ZETEC Engine stumble - SOLVED - Page 11 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-04-2008, 01:42 PM   #101
HawkeyeFLA
Fan#: 6078
What I Drive: 2002 Ford Focus ZX3 Pitch Black
FF Reputation: 5 HawkeyeFLA Good Standing Member
So, I finally got off my lazy azz and stuck my hand down into the engine area, and sure enough, my hose is collapsing ... so I'm off to the Stealership. I know I can get it cheaper online, but I figure after S&H and my time waiting ... its not worth the savings. Gonna get some MAF cleaner while I'm out and clean that up also.
HawkeyeFLA is offline
Old 09-04-2008, 06:08 PM   #102
HawkeyeFLA
Fan#: 6078
Yay, new hose in. And man, that factory clamp is a pita. I have the newer hose with the metal heat shield around it. I'll post a picture up of the 2 different hoses in a bit. Haven't had a chance to do enough driving in the "zone" to see if the problem has gone away.
Old 09-14-2008, 10:08 PM   #103
edge10
edge10's Avatar
Fan#: 59206
What I Drive: 13 Ruby Red Titanium HB
Points 864, Level 15
Points: 864, Level: 15 Points: 864, Level: 15 Points: 864, Level: 15
Level Up 64% Completed
FF Reputation: 2 edge10 Good Standing Member
Talking
Many thanks to those in this forum!
My 2000 ZX3 Zetec popped a PO171 and then started idling rough and stalling. I tried fuel injector cleaner, replaced the air filter, fuel filter and PCV valve no change.
I am definitely not a car mechanic type, but I kept looking, finally found out where the other end of the PCV hose connected and felt around under the air intake and found the hose, it had collapsed. I got the the hose from the dealer, old style no heat sink, and replaced it a few weeks ago. That clamp is a bear! If not for the clamp, it would have been a ten minute job. Once I had the hose out, I could see it had collapsed and was cracked.
My car is now running great! Steady RPMs at idle, no problems.
One question: Is the other end of the hose, the one that attaches to the metal tube that goes over the block, is it suppose to slide over the bump on the tube? I didn't get it over that, but I secured it with another hose clamp.
Thanks,
Dave
edge10 is offline
Old 09-18-2008, 03:22 PM   #104
HawkeyeFLA
Fan#: 6078
So yeah, totally forgot I was going to post a picture of the newer hose with the heat shielding.
Here it is:
Old 09-22-2008, 03:53 AM   #105
sunyfoci
sunyfoci's Avatar
Fan#: 38913
What I Drive: 2001 red zx3 2.0L DOHC
Points 3,150, Level 34
Points: 3,150, Level: 34 Points: 3,150, Level: 34 Points: 3,150, Level: 34
Level Up 67% Completed
FF Reputation: 1 sunyfoci Good Standing Member
Thought i fixed my idle when i did the battery reset today only to find out that it wasn't fixed so after work in the dark i leave the car running stick my hand around thinking im not going to find anything and what do you know i find that very hose collapsed at the bend, problem was right in front of me the whole time, guess ill stop by the stealership again tomorrow
current mods: 2.5 borla catback, debadged, AEM cai, H&R coilovers, SVT frontlip, SCT Xcal, kenwood deck, gutted interior, shortened antenna, and a big ass dent on the passenger side
sunyfoci is offline
Old 09-24-2008, 08:12 PM   #106
sunyfoci
sunyfoci's Avatar
Fan#: 38913
replaced hose sucessfully car is still running like crap after cold starts and almost stalling when i come to a stop, rpm climbs and dips goes from rough to smooth almost in a throbbing pattern
sunyfoci is offline
Old 10-17-2008, 06:21 AM   #107
Benporat
Fan#: 59927
What I Drive: Focus 2012 Silver
FF Reputation: 1 Benporat Good Standing Member
Ford focus 1600 2004
Bad idle/choppy accel
Engine error lamp
computer analysis- manifold leak or bad sensor
pictures speak for themselves
thanks for the thread!!
Benporat is offline
Old 10-17-2008, 10:11 PM   #108
copper67440
copper67440's Avatar
Fan#: 43748
What I Drive: 2006 Charcol ZX5
Points 557, Level 11
Points: 557, Level: 11 Points: 557, Level: 11 Points: 557, Level: 11
Level Up 14% Completed
FF Reputation: 1 copper67440 Good Standing Member
This information is awesome. 150,000 miles and I have been living with the CEL going on and off for a while, stumbling at idle, irratic idle, stalling, sloooooow a take off, It's gotta be the hose. I'm going to check asap.
copper67440 is offline
Old 10-17-2008, 10:17 PM   #109
HawkeyeFLA
Fan#: 6078
Engine error lamp
Not familiar with that hose. Which engine do you have?
Old 10-18-2008, 03:13 AM   #110
subtleshift
subtleshift's Avatar
Fan#: 49283
What I Drive: 04 Sonic Blue Svt
FF Reputation: 1 subtleshift Good Standing Member
quick question, my idle bogs just like you guys are explaining, but i have an SVT...does anyone know if this is a fix for an svt too...if it wasnt late right now id check it out myself!
FS sri, FS front/rear strut bars, CFM pulleys (3), CFM sts, CFM 67mm TB, Fidanza lw flywheel, Centerforce dual-friction clutch, RT off road pipe, TOMS TUNE!!!
it helps to have a car lift. nuff said
subtleshift is offline
Similar Threads
Zetec engine identification mr_force ZETEC Performance (2000-2004) 15 09-05-2007 05:00 PM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
New Engine Technology 2004SVTAutoXer Ford Focus & General Car Chat 8 04-26-2006 07:06 PM
Zetec Stumble Fix...Help? jcarian General Technical Chat 1 03-12-2005 12:00 AM
