2012 installing amP help - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-06-2014, 01:47 PM   #21
h4ck3d
h4ck3d's Avatar
Fan#: 131929
What I Drive: 12' Focus Titanium 5dr Tuxedo Black
FF Reputation: 1 h4ck3d Good Standing Member
Originally Posted by cleonjones View Post
I used a fuse for my radio I can't remember exactly which but I also put a switch in near my fuse panel to turn my amp on and off. I've had it in for a few years now and still working fine.
There may be a better solution but I like being able to turn it on and off as I want.
yah that is what i have done in my previous cars, was just run a remote wire from the battery to a fused switch, and then to the amp. I was just hoping to get around that by splicing into the remote antenna wire.
2014 Focus ST - Tuxedo Black - COBB Stage 1
h4ck3d is offline
Old 03-06-2014, 03:07 PM   #22
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,327, Level 29
Points: 2,327, Level: 29 Points: 2,327, Level: 29 Points: 2,327, Level: 29
Level Up 18% Completed
FF Reputation: 0 smallblockfever Newbie
As long as the remote wire gets a voltage potential across it the amp will turn on. Doesn't have to be 12v, but its nice.
When the remote wire gets a voltage, the amp turns on. That's all it is.
You can tap the remote wire into anything. When that "anything" turns on (gets a voltage) then so will your amp.
Choose where your remote wire taps in by when you want it on.
Want it on with the head unit? Tap into the stereo.
With the ignition? Tap into that
I'd stay away from the power antenna because that only turns on if your radio (fm/am tuner) is on.
An easy way to make this circuit is to buy an add-a-circuit fuse. Its a fuse replacement that you put into the fuse box on the circuit you want to tap into and it runs another circuit off of that.
"Never miss a good chance to shut up."
smallblockfever is online now
Old 03-06-2014, 03:08 PM   #23
smallblockfever
Fan#: 95004
Here is a link to an add a fuse.
You can get them at any parts store.
http://m.ebay.com/itm/261414361917?nav=SEARCH
Old 03-06-2014, 05:08 PM   #24
cleonjones
Fan#: 81265
What I Drive: 2008 Red SES
Points 383, Level 7
Points: 383, Level: 7 Points: 383, Level: 7 Points: 383, Level: 7
Level Up 66% Completed
FF Reputation: 1 cleonjones Good Standing Member
This is what I have. Sorry that's what I meant by my fuse, just wire into that and stick a fuse in and wire your switch between the add a fuse thing and the amp. No remote wire coming from my battery.
cleonjones is offline
Old 04-10-2014, 03:47 AM   #25
edco76
Fan#: 153602
What I Drive: 2012 Focus White Titanium SEL
FF Reputation: 1 edco76 Good Standing Member
I used the add-a-fuse and tapped my sunroof fuse in the trunk.
edco76 is offline
Old 04-20-2014, 10:52 PM   #26
DustyAlex
Fan#: 107712
What I Drive: 2012 Sonic Blue SE
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 1 DustyAlex Good Standing Member
I'm in the same boat as Dansae, I had a reputable company install my amp/sub and it still sounds incomplete.... Also my steering wheel control for back, and fm/am switch is inop now.
Labour rate is $60 an hour, if you already tried to fix it $80 an hour, and if you want to help me $100 an hour
DustyAlex is offline
Old 04-21-2014, 09:58 AM   #27
smallblockfever
Fan#: 95004
what exactly do you mean by "incomplete"? That could mean a lot of things haha
Did you specifically have them install a harness for the steering wheel controls? The only reason you should have lost any control over that is if you got a new head unit and didn't install an adapter harness. Installing a sub/amp combo into a stock system should not have affected the steering controls whatsoever.
Old 04-21-2014, 09:32 PM   #28
DustyAlex
Fan#: 107712
Forum Activity 2%
They've installed something behind the head unit, I've fixed the incomplete sound today. I moved the wire running from the sub to the amp next to the other one (I'm assuming it's the in/out) Still no previous, or am/fm function on the steering wheel though. They did a complete sub/amp install including a inline converter
