ZETEC Engine stumble - SOLVED - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-19-2009, 09:25 AM   #131
jay1028
Fan#: 50724
What I Drive: 2003,Red ZX5
Points 1,209, Level 19
Points: 1,209, Level: 19 Points: 1,209, Level: 19 Points: 1,209, Level: 19
Level Up 9% Completed
FF Reputation: 2 jay1028 Good Standing Member
I Just checked the net and can't find the hose. Where are you guys buying this hose online?
jay1028 is online now
Old 01-20-2009, 02:05 PM   #132
p90xsexyguy
p90xsexyguy's Avatar
Fan#: 60206
What I Drive: 2001 Green Ford Focus ZX3
FF Reputation: 1 p90xsexyguy Good Standing Member
Jay1028 go to your local dealer.. You will not find it on the net...
"Never settle for the Best, Settle for being the Best of the Best."
p90xsexyguy is offline
Old 01-20-2009, 02:25 PM   #133
CaysE
EDM Specialist
CaysE's Avatar
Fan#: 22059
What I Drive: Blown red SVT
Points 15,564, Level 80
Points: 15,564, Level: 80 Points: 15,564, Level: 80 Points: 15,564, Level: 80
Level Up 43% Completed
FF Reputation: 80 CaysE Excellent Standing Member
Buy-Sell-Trade Rating: (13)
This may solve my ZX3's weird idle and P0171 at quarter tank issues. I hope!
CaysE is offline
Old 02-01-2009, 05:50 PM   #134
MadFF
Fan#: 62398
What I Drive: 2005 Brown Focus ZXW
FF Reputation: 1 MadFF Good Standing Member
Hello!
This thread is great... I am wondering if all this info relates to my car (wife's, actually).
We have a 2005 Ford Focus ZXW (wagon). It has a 2.0l engine with 58,000 miles on it. It has developed what I consider to be a rough idle, seems like it has gotten worse over the last 6 months or so. It runs fine, no stalling or stumbling, just a rough idle.
I went to check the air filter... surprise! It is permanently mounted in the bumper I guess? Who (and why?) thought of that design? The air filter air flow indicator (the clear plastic thing with the yellow indicator that moves the more the air flow is restricted) is barely visible, meaning I assume the air flow and air filter are fine.
I have removed and checked (then put back) what I believe to be the MAF sensor, and it looks totally clean.
The collapsed PCV tube that is being talked about here, do I have the same design or has it been changed? For the life of me I cannot find it, the pictures posted are great but maybe they don't relate to my engine? Looking from above my engine, should I be able to see it, or do I have to go under the car and look up?
Thanks!
MadFF is offline
Old 02-16-2009, 10:09 AM   #135
devil_dog_switch
devil_dog_switch's Avatar
Fan#: 55359
What I Drive: 2003 Black Dodge Durango
FF Reputation: 3 devil_dog_switch Good Standing Member
um ok well that's what i thought to.. mainly since i had 2 boots.hoses that were closing themselves. but i've replaced then with nice hard plastic.. so they can't crimp shut no matter what. but i'm still having the issues.
an thoughts??
Former Home of the Blue Light Special
Ask me about Lighting
2003 Dodge Durango Sport
2002 Ford Focus SPI *SOLD* you will be missed
devil_dog_switch is offline
Old 02-17-2009, 06:15 AM   #136
domesplit
domesplit's Avatar
Fan#: 19448
What I Drive: 2002 ZX5 and 2003 SVT ZX5
Points 990, Level 16
Points: 990, Level: 16 Points: 990, Level: 16 Points: 990, Level: 16
Level Up 90% Completed
FF Reputation: 1 domesplit Good Standing Member
Originally Posted by MadFF View Post
Hello!
Thanks!
Take a picture of your engine and I can show you. to try and answer your question you can see the pcv valve looking from the top of your engine but it wraps around your engine from the front to the right side then to the back. The rubber line becomes a metal line for about 3 or 4 inches then turns right back into a rubber line and goes behind the engine and twards the bottom and may be a little hard to reach or find if you don't trace the line. Also keep in mind that the line looks way smaller than what it seems; it's about as wide as your finger.
The line on the left is the new one the one on the right is the old one. This is the line that is on the back side of the engine. If you were to trace from the PCV valve that rubber hose goes to a metal line on the right side of your engine (driver side) the after about 4 inches of metal line turns back into a rubber line, that the line in the picture.Mine was collapsed so it was hard to tell if it was bad until I found it and noticed it wasn't round at the 90 degree turn
PCV Valve and start of hose
This is a modded engine but if you look at where it says Zetec, to the right you will see a silver cap and below that is where the pcv valve is located (to the right of the heat shield with x on it. The red line represents how your pcv valve line will run. Just look at all these pics together and you will find it.
domesplit is offline
Old 02-19-2009, 06:52 AM   #137
ingqman1
ingqman1's Avatar
Fan#: 62097
What I Drive: 02 Slvr SVT 08 Blk Suburban 11 Jeep
FF Reputation: 1 ingqman1 Good Standing Member
bwojdyla this thread should win some type of award. I think Ford should put you on there payroll for finding this problem. I think you are the first person in the history of this site to have found this issue, which I find quite funny considering how many of us have had this problem!
ingqman1 is offline
Old 02-19-2009, 02:20 PM   #138
domesplit
domesplit's Avatar
Fan#: 19448
a lot of people know of how to fix the psv hose problem but i just made is very simple for those of us who aren't so engine savy
Old 02-25-2009, 04:07 PM   #139
trailbikerider
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
Points 10,328, Level 67
Points: 10,328, Level: 67 Points: 10,328, Level: 67 Points: 10,328, Level: 67
Level Up 70% Completed
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
Just searched around for my hose, and found it's kinked too. Gonna go to Ford and get it replaced. What part # is the hose and/or what should I ask for?
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 02-25-2009, 04:56 PM   #140
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Just a FYI great pictures but the Red line goes to far behind the engine its actually located just right of the throttle body and below it :D I will get a better picture when I get my Zetecs both pulled from there cars
I know one of my zetecs has a bad one and the other has a brand new one.. I've yet to inspect my new Wagon for that since its still slime covered from the uncoating of the engine bay LOL
Wagon Partout - http://www.focusfanatics.com/forum/showthread.php?t=212282
My Wagon Rebuild - http://www.focusfanatics.com/forum/showthread.php?t=217009
Feral is offline
Similar Threads
Zetec engine identification mr_force ZETEC Performance (2000-2004) 15 09-05-2007 05:00 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
New Engine Technology 2004SVTAutoXer Ford Focus & General Car Chat 8 04-26-2006 07:06 PM
Zetec Stumble Fix...Help? jcarian General Technical Chat 1 03-12-2005 12:00 AM
