member
It's there right below the throttle body. There is nothing else to remove unless you want to take the intake off. Hardest part when I replaced mine was getting the hose clamp off. You have to contort yourself and using a pair of pliers, remove the clamp. I just used a zip tie when I installed the new hose. And the hose will not go all the way over to the PCV, there is a steel tube between the hose and the PCV.
2003zx5 is offline
Old 05-10-2011, 11:07 PM   #194
y-bot
Fan#: 81143
That clamp is ridiculous. FYI - the hose it not the same diameter on both ends. I matched up the size of a hose clamp to the wrong end and it wouldn't fit the end it needed to go on. So, zip ties it is. Idle is smoother and I erase the CEL code, we'll see if it stays.
y-bot is offline
Old 05-10-2011, 11:11 PM   #195
Vexorg
Vexorg's Avatar
Fan#: 85499
What I Drive: 2001 Zx3 ChromeGold
FF Reputation: 3 Vexorg Good Standing Member
It's amazing how much that little PCV can effect things. Doorman rocks. I like their stuff. Their lower control arms are heavier duty than the OEM's and very well priced.
Vexorg is offline
Old 05-10-2011, 11:13 PM   #196
Charged SVTF
Was that our exit?!?
Charged SVTF's Avatar
Fan#: 22047
What I Drive: 2002 Sonic Blue Supercharged SVT
FF Reputation: 30 Charged SVTF Great Standing Member
Thank you thank you....I developed that part :) Yea, a clean PCV system can do wonders. We are also going to make the elbow from the PCV to the tube. Stay tuned.
2002 Sonic Blue SVT #246 of 4788 cardomain.com/ride/2483606
- JRSC BBK - Exhaust - Intake - Suspension -
First Place 2007 Season SJR-SCCA Solo and 2007 Rookie of the Year SJR-SCCA #20 SM
Charged SVTF is offline
Old 05-10-2011, 11:23 PM   #197
Vexorg
Vexorg's Avatar
Fan#: 85499
You designed the hose? or the control arms? Lol.
Vexorg is offline
Old 08-24-2011, 06:27 PM   #198
02focus2.0
Fan#: 89175
What I Drive: 2003 Pitch black SE
FF Reputation: 1 02focus2.0 Good Standing Member
First it stalls, now it races
I bought a old focus with 100,000 on it and for the first few days it ran ok. It suddenly started stalling whenever I came to a stop for any period of time. I could save it by popping it in neutral and just giving it the slightest bit of gas and putting it in drive again. I never had a problem restarting it if it stalled.
So I read all of your advice and sure enough it was the vacuum hose from the PCV valve on the back of the engine. The elbow was crushed and blocked the hose. I replaced it and it ran perfect...for about 10 minutes.
Now it seems the car just wants to go, no matter what the traffic conditions. it no longer stalls at idle but the RPM's keep climbing and when I throw it in neutral it revs at about 3,000 RPM or so (just a guess, this one does not have a tach) If I let the engine cool down for a few minutes it returns to normal but after prolonged driving it starts racing again. It is much more prevalent when the A/C is running
So here are my thoughts: Throttle body needs cleaning? IAV needs replacing? or is it something as simple as resetting something since this problem started 10 minutes after I solved the stalling problem? Any suggestions? No check engine lights
02focus2.0 is offline
Old 08-24-2011, 07:12 PM   #199
deezx5
deezx5's Avatar
Fan#: 72153
What I Drive: 2011 Gray Hyundai Elantra GLS
FF Reputation: 3 deezx5 Good Standing Member
I would start by unplugging the negative battery terminal for 15-30 minutes then let the car relearn its idle for a few minutes with ac off then a few more with ac on before going for a drive. If this doesn't work then it cost nothing and required minimal effort.
Also if you haven't done a tune up at at 100K plugs, wires, pcv valve are all due for replacement and a new fuel filter is always a good idea. Just a few things to keep in mind Welcome to FF
deezx5 is offline
Old 09-18-2011, 03:54 PM   #200
oshoguno
Fan#: 45853
What I Drive: 2012 Focus SE Hatchback
Points 661, Level 13
Points: 661, Level: 13 Points: 661, Level: 13 Points: 661, Level: 13
Level Up 22% Completed
FF Reputation: 1 oshoguno Good Standing Member
I don't know if this has been covered already or not. I got a PCV valve (Fram FV349), hose (xs4z-6n664-ba) and elbow (f8cz-6n664-aa) and went to do the job. I found out that the hoses inner diameter is different from what is on the car. My old PCV connection port is much bigger and the pipe under the thermostat housing is bigger. As a result the hose will not fit on the pipe and neither will the elbow if I use the new parts. Any help or information would be greatly appreciated.
oshoguno is offline
Similar Threads
Zetec engine identification mr_force ZETEC Performance (2000-2004) 15 09-05-2007 05:00 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
New Engine Technology 2004SVTAutoXer Ford Focus & General Car Chat 8 04-26-2006 07:06 PM
Zetec Stumble Fix...Help? jcarian General Technical Chat 1 03-12-2005 12:00 AM
