Go Back   Focus Fanatics > Model Specific Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 03-15-2012, 04:03 PM   #1
rthomas0904
Fan#: 94714
What I Drive: 2012 White SE
FF Reputation: 1 rthomas0904 Good Standing Member
2012 installing amP help
How do I remove the bottom panel to run the power and RCA cable under it. The only option I see is holding up the weather striping and sticking a flathead screw driving and prying... I can plent of info on door panels but none on this... Also, and pictures or how to vids of how to remove head unit and whole center trim piece so I can install the loc would he appreciated also.
rthomas0904 is offline
Fan#: 1
Old 03-16-2012, 05:59 AM   #2
eyeballeater
eyeballeater's Avatar
Fan#: 87226
What I Drive: 2012 Sedan SE with sport appearance
FF Reputation: 1 eyeballeater Good Standing Member
How to remove head unit: http://www.justanswer.com/ford/5pzby...ord-focus.html
2012 SE Sedan Spec 201A, Sport appearance package and 17" wheels
eyeballeater is offline
Old 03-16-2012, 02:15 PM   #3
rthomas0904
Fan#: 94714
Wow I couldn't find shit on that to save my life. There's half my journey, thank you
Old 03-17-2012, 12:45 AM   #4
eyeballeater
Fan#: 87226
Here is some pics I took of how I attacked the wiring to hook up my LOC. Probably might help you out too. Mine is the SE model with base 4 speaker audio. Yours my vary a bit. Rep is always welcome.
Old 03-19-2012, 02:01 PM   #5
rthomas0904
Fan#: 94714
Got all my goodies today and started the install.... Eyeball, that info was the tits. Also, removing the panels beneath the door to run the wires was punctually much easier then I had planned. Have a huge problem though... Where to run the amp power cable through the firewall.... It appears like I have no holes where I can slid a 4 gauge wire through.... My focus is manual so i can't use the hole for the clutch cables. really don't want to drill a hole, but if i got to I better try to find a drill somewhere... Also, where have people been using as a ground in the hatchbacks? Any info on the firewall dilemma would be awesome... everything is in my car and wired up, just waiting on power...
Old 03-19-2012, 06:37 PM   #6
alaskanzx5
alaskanzx5's Avatar
Fan#: 82699
What I Drive: 2000 silver zx3
FF Reputation: 6 alaskanzx5 Good Standing Member
a seat bolt is a good ground, take a seat bolt out and sand all the paint under the bolt off and if the bolt is painted sand the paint off the bolt. you want to make sure to get all the paint off where the wire will be touching, some sand paper and a wire brush will clean all the paint right off.
hn155:rockford stereo, will have 2 t215's 2 punch pro tweets 2pro 6.5mids, t400.4 t1500.1bdcp.
perfomance build to come, lentach tranny, engine build for 250hp, turbo.
alaskanzx5 is offline
Old 03-19-2012, 08:15 PM   #7
pastoriusk2
pastoriusk2's Avatar
Fan#: 89909
What I Drive: 2012 Focus SE
FF Reputation: 1 pastoriusk2 Good Standing Member
There is a rubber grommet on the passenger side of the firewall where the main wiring harness goes in. What I did was cut a small X with an exacto knife away from the center so you don't nick any of the wires. Then you should be able to shove the power wire through that. I used 2 gauge wire so it was kind of a pain, but 4 gauge should be easy.
pastoriusk2 is offline
Old 06-14-2012, 08:54 AM   #8
DaeHanL
DaeHanL's Avatar
Fan#: 90891
What I Drive: 2012 Red Candy SE 5spd
FF Reputation: 1 DaeHanL Good Standing Member
Sub wiring was done by me. I know it's right.
I had the LOC installed at Best Buy, cause I don't know what I'm doing and it's only $20-
My sub does not sound very good at all. Sounds incomplete, not full. That got me suspicious of the wiring of the LOC.
Turns out only the front right side was hooked up! Opposed to both sides.
Would that definitely affect the sound coming from the sub? If so, I'm taking it back ASAP.
If not I'm assuming my set up just sucks.
NEVER YIELD!
2012 FF5DR SE Sport, 5-Spd, and ALL the 'fixins!
-DaeHan
DaeHanL is offline
Old 07-15-2012, 12:14 PM   #9
BLarson
BLarson's Avatar
Fan#: 58905
What I Drive: 2012 Ox White SE Sports Pack Hatch
FF Reputation: 6 BLarson Good Standing Member
Your the man!! Thank you for this!!
BLarson is offline
Old 08-21-2012, 03:20 AM   #10
BLarson
BLarson's Avatar
Fan#: 58905
Okay, I am a total noob when it comes to stereo installs but the local shop wanted to charge me $200 just for labor and another $70 in parts to install my subs and amp. I am very familiar with electrical work so i thought why not at least try it, as I've heard it's not too complicated.
So I've looked into what goes into it and have found a few questions. I've heard you can splice the LOC into the rear speaker instead of up near the head unit? I've heard you can use an amp which has line in inputs instead of an LOC? And if I instal the LOC near my dash, how many channels do I need on my LOC? I have a SE hatch with the tech package. So it has 4 speakers and two tweeters. I'm just trying to add a amp and two 12"s. Ive also seen a vast difference in price between LOC's, from $15-100. Get what you pay for? Or buy cheep? Any help would be greatly appreciated. I want to do it right.
BLarson is offline
