ZETEC Engine stumble - SOLVED - Page 18 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-28-2010, 12:18 AM   #171
pstaboche
Fan#: 73962
What I Drive: 1991 White ZX3
FF Reputation: 1 pstaboche Good Standing Member
Idle in neutral and park bad, engine cuts out Zetec Motor
I have a 2001 Focus and it cuts out while in neutral and park. Any ideas. Zetec motor automatic.
pstaboche is offline
Old 03-28-2010, 10:54 AM   #172
1stTimeFocus00
Fan#: 44202
What I Drive: 2000 InfaRed Zx3
FF Reputation: 27 1stTimeFocus00 Great Standing Member
Buy-Sell-Trade Rating: (9)
did you check the pcv value?
Also hows your wires/plugs?
Zetec Crew #152
United States Army
1stTimeFocus00 is offline
Old 04-03-2010, 10:33 PM   #173
musikron
Fan#: 74021
What I Drive: 2003 Silver ZX5
FF Reputation: 1 musikron Good Standing Member
This is awesome! I have been having a rough idle in my new (to me) 03 ZX5. I felt back there and the hose was mushy. I started the car to try and see if I could play with the hose and get it to act up, and it was totally collapsed cause of the vacuum! I will be addressing this first thing Monday, that and plugs should clear it up.
Thanks!
musikron is offline
Old 04-10-2010, 05:56 PM   #174
musikron
Fan#: 74021
Well I just did this to my car and it is a day and night difference! No more vibration, rough idle, and strange sounds coming from under the hood.
The part was 21.03 at the stealership, and you don't even need the one clip that was on there from the factory.
Thanks!
musikron is offline
Old 05-02-2010, 07:54 PM   #175
H0nda_Crazy
Fan#: 73688
What I Drive: 1991, black, Honda prelude
FF Reputation: 3 H0nda_Crazy Good Standing Member
Why isnt this shiznit stickied yet? I just found this faulty hose on my GFs car. Damn thing is sitting right here in front of me.
H0nda_Crazy is offline
Old 05-02-2010, 09:14 PM   #176
H0nda_Crazy
Fan#: 73688
So I just duct taped it. Started the car up and I guess its a really big hole because I can still feel the hose caving in under pressure. The tape sorta just adheres to the caved in section. The idle is fine now. seems a little low. My one concern is the tape failing and getting sucked into the hose. I put alot of tape on there so maybe its too much to stuff through the hole and it wont go through if it does stop sticking. Do you guys think its a bad temporary fix if the tape is drawing into the hose a bit?
Old 08-26-2010, 06:03 PM   #177
dieseldan001
Fan#: 77990
What I Drive: 2002 ford focus Zx3 2.0L Zetech
FF Reputation: 1 dieseldan001 Good Standing Member
ok, so i have a 2002 Ztech engine with a few problems.....1st, its got a rough idle....2nd its got shitty gas milage, and 3rd....just now *today* i broke off a little round tube that had a hose connected to IT and the air box.......any idea's on how to replace such a thing?? it was or is located on the top of the valve cover to the right........my prior experience is with a 200 SE 4 dr 2.0L sohc motor.......MAN these engines are different !!!
dieseldan001 is offline
Old 08-27-2010, 01:44 PM   #178
cnstarz
cnstarz's Avatar
Fan#: 78018
What I Drive: 2002 Black ZTS
FF Reputation: 1 cnstarz Good Standing Member
I have an 02' ZTS (manual transmission) with the stumble problem too . .. not only @ idle, but when I am in lower gears @ low RPMs. It is driving me crazy, and I don't know if its pertinent info or not, but it seems to do it worse when I'm running the A/C .. ... oh and @ idle it'll do it so bad it almost stalls out and then it sounds like the fan kicks on? Hmmmmm
unfortunately I'm a stereotypical girl and I do the sound effects and make up words to describe what's up w/ my car and that prolly won't help me here :( UGH
♥♥ Black 2002 ZTS ♥♥
cnstarz is offline
Old 09-15-2010, 11:35 PM   #179
bnaughty27
Fan#: 69010
What I Drive: 2000 Silver ZX3
FF Reputation: 1 bnaughty27 Good Standing Member
Thanks for this thread, it's was awesome! I've had a low/rough idle for over a year now, and found this thread the other night and right away found the hole in the hose. Was an easy fix and saved a ton of money. Thank you!
bnaughty27 is offline
Old 09-16-2010, 02:02 PM   #180
mattmartin4
Fan#: 78618
What I Drive: 2003 Dark Grey ZTW
FF Reputation: 1 mattmartin4 Good Standing Member
I have a stumbling problem when driving... I have noticed a slight stumble when idling - but it doesn't stall.
Going to check my pipe tonight.
mattmartin4 is offline
Similar Threads
Zetec engine identification mr_force ZETEC Performance (2000-2004) 15 09-05-2007 05:00 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
New Engine Technology 2004SVTAutoXer Ford Focus & General Car Chat 8 04-26-2006 07:06 PM
Zetec Stumble Fix...Help? jcarian General Technical Chat 1 03-12-2005 12:00 AM
