ZETEC Engine stumble - SOLVED - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2009, 06:23 AM   #151
MadFF
Fan#: 62398
What I Drive: 2005 Brown Focus ZXW
Points 286, Level 5
Points: 286, Level: 5 Points: 286, Level: 5 Points: 286, Level: 5
Level Up 72% Completed
FF Reputation: 1 MadFF Good Standing Member
Bleeder "nut" is clogged? My first thought.
MadFF is offline
Old 05-22-2009, 12:49 PM   #152
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,812, Level 49
Points: 5,812, Level: 49 Points: 5,812, Level: 49 Points: 5,812, Level: 49
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 2%
FF Reputation: 10 Paladin Great Standing Member
bumping this for a possible sticky by a mod. as i just did this. it should be listed with the howto's in the tech shortcut too. it'd help a lot of owners for sure.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 10-20-2009, 12:42 PM   #153
nozferatu
Fan#: 25104
What I Drive: 2012 Fiat 500 Sport
FF Reputation: 1 nozferatu Good Standing Member
Well...it's going on 4 years! I can't believe it went by so fast.
I'm getting a new TB and TPS from a fellow on this forum and let's see if that solves some of the issues I'm currently having. I've got a CEL light on now permanently...was intermittent...but I think it's the TPS and always may have been...who knows with this car.
nozferatu is offline
Old 11-20-2009, 07:57 PM   #154
Har01d
Fan#: 70686
What I Drive: 2000 grey SE
FF Reputation: 1 Har01d Good Standing Member
FIX for ENGINE STUMBLE
As previously reported in this thread, the engine stumble can be caused by the PCV hose from the rear of the intake manifold. This is a Motorcraft hose that is apparently only available from your local dealer with convenient hours. However for those of us who can't seem to be off in the middle of the M-F 8-4 timeframe here is a fix that seems to work and costs about $20.
First remove the offending hose (Motorcraft P/N C013A 988F-6N664-BA) and hold onto it. The hose clamp can be released by slipping a set of needle nose pliers into the two raised areas on the clamp and prying back until the clamp pops loose and you drop the needle nose into the engine compartment. The hose can then be removed by pulling and twisting.
Remove the opposite end of the hose with the aid of a long screw driver prying gently against the end of the hose.
Now take the hose to your local auto parts store and ask them for a replacement. They won't have it. So follow this up by asking if you can see all their hoses and match it up to one that is close in shape and size. They will invite you back to a wall of hoses and after looking for 10 minutes, you won't find it.
Now go to the wall of HELP! parts. These are parts that DORMAN has packaged to help you fix things that no one has parts for. Pick out P/N 46017 a PCV END Assembly. This part is 5/8" id on one end and elbows down to 3/8" id on the other. PERFECT. However it is about 1 1/2" long, so go over to the fuel line hose and cut 2 feet of 3/8" id hose. You only need one foot, but it's always good to have too much.
Now find the obscure area in the store where they sell VACU-TITE hose connectors and buy PN 47348 3/8" by 3/8" barbed straight hose connector. For the non US crowd that is 9,52 mm x 9,52 mm.
On the way out, buy a couple of hose clamps with a 5/16" to 7/8" range. You will buy a pack of 4 even though you only need one, then when you get home you'll find 3 of them that you still have from the last time you bought a 4 pack.
Now it's time to assemble. Insert the hose connector into the 3/8" side of the PCV END ASSEMBLY and then insert the other end of the connector into the 2 Ft. length of 3/8" fuel line. You may want to use some black electrical tape to wrap the connection.
A little white lithium grease on all the hose nipples makes everything slippery so it is easy to attach the hoses.
Trial fit the assembly and then cut the 3/8" fuel line hose down to the length that provides a large radius and keeps the hose from contacting any engine parts. For me this was about 13" long (12" would also work, but what the hell, I had a whole other foot to play with).
Now slip the 5/8" ID end of the PCV END ASSEMBLY over the hose nipple on the manifold, remembering to put a hose clamp over the end. Slide hose clamp in place and tighten. Not too tight, not too loose. Just right.
Now slip the other end (3/8" ID in case you get confused) onto the other hose nipple. Apparently this end doesn't require a clamp.
Only one thing left to do. Pull all the power fuses to reset the ECM. Fuses number 1 and 7 in the engine compartment fuse box on the 2000 SE seemed to work.
Now start the car and sit inside and revel in the glow of success and smooth idling.
Har01d is offline
Old 11-22-2009, 05:40 PM   #155
big shade
Fan#: 57280
What I Drive: 2002 white s/e Zetec
FF Reputation: 1 big shade Good Standing Member
This has helped me a ton
Old and collapsed. Thanks for the post! Now when I fix this I can get the wife off my butt.
big shade is offline
Old 12-08-2009, 05:00 PM   #156
jay1028
Fan#: 50724
What I Drive: 2003,Red ZX5
Points 1,517, Level 22
Points: 1,517, Level: 22 Points: 1,517, Level: 22 Points: 1,517, Level: 22
Level Up 17% Completed
FF Reputation: 2 jay1028 Good Standing Member
Hey guys I need some of your help. I just went to the dealer for the second time and got a different parts person. Still got the same response. They can't find the hose in their system. I asked to look at the parts drawings on the screen and couldn't find anything that looked like the PCV hose. I printed out the picture of the old and new hoses side by side from this thread and they couldn't find out what is was. They are telling me that the car has been modified and it is not an OEM part. What dopes!! I live in a small town not wanting to travel 60mi to another dealer, I need someone to tell me where I can get the hose mailed to me.
I don't know how such a large American company can have such badly drawn documentation in their dealerships.
Thanks,
Jay
jay1028 is online now
Old 12-10-2009, 06:59 PM   #157
jay1028
Fan#: 50724
Har01d,
Thanks for your info on the PCV hose mod. I can't get the OEM part and just put together the parts that you specified. Pep Boys has the parts and I assembled them with no problems. The new fabricated assembly is much better than the OEM hose and I don't think I will have to replace it every five years like the poorly designed Ford part. This new assembly is more heavy duty than the thin wall hose Ford supplied. I don't know what is in some of the automotive engineers minds using such a flimsy part as such an integral part of the motor operation. You have to wonder if there are any design reviews involved before designs are released. I like the car but have had too many problems with it in just 80k miles.
Alternator at 60k, coil pack,valve cover gasket and plastic thermostat housing (another design from a genius) at 63k, rear wheel bearings at 65k, ign cycl at 66k (that was fun being stranded), power steering pump leak at 70k and now PCV hose at 80k. I have a '96 Explorer V8 with no where near this many problems.
Old 12-10-2009, 07:15 PM   #158
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Zetec PVC hose with part number still attached
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Old 12-16-2009, 01:03 PM   #159
gaz1250
Fan#: 53832
What I Drive: 2003 Zetec 1.6
FF Reputation: 1 gaz1250 Good Standing Member
What are the symptoms of the hose failing?
gaz1250 is offline
Old 12-16-2009, 02:15 PM   #160
Feral
Feral's Avatar
Fan#: 58350
it varies, some cars have idle problems, some stumble when they accelerate some run fine.....
Feral is offline
Similar Threads
Zetec engine identification mr_force ZETEC Performance (2000-2004) 15 09-05-2007 05:00 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
New Engine Technology 2004SVTAutoXer Ford Focus & General Car Chat 8 04-26-2006 07:06 PM
Zetec Stumble Fix...Help? jcarian General Technical Chat 1 03-12-2005 12:00 AM
